610 replies to this topic
#141 leemsami
leemsami
  • 66 posts
Posted 15 June 2012 - 02:51 PM
Guys I need some serious help. I flashed the 211 leak and now I can't get root back. Here is what I did.
1. fastboot 211.img (with unstuck211)
2. installed 211 leak from recovery (everything good so far)
3. booted up enabled debugging
4. fastboot 85.img
5. boot using bp tools
Here is where my problem is. I used mat's tool to root and I get error: more than one device or emulatur.
Please help!! I'm trying the whole process for the third time, but I could use some help.
When u extract the zip file, make sure the boot.img is in there. I had that problem. Unzip the .211 utility again and make sure the files are there
#142 aarnold0805
aarnold0805
  • 70 posts
  • Twitter:aarnold3273
  • Google+:aarnold0805@gmail.com
  • LocationRiverton, WY.
Posted 15 June 2012 - 02:52 PM
you mean the 85.img file? Well both bootimg files are in there, so trying round three. I hope it works, because I;m getting angry, and you wouldn't like me when I'm angry :D
Sent from my 209 KOA RAZR
#143 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 15 June 2012 - 03:08 PM
all good
#144 topaz330
topaz330
  • 10 posts
Posted 15 June 2012 - 03:13 PM
anyone get this script work to reroot the device?
, I tried and everything seems to push but no root when its all said and done
problem is that i'm a newb and not familiar with manually loading the boot.img and all that stuff. i was looking for a nice one click script that would root the device again.
#145 leemsami
leemsami
  • 66 posts
Posted 15 June 2012 - 03:14 PM
extract the files on the desktop and delete the older utility zip.
#146 aarnold0805
aarnold0805
  • 70 posts
Posted 15 June 2012 - 03:28 PM
well I did that and still getting the error: more than one device or emulator. Any other ideas?
#147 leemsami
leemsami
  • 66 posts
Posted 15 June 2012 - 03:32 PM
what leak are u on?
#148 etrorteepe
etrorteepe
    Not a Belieber
  • 221 posts
  • Current Device(s):Nexus 5
Try going into windows task manager. Kill all instances of adb and moto-fastboot if you see any. Or just reboot your PC.
#149 etrorteepe
etrorteepe
    Not a Belieber
  • 221 posts
Posted 15 June 2012 - 03:35 PM
4. fastboot 85.img
Its much easier to just use the root ics tool that can root any 4.0.4 based kernel.
#150 justin75
justin75
  • 21 posts
  • Google+:vatriquets@gmail.com
  • LocationVirginia Beach
Posted 15 June 2012 - 03:36 PM
My name's J and I'm a crack flasher.
Hiiiiiiiiii J.
Just a quick tid: I have found that if my sd is all junked up and full, I run into some hiccups trying to get leaks to flizash. I keep a 2GB sd I use for leaks and the I switch to a 32GB that has all my apk's, ROM zips that after I reinstall safestrap I use to flash the crack out of myself to test other ROMs.
But those of you that get stuck, thought it might help.
Thanks for lettin me share. (Lol)
Sent from my Apple Slicin Razr
#151 King Lo
King Lo
  • 7 posts
Posted 15 June 2012 - 04:05 PM
*nevermind*
#152 kbuck13
kbuck13
  • 105 posts
Posted 15 June 2012 - 04:07 PM
I did, un installed SU that was installed then ran the auto script and it workdd first time.
#153 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 15 June 2012 - 05:02 PM
Restarted three times, tried switching from no slide, back. Guess im going to have to do it again?
Is your usb plugged in? I have been loosing touch screen response when plugged in. I unplug and it instantly works again.
#154 alexh037
alexh037
  • 69 posts
  • LocationWoodland Hills, CA
So I woke up this morning clearly leaning to go from 181 to 210. I was in the process of finding the best download links, when THIS popped up. Good golly, now what to do!
There is NOTHING wrong with my 181/Eclipse, 50 hours battery, kick-rear end data, powerful signal, flash enabled device. Yet, the call of the sandwich still haunts my dreams.....
I was in the same boat. Loved my 181 but finally decided to jump to ics and installed 210 yesterday. Now i know what all the fuzz is about...this thing is fast and smooth so damn sleek there is no looking back.
#155 Guest_R3Ds_*
Guest_R3Ds_*
Posted 15 June 2012 - 05:39 PM
Anyone notice vm heap is set to 128m, why so high? I set back to 64m and did not notice a difference.
R3Ds Themes
#156 mdowns989
mdowns989
  • 211 posts
  • Twitter:@mdowns989
  • Google+:+Michael Downs
  • LocationCentral Coast Cali.
Posted 15 June 2012 - 05:59 PM
I have a problem... it started with the 210 leak.. I now have 211 installed... it runs GREAT as long as I stay stock..Anytime I install a ROM it seems that the gallery has serious issues reading from my ext. SD card.. it will not populate my pics,videos etc.. and will not sync my google photos either.. if I remove SD card it syncs google photos perfectly.. and yes... I've cleared data.. cache... everything... nothing seems to help... anyone else have this happen? Its driving me nuts.. moreso since stock works just fine so its NOT a bad reader... any ideas are most appreciated..
#157 MartyChubbs
MartyChubbs
  • 211 posts
  • LocationThe Ghetto, Minnesota
Posted 15 June 2012 - 06:16 PM
I erased my sd after 210 cause it was funky too. Works normal...
I (aka Mr. Chubbs aka Marty "The Wad" Chubbs aka Knot Mehreelname ) accept no liability for the content of this post. I basically made it all up as I was typing...
#158 mdowns989
mdowns989
  • 211 posts
Posted 15 June 2012 - 06:36 PM
I erased.. Even copied to new SD card... same $!#7..
#159 porkshanker
porkshanker
  • 57 posts
Posted 15 June 2012 - 06:37 PM
stock 181 unrooted... I did the wipe in stock recovery and install update from zip. It fails towards the end and saying install aborted.
#160 loonie01
loonie01
  • 190 posts
Posted 15 June 2012 - 06:40 PM
try a factory reset
