610 replies to this topic
#81 DriveEuro
DriveEuro
  • 68 posts
Posted 15 June 2012 - 07:49 AM
Not in the stock browser. I have it working in Dolphin though.
#82 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 15 June 2012 - 07:52 AM
Flash will not work on stock ics build. Look in your system/apps there is an apk called flash removal. Moto is being apple and only wants html5.
#83 iDroidGuy
iDroidGuy
    :D Taco!
  • 650 posts
  • Twitter:iDroidGuy
  • Google+:Stephen Wilmot-Doxey
  • LocationHopewell, VA
Posted 15 June 2012 - 07:54 AM
Quick question. Do I place the Zip on the internal or external SD. My gut is telling me internal
If you'd like to buy me a Mountain Dew just PM me for my PayPal info. Thanks :)
#84 mkarps
mkarps
  • 56 posts
Posted 15 June 2012 - 07:55 AM
Ok running into problem. I fastbooted to 181 in utility and then rooted. put the 211 file on my sd card. held vol+- and power. Hit recovery. install zip from sd card. installed the file. at the end said something E; install aborted. could not sideload...or something. now reboot only goes to dual core screen. any help?
#85 mkarps
mkarps
  • 56 posts
Posted 15 June 2012 - 07:56 AM
I put mine on sd card which is wrong maybe?
#86 (TSON)
(TSON)
  • 529 posts
Posted 15 June 2012 - 08:00 AM
Flash works fine. That APK is unused. It's the APK that that would tell you that Flash is unsupported in in earlier builds.
#87 exalted911
exalted911
  • 30 posts
Another one??? wow I am sure glad I didn't update to 210. I am very happy with 209. Not planning on updating anymore till the official ota comes out.
U people are crack flashers geeezzzz.
  • fixxxer2012 likes this
#88 mkarps
mkarps
  • 56 posts
Posted 15 June 2012 - 08:07 AM
OK. So I'm probably dumb and forgot to wipe data before sideloading 211 file. Maybe that's why I recieved the aborted install error? Will try wipe and sideload again now. Otherwise guess I'll have to fastboot back to 181 again I assume?
I could try the ES file explorer way but the file is on my sd card but it's still not showing in ES file explorer.
Update: Yeah same error.
E:Error in tmp/sideload/package.zip
status 0
installation aborted
#89 rndchef
rndchef
  • 65 posts
Posted 15 June 2012 - 08:26 AM
status 0
You must be on stock .181 rooted. No Bootstrap or Sidestrap. If the files are not showing on ES File then you might need to go into settings and check the two root boxes and then you should not have an issue. Save file to cache and click on leak file and rom manager does the rest. If you fail to sideload, the files in cache disappear and have to be resaved there.
#90 DriveEuro
DriveEuro
  • 68 posts
Posted 15 June 2012 - 08:32 AM
Its not that bad with the new method that doesn't wipe your phone. I flash and just have to tweak a few things for like 2 minutes. That's all.
#91 fixxxer2012
fixxxer2012
  • 262 posts
Posted 15 June 2012 - 08:34 AM
i may not move from .210 until the ota hits, getting tired of setting everything back up. this is as bad as using cm9 nightlies, lol.
#92 arparaspolo
arparaspolo
  • 7 posts
Posted 15 June 2012 - 08:35 AM
Does taking this update pull you from the OTA updates in the future?
#93 fixxxer2012
fixxxer2012
  • 262 posts
Posted 15 June 2012 - 08:38 AM
im going to say yes it does. but you should be able to fastboot the ota, no issues when it drops.
#94 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 15 June 2012 - 08:41 AM
status 0
You need to go and read the instructions for 206 or 209 and follow them. There are a number of steps you are missing. I would post them for you here but I'm not at a computer.
#95 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 15 June 2012 - 08:45 AM
If your happy with .210 that's cool, no need to flash 'em all, but you can use my teaks to Matt's Utility
, keep your data and not have to set anything back up. There may be a few apps that you have to reinstall or clear data on, but that's about it.
#96 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 15 June 2012 - 08:50 AM
WTF! I just jumped to .210 less than 48 hours ago. LoL
#97 mkarps
mkarps
  • 56 posts
Posted 15 June 2012 - 08:51 AM
OK I will recheck my steps.
#98 XCellFoneSalesRep
XCellFoneSalesRep
  • 53 posts
  • Twitter:https://twitter.com/XCellFoneRep
  • Google+:http://goo.gl/XgDaW
  • LocationThe Joisey Shore, Nu Joisey
Posted 15 June 2012 - 08:56 AM
Hey is anyone else having problems with Safestrap on .211? 2.00 wont install recovery for me :(
#99 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 15 June 2012 - 08:57 AM
Install busybox from the mark... uh. Play Store.
  • XCellFoneSalesRep likes this
#100 XCellFoneSalesRep
XCellFoneSalesRep
  • 53 posts
Posted 15 June 2012 - 09:01 AM
Thank you kind sir
