Yeah after I posted that I thought about it and realized it was a stupid question seeing how you go back to .85 to root,but thanks for the response..75 and .79 can be fastbooted back to a working .181 (GB) state.
Anything past .79 (which would be .206, .208, .209, .210, or .211) can not be downgraded back to .181 (gingerbread), in a workable state -- if the OTA is, lets say .206, and you're on .211, you'd use matts unstuck util, and go back to 206 that way (fastbooting the .181 files, the 206 boot img, then the 206 zip) <-- again, thats just an example, presuming that 206 was the ota (it doens't mean it will be, or any of these leaks will be).
#61
Posted 15 June 2012 - 06:19 AM
#62
Posted 15 June 2012 - 06:20 AM
#63
Posted 15 June 2012 - 06:24 AM
#64
Posted 15 June 2012 - 06:25 AM
172.46KB 113 downloads 143.76KB 112 downloads
#65
Posted 15 June 2012 - 06:29 AM
6.16.211 Mirror on XBot.
Enjoy.
X
thank you, ROMBOT appears to be down (again)
#66
Posted 15 June 2012 - 06:45 AM
A CRC (Cyclic Redundancy Check) file is used to ensure that the file you received is the same as what was sent. The HTTP protocol does not have data integrity checking built into it (like FTP does), so its possible that you could download a corrupt file without any notification from your browser. The CRC helps by providing a blueprint for you to check your downloaded file against. It works like this: File owner applies an algorithm to the file and it spits out a number, which is saved as a CRC. Then you run that same algorithm against the file you downloaded and see if you get the same CRC number. I might be missing some details here, but off the top of my head this should give the general idea.Put the .zip and .crc (the .crc isn't *needed*, but I've become used to putting it on there as well, since it's so small anyhow), on the root of your SD CARD, and flash it through moto recovery. Everyone wants to use the rom manager method, but even matt tells people to sideload with moto recovery, as its, IMHO, the easiest way to get it done.
That's where the CRC is useful to us, even though the phone does not use it.
#67
Posted 15 June 2012 - 06:46 AM
#68
Posted 15 June 2012 - 06:47 AM
#69
Posted 15 June 2012 - 06:51 AM
Fast and perfect... thanks man..
#70
Posted 15 June 2012 - 06:52 AM
@P3Droid: Morning, IMO its pointless to keep upgrading your device 209/210/211/etc. not seeing a difference. This thing is ready to drop...
i agree the OTA is close.
#71
#72
Posted 15 June 2012 - 07:19 AM
#73
Posted 15 June 2012 - 07:23 AM
Just saw this asked in another forum and wondered about it. What happens if a previous leak becomes(.210) official and were on.211 will we be able to go back? I'm sure someone would figure it out but I'm just curious.
Just to confirm what others suggested. I was having issues w 210 so i went backwards to 209.
Will sit on 209 and keep an eye on this thread because my issues were 3g related and i know others had the same.
#74
Posted 15 June 2012 - 07:29 AM
#75
Posted 15 June 2012 - 07:30 AM
#76
Posted 15 June 2012 - 07:32 AM
#77
Posted 15 June 2012 - 07:33 AM
#78
Posted 15 June 2012 - 07:37 AM
Sorry if this has been asked before. I am wondering if Titanium Backup can be used on these leaks yet? I remember on .79 it was not compatable, but I'm wondering if this has changed since then. If it still does not work, what do people suggest to use for freezing apps. Thanks!
It works but i use ROM Toolbox Pro
#79
Posted 15 June 2012 - 07:42 AM
Ever dance with the devil in the pale moonlight?
Of Course, Just like this
1 of my all time favs
#80
Posted 15 June 2012 - 07:48 AM
