That file is the correct file. It sounds like you tried to feed it to RSD without unzipping it. You have to first unzip the file, then open RSD and select the file that you got when you unzipped it. If you want Webtop included you should go with Matt's utility though. It has it included. The fastboot files don't.I downloaded a torrent of whats suposed to be .211 lastnight but it says non fastbootable, its zipped as VRZ_XT912_6.7.2-180_DHD-16_M4-31_1FF.xml.zip and I'm hesitant to assume this is the stock .211. If so could some1 confirm so i can move along?
#601
Posted 25 August 2012 - 02:41 PM
#602
Posted 26 August 2012 - 01:36 PM
#603
Posted 26 August 2012 - 01:38 PM
#604
Posted 26 August 2012 - 01:40 PM
#605
Posted 26 August 2012 - 01:41 PM
#606
Posted 26 August 2012 - 01:45 PM
#607
Posted 26 August 2012 - 01:48 PM
#608
Posted 02 September 2012 - 06:44 AM
Mirror uploaded by spc_hicks09:
This mirror is actually the 215 update. It's about 42mb. The 211 update size is 354mb. This had me confused at first. Thanks Matt for everything though.
#609
Posted 06 September 2012 - 09:35 AM
#610
Posted 09 September 2012 - 03:23 PM
I can't find a working download for the 1.81 utility and the files to get to 211. I'm stuck on 84 right now.
Droid Razr torrents are here:
#611
Posted 20 August 2013 - 10:28 AM
I am wondering if anyone can help me with this question.
I have a Razr Hd--Rooted. I have Super SU version 1.45. There is now an update out there for Super SU. Do I need to update ?
Should I update ? I am sure I have updated Super SU in the past with other droid phones But am really not sure.
If anyone can help with these questions I thank you..
Droid Razr H.D- 4.1.2
Thank you to ALL>
