610 replies to this topic
#581 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 23 June 2012 - 04:57 PM
no coming from the stock .181 (gingerBread)
get into Moto Recovery and try to reload update zip again. it may fail a few times before it takes.
#582 theBonVoyage
theBonVoyage
  • 118 posts
  • LocationCharleston, SC
Posted 23 June 2012 - 04:59 PM
Dammit. Does anyone know if autocorrect is possuble fir 211? There's a few things ive noticed that i dont really like about 211. Like you actually have to go into a group hit menu and send message to send a group message instead of just ryping the name of the group in the recipuent field.
#583 theBonVoyage
theBonVoyage
  • 118 posts
Posted 23 June 2012 - 05:07 PM
thanks for your help.
same thing happened again. get the following message:
(status 0)
installation aborted.
any advice on how to proceed?
Just use Razr Utility 1.7 option 1 then flash like normal. I was getting the same exact error and it worked for me.
#584 wyld
wyld
  • 845 posts
Posted 23 June 2012 - 05:09 PM
instead of typing a contacts name to send text type in the group name instead and as far as auto correct here is a screen shot hop that helps ?
#585 wyld
wyld
  • 845 posts
Posted 23 June 2012 - 05:15 PM
Language & input
#586 getdavidt
getdavidt
  • 5 posts
Posted 23 June 2012 - 05:36 PM
thanks much, ran the utility and all is well.
#587 DHA123
DHA123
  • 44 posts
Posted 23 June 2012 - 06:03 PM
Smh..
Told you Matt rules... All hail
#588 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
  • Twitter:@quadjacks
  • LocationFort Drum, NY
  • Current Device(s):Maxx HD
Posted 24 June 2012 - 08:06 AM
Good Morning, what would be the equivalent or steps for/of a hard reset on .211?
#589 theBonVoyage
theBonVoyage
  • 118 posts
Posted 24 June 2012 - 04:42 PM
Language & input
Thanks for the help bro. As far as the group name instead of the individual, it's not working. That's what i was doing on .75 but in .211 it doesn't accept the group name as a valid recipient.
#590 toocool1280
toocool1280
Posted 24 June 2012 - 05:55 PM
need help!!!!!! do everything right,flash 6.12.181,and use unstuck and do number 1 to 6.16.211. and then install zip,gets all the way through and says error cannot load sideload installion aborted. please help
#591 beeryooper
beeryooper
  • 185 posts
  • LocationWisconsin
Posted 25 June 2012 - 05:39 AM
#592 crupp
crupp
  • 51 posts
Posted 25 June 2012 - 09:08 AM
I bought an HD dock but when I plug in my phone I do not see the option for Mirror or Webtop? anyone know why?
#593 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 25 June 2012 - 09:19 AM
Did you get the HDMI cable with it or just the dock? I believe that you have to have it connected to an HDMI input (ie. monitor, TV) before it will work.
#594 crupp
crupp
  • 51 posts
Posted 25 June 2012 - 09:22 AM
I have the dock buy don't have the HDMI connected that may be it. Thanks G8
#595 trex8bears
trex8bears
  • 17 posts
Posted 12 August 2012 - 07:16 PM
download link isnt working. can anyone help? im on .209 and having problems with my screen so i want to upgrade. thanks
#596 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 12 August 2012 - 07:19 PM
You can use Matt's 1.8 utility to flash stock 211.
#597 ryan8r
ryan8r
  • 37 posts
  • Twitter:@ryan8r
  • LocationBeyond the Grave..
Posted 14 August 2012 - 12:18 AM
I have a Verizon RAZR flashed with 211 fw. It shows "Baseband Version" as unknown. Can I Flash this on the already existing fw to see if that may fix it ?!
If anyone has any other suggestions would appreciate it.
Sent from my MB855 using Tapatalk 2
#598 Guest_BDH_*
Guest_BDH_*
Posted 23 August 2012 - 12:43 AM
Mirror: (will always be available)
Will add to the OP as well.
#599 8all3r
8all3r
  • 11 posts
  • Google+:sequoyablanchard@gmail.com
  • Locationcalifornia/florida
Posted 25 August 2012 - 07:29 AM
Hey Friends, I have found myself needing to revert to stock .211 BUT, as far as i know all the .211 links are dead...
I downloaded a torrent of whats suposed to be .211 lastnight but it says non fastbootable, its zipped as VRZ_XT912_6.7.2-180_DHD-16_M4-31_1FF.xml.zip and I'm hesitant to assume this is the stock .211. If so could some1 confirm so i can move along? Im trying to go stock so I can up to .215 and then flash arctic 2.2 as im currently on arctic beta and its become real buggy... i have been draggin through these forums for hours rying to put the pieces together, but among the dead links and strange looking zips i have found I feel like i need a lil push, any1 think they got this?
#600 DHA123
DHA123
  • 44 posts
Posted 25 August 2012 - 07:31 AM
Matts 1.81 utility, option 1. It'll put you where you need to be
