#41
Posted 15 June 2012 - 05:04 AM
#42
Posted 15 June 2012 - 05:29 AM
Pissed because flash still isn't working. Still no 4G/3G toggle.
#43
Posted 15 June 2012 - 05:38 AM
#44
#45
Posted 15 June 2012 - 05:40 AM
A known change right now is that the updater-script deletes the cache from the facebook app while updating...
That was in .210 too.
: @ me just updating to .210 yesterday though.
#46
Posted 15 June 2012 - 05:42 AM
Sent from my koa cm9 razr
#47
#48
Posted 15 June 2012 - 05:47 AM
#49
Posted 15 June 2012 - 05:50 AM
OK, flash is working in Dolphin Browser. Not working in stock browser. At least it works somewhere. Still prefer stock browser, but I'll live.Yup I just checked, flash works on boat browser but not the stock browser, I didn't know what people were talking about when they said flash doesn't work, but it always worked on all the leaks for me because boat browser is my default browser.
Never worked for me on any ICS build with stock browswer.Flash always worked in stock browser... it just doesn't play well with some video sites. Is support worse in this build or something?
#50
Posted 15 June 2012 - 06:02 AM
- Charlizarlslie likes this
#51
#52
Posted 15 June 2012 - 06:06 AM
Just saw this asked in another forum and wondered about it. What happens if a previous leak becomes(.210) official and were on.211 will we be able to go back? I'm sure someone would figure it out but I'm just curious.
I believe if you're on .79 or newer, you can go back to .79 at the oldest. If you are on .75 you can go back to GB.
Someone please let me know if I'm wrong.
#53
Posted 15 June 2012 - 06:08 AM
That's not right. Hold on. I'll correct you in a sec. I need to find the post
#54
Posted 15 June 2012 - 06:09 AM
.75 and .79 can be fastbooted back to a working .181 (GB) state.
Anything past .79 (which would be .206, .208, .209, .210, or .211) can not be downgraded back to .181 (gingerbread), in a workable state -- if the OTA is, lets say .206, and you're on .211, you'd use matts unstuck util, and go back to 206 that way (fastbooting the .181 files, the 206 boot img, then the 206 zip) <-- again, thats just an example, presuming that 206 was the ota (it doens't mean it will be, or any of these leaks will be).
#55
Actually you can go back to gingerbread from .79 as well. Anything > .79 and you're stuck for now.I believe if you're on .79 or newer, you can go back to .79 at the oldest. If you are on .75 you can go back to GB.
#56
Posted 15 June 2012 - 06:10 AM
- etrorteepe likes this
#57
Posted 15 June 2012 - 06:13 AM
#58
Posted 15 June 2012 - 06:14 AM
This is the thread I am referring to. follow these instructions, just use the 211 file?
Edited by mkarps, 15 June 2012 - 06:19 AM.
#59
Posted 15 June 2012 - 06:18 AM
So I am about to try going to 211. I am currently on stock 181 rooted. Haven't installed a leak yet. I'm looking at old threads and new and a little confused on exactly what to do, if I need to go through the rom manager and ES file manager route that was described in the older leak with just replace this file? Or just fastboot and install zip from 211?
I did the Es File & Rom Manager route. Just make sure you are on stock .181. I used Matt's utility to get there then the cache install and it worked fine. I lost root and used the new 4.04 Root utility and everything is great. Make sure you did not install CWM or Safestrap. Stock means fastboot back or RSD and no changes but rooting.
#60
Put the .zip and .crc (the .crc isn't *needed*, but I've become used to putting it on there as well, since it's so small anyhow), on the root of your SD CARD, and flash it through moto recovery. Everyone wants to use the rom manager method, but even matt tells people to sideload with moto recovery, as its, IMHO, the easiest way to get it done.
