610 replies to this topic
#541 Guest_BDH_*
Guest_BDH_*
Posted 22 June 2012 - 09:18 AM
im on 211 so that means when the OTA comes out i can get one it or am i gonna have to use the utility to flash back to 181.. i did the whole process to get to 211 correctly where u flash to 181 then to 211
You're already on the OTA.
#542 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 22 June 2012 - 09:19 AM
Ummm.... You are on the OTA .211. No need to worry anymore. Carry on... :)
Damn you Hicks... Stop ninjaing me. :P
#543 chinkster
chinkster
  • 133 posts
Posted 22 June 2012 - 11:19 AM
does ics have a screen shot method already incorporated in it already or are we still going to have download crappy screenshot apps and shake the damn thing? btw, what screenshot apps are you guys using? if ics doesn't have this in there already its kinda wack that they can't even put this basic simple feature in there.
#544 Mr. Orange 645
Mr. Orange 645
  • 128 posts
  • LocationSW, Missouri
Posted 22 June 2012 - 11:55 AM
Press power and volume down at the same time and hold for a second. Screen will flash and save a screen shot. That's the native screenshot feature.
  • chinkster likes this
#545 chinkster
chinkster
  • 133 posts
Posted 22 June 2012 - 12:05 PM
is this on ICS? dont tell me this has been a hidden feature on GB already!
#546 Memnoch73
  • 5,016 posts
Posted 22 June 2012 - 12:08 PM
ICS feature only
#547 chinkster
chinkster
  • 133 posts
Posted 22 June 2012 - 12:51 PM
ICS feature only
thank you kindly sir
  • Memnoch73 likes this
#548 vbetts
vbetts
Posted 22 June 2012 - 01:46 PM
New guy here yo,
Is there a way to this on a non rooted device without a computer on GB .181? Trying to update our store's Razr unit and don't have a computer ready for this, the stock recovery doesn't see the update as even the default name and update.zip at the root of the sd card.
#549 GlassEyedPete
GlassEyedPete
  • 18 posts
Posted 22 June 2012 - 02:23 PM
where can i find the instructions on how to make one of these motorola factory cables? i dont wanna pay $30 bucks for a freakin cable...
edit: nm googled it. looks a little more complicated than just cut and splice. damn i wish monoprice would sell these for a buck or two lol
Ebay has them for $9.00, which isn't too bad but programming is all they're good for. You can't charge your battery or do regular USB data transfer, just programming.
#550 jakubx80
jakubx80
Posted 22 June 2012 - 02:55 PM
Ok, I'm on 211 leak as well but just got notification that software update is available. Any ideas what is the best way to proceed?
#551 Guest_BDH_*
Guest_BDH_*
Posted 22 June 2012 - 03:06 PM
Proceed to what? Lol. 211?
#552 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 22 June 2012 - 03:10 PM
He's one of the lucky few that will be upgraded early to jelly bean :lol:
#553 beeryooper
beeryooper
  • 185 posts
  • LocationWisconsin
Posted 22 June 2012 - 03:29 PM
common sense tells you that you are already on the ota. you might have gotten a notice that a software upgrade will be available for the razr but you already on the ota and since you are not on 181 you wouldnt get the upgrade. use some common sense
#554 beeryooper
beeryooper
  • 185 posts
  • LocationWisconsin
Posted 22 June 2012 - 03:32 PM
good lord....really? any common sense or....?
#555 habba
habba
  • 35 posts
  • LocationArizona
Posted 22 June 2012 - 04:59 PM
I just checked my wifes phone and no OTA for her yet. is there a new utility for 211 yet ?
#556 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
Posted 22 June 2012 - 05:04 PM
There's this one;
#557 habba
habba
  • 35 posts
  • LocationArizona
Posted 22 June 2012 - 05:06 PM
There's this one;
Great Thank You
#558 thejron
thejron
  • Google+:Jeran Cadorette
Posted 23 June 2012 - 03:51 AM
So just to be clear one cannot flash this over .210 or .209? Fastbooting to .181 then flash boot.img with unstuck utility and finally flash the zip?
#559 Brad92
Brad92
  • 624 posts
  • LocationTexas
Posted 23 June 2012 - 06:09 AM
Yes, you have to do the steps you mentioned to get on .211
#560 mbell75
mbell75
Posted 23 June 2012 - 10:55 AM
You NEED to be on .181 to get the ota, so the only option you have, being on 210 right now, is to use matt's droid razr utility, to fastboot back to .181, then use the unstuck utility for 211, flash the boot211.img via fastboot (with the unstuck tool), and then put the 211 update zip (thats posted in this thread) on your SD card, and apply that from sd card/external storage. The OTA update will ONLY be recognized on a device running .181, NO other build
Thanks. Too much work, I will just stay on .210
