If I'm reading correctly in that horrible small font but I believe they say step 2 OTA to .181
Yep, I edited my post before you replied lol. Still, steps 1 & 2 are not needed.
Posted 21 June 2012 - 12:11 PM
Posted 21 June 2012 - 12:12 PM
Posted 21 June 2012 - 12:13 PM
You don't have to power down to get to fastboot using the Power and volume down button...I have done countless times from my home screen. and you will notice that after I fastbooted back to .173, I updated to .181...in re-reading my post, I am not sure where you are having a problem, I specefically said to release only the power button and the press it again.
Posted 21 June 2012 - 12:17 PM
Since I didn't realize that there were people from the old yahoo chat rooms here, that feel the need to cry about everything and criticize anything, I have made the font bigger and also, the reason that I didn't use Matts Utility that fastboots directly to .181 was that I have heard that some people have had problems using that, so I went from the reliable Utility. I guess that someone trying to help is construed as a problem, so the need to correct a perceived problem exists. I guess that if it helps others, then so be it, I dont have an issue with that. Just make sure you know the reason behind the steps of someone post, before you assume to know everything.Ok, so I just updated to .211 from .75 ICS Leak, this is how I did it and it works perfectly. Download the .211 file from and then put it on your Ext. SD Card.
1. I used DroidRAZRUtility1.51_ICS_COMPATIBLE to fastboot back to .173:
A. Press and hold your power button and the volume down button at the same time, when the
screen flickers with a white bar, release the power button and then
press it again and hold it for a few seconds, release both buttons and you should be in
fastboot mode;
B. Plug your phone into your computer and double click on the DroidRAZRUtility.bat file;
C. Follow the directions to Restore RAZR to 6.12.173;
2. Then use the OTA ( Menu, Settings, About Phone, System Update) to get to .181;
3. Use MotoFail to root phone;
4. Go to the Play Store and install the following apps: ES File Explorer, ROM Manager (free
version), OTA Root Keeper.
5. Run OTA Root keeper, this next step is extremely important if you want to retain root after the
.211 update, after backing up root, click on Temp. un-Root, then click on restore root.
6. Open ES File Explorer, press menu, then settings. Check: up to Root, Root Explorer, Mount File
System.
7. Navigate to your sdcard-ext and find the Blur_Version.6.12.181.XT912.Verizon.en.US.zip file
and copy it to your cache folder in the root directory.
8. Navigate to your cache folder and single click on the blur file, it should ask you which program to open it with, choose ROM Manager, it will ask you if you want to
reboot to recovery, say yes and let it do its thing.
VOILA! You are on the .211 leak. Final thing, open Voodoo OTA and restore root! Worked for me about 15 minutes ago. GOOD LUCK!
Posted 21 June 2012 - 12:20 PM
Wow, so quick to jump on someone. I edited my post right after posting it. Here are the issues:
1. I was stating that steps 1 & 2 are not needed. Simply use the 1.6 Utility to fastboot straight to .181.
2. You do not press the power button again after releasing it. Just let go of it.
When i want to go straight to fast boot, I have had to press the power button again for a few seconds, that is what worked for me, and when I have tried it other ways, not so lucky. I apologize if what I responded was taken as jumping on you, All I was trying to do was give the exact steps that worked for me. If this seems to be a problem for others, I will delete my post, and be content to be a reader.Wow, so quick to jump on someone. I edited my post right after posting it. Here are the issues:
Posted 21 June 2012 - 12:24 PM
Posted 21 June 2012 - 12:30 PM
Posted 21 June 2012 - 12:48 PM
Posted 21 June 2012 - 12:51 PM
Posted 21 June 2012 - 12:55 PM
links are down and im stuck at boot
Posted 21 June 2012 - 02:01 PM
Posted 21 June 2012 - 02:05 PM
Anybody know what to do if stock recovery just gives you a triangle with an "!" when you try to use it?
Posted 21 June 2012 - 02:10 PM
Press both volume buttons at the same time.
Posted 21 June 2012 - 03:07 PM
Posted 21 June 2012 - 03:08 PM
If I'm on .210 can I just flash this or is there more steps I'm missing?
Posted 21 June 2012 - 03:23 PM
Posted 21 June 2012 - 03:37 PM
Sound like a error message from the beginning. How long did it update for?My installation aborted at the end...something about tmp and sideload....is that normal or should I dig up the exact error message?
Posted 21 June 2012 - 03:46 PM
Posted 21 June 2012 - 03:49 PM
Posted 21 June 2012 - 03:54 PM
