#441
Posted 21 June 2012 - 08:39 AM
Oh well, better to be thought of as knowing little, then to be thought of as knowing more then you really do.
#442
Posted 21 June 2012 - 08:40 AM
the link is broken...hmmm
check a few posts above this one, theres a lnk to a mirror (XBOT)
#443
Posted 21 June 2012 - 08:42 AM
I used the unstuck method and flashed 85.img in ap fastboot. Ran matts utility and I'm getting
/system/bin/sh: cannot create /data/local.prop: permission denied
EDIT: My persistent nature paid off
All I did was reflash 85 and follow matts instructions and used his utility for ics root. I now have root access
#444
You said you were coming from .75, right? Did you fastboot BACK to .181 first, let the device restart, etc? Since you were on .75, you would not have needed to use the unstuck util at all (since the 211 update updates from .181, and since you were on .75, you should have been able to get back to .181 w/o an issue).
I suggest fastbooting again, back to .181, and letting your device boot just to make sure it did take .181. After that, try the update again.
Yeah it booted originally. It's booting .181 now for the third time. I'm redownloading the .211 update zip just incase it was a bad download.
#445
Posted 21 June 2012 - 08:44 AM
#446
Posted 21 June 2012 - 08:52 AM
#447
Posted 21 June 2012 - 10:14 AM
-- link to thread
- link to the torrent itself (if you don't know how to use a torrent, then your only option right now is Xbot).
- dropbox link as well -- can't have too many options, right? (the .crc file is there, but is *not* needed if you're applying the update with MOTO STOCK RECOVERY, if you're unsure, download it just to be 100% safe)
#448
Posted 21 June 2012 - 11:02 AM
#449
Posted 21 June 2012 - 11:08 AM
People keep saying that the SOAK will be .211. I was wondering, for the final build of ICS wouldn't Motorola remove the Developer Options from settings?
Nobody knows 100% for sure if 211 will be, and generally the options stay there, since things like USB debugging, etc are there, and options like that are sometimes needed for apps, etc. Not sure what, if anything else they may "need" to remove, if anything.
#450
Posted 21 June 2012 - 11:10 AM
1. I used DroidRAZRUtility1.51_ICS_COMPATIBLE to fastboot back to .173:
A. Press and hold your power button and the volume down button at the same time, when the
screen flickers with a white bar, release the power button and then
press it again and hold it for a few seconds, release both buttons and you should be in
fastboot mode;
B. Plug your phone into your computer and double click on the DroidRAZRUtility.bat file;
C. Follow the directions to Restore RAZR to 6.12.173;
2. Then use the OTA ( Menu, Settings, About Phone, System Update) to get to .181;
3. Use MotoFail to root phone;
4. Go to the Play Store and install the following apps: ES File Explorer, ROM Manager (free
version), OTA Root Keeper.
5. Run OTA Root keeper, this next step is extremely important if you want to retain root after the
.211 update, after backing up root, click on Temp. un-Root, then click on restore root.
6. Open ES File Explorer, press menu, then settings. Check: up to Root, Root Explorer, Mount File
System.
7. Navigate to your sdcard-ext and find the Blur_Version.6.12.181.XT912.Verizon.en.US.zip file
and copy it to your cache folder in the root directory.
8. Navigate to your cache folder and single click on the blur file, it should ask you which program to open it with, choose ROM Manager, it will ask you if you want to
reboot to recovery, say yes and let it do its thing.
VOILA! You are on the .211 leak. Final thing, open Voodoo OTA and restore root! Worked for me about 15 minutes ago. GOOD LUCK!
#451
Posted 21 June 2012 - 11:12 AM
#452
Posted 21 June 2012 - 11:13 AM
Anyone know how to do screen shots from this leak?
vol down+power i believe
#453
Posted 21 June 2012 - 11:18 AM
I tried that, doesn't seem to work, I will start pressing buttons and see what happens, Thanks!vol down+power i believe
#454
Posted 21 June 2012 - 11:20 AM
its definately power down and volume, think you have to do it kinda fast.
#455
Hold vol- and power for like 2 secs. It takes it.
#456
Posted 21 June 2012 - 11:50 AM
#457 Guest_BDH_*
Posted 21 June 2012 - 12:05 PM
Ok, so I just updated to .211 from .75 ICS Leak, this is how I did it and it works perfectly. Download the .211 file from and then put it on your Ext. SD Card.
fastboot mode;
System.
Steps 1 & 2 are not needed. Just download the 1.6 RAZR Utility and fastboot straight to .181. Also, those steps for booting into fastboot mode are not correct. Correct steps are:
1. Power phone off
2. Press and hold power button and vol down at the same time.
3. Screen will flicker, let go of ONLY the power button.
Edited by spc_hicks09, 21 June 2012 - 12:08 PM.
#458
Posted 21 June 2012 - 12:08 PM
1. Power phone off
If I'm reading correctly in that horrible small font but I believe they say step 2 OTA to .181
#459
Posted 21 June 2012 - 12:10 PM
#460
You don't have to power down to get to fastboot using the Power and volume down button...I have done countless times from my home screen. and you will notice that after I fastbooted back to .173, I updated to .181...in re-reading my post, I am not sure where you are having a problem, I specefically said to release only the power button and the press it again.I'm having trouble believing this worked. The .211 leak can only be installed coming from .181. It will not work coming from .173 unless that is a typo that you made. Also, those steps for booting into fastboot mode are not correct. Correct steps are:
1. Power phone off
