610 replies to this topic
#21 justin75
justin75
  • 21 posts
  • Google+:vatriquets@gmail.com
  • LocationVirginia Beach
Posted 15 June 2012 - 03:45 AM
Wow! Bro you ARE the man!
Btw, for the couple of u that questioned me yesterday about how i got the overclock zip to work on 210 (and 209 AND 208 AND 206) .... before you hate yhe playa, try it n get in the game first....i mean seriously. It DOES work! And footballwhateveryournamewas, u asked how i did it, wen i clearly put down the steps i took to get it to work, um.....(repeating what i just wrote would be redundant and, ah, as silly as ur question. Sorry, a spade is a spade..)
Sent from my Apple Slicin Razr
#22 justin75
justin75
  • 21 posts
Posted 15 June 2012 - 03:49 AM
Ever dance with the devil in the pale moonlight?
I ask that of all my prey. .
( great line! )
#23 zoo16
zoo16
  • 29 posts
  • LocationColumbus, OH
Posted 15 June 2012 - 03:50 AM
Can these really be called "leaks" anymore? I mean, when they're coming out this fast I think it's called a "flood".
  • zephyrus14 and kingkylet like this
#24 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 15 June 2012 - 03:52 AM
So I woke up this morning clearly leaning to go from 181 to 210. I was in the process of finding the best download links, when THIS popped up. Good golly, now what to do!
There is NOTHING wrong with my 181/Eclipse, 50 hours battery, kick-rear end data, powerful signal, flash enabled device. Yet, the call of the sandwich still haunts my dreams.....
  • Burbank likes this
Proud father of a US Marine
#25 huger82
huger82
  • 38 posts
Posted 15 June 2012 - 03:55 AM
So i got to excited to flash that i forgot to put the update on my sd card before I fastboated back to .181 is there anyway to get the file on my sd card now besides buying a micro sd adapter?
#26 boxermansr
boxermansr
  • 133 posts
  • LocationEl Paso, TX
Posted 15 June 2012 - 04:00 AM
Short of borrowing one otherwise, I don't think that there is.
#27 vaderyeh
vaderyeh
  • 35 posts
Do you have another phone with a micro usb port
#28 fbm111
fbm111
  • 56 posts
  • Twitter:fbm111
No adapter or spare phone will work.
#29 benefit14snake
benefit14snake
  • 232 posts
Posted 15 June 2012 - 04:08 AM
Is rombot down? None of the links are working for me....
Thanks for the leak matt!
#30 jb_alphamale
jb_alphamale
  • 251 posts
Posted 15 June 2012 - 04:10 AM
Rombot not working at this hour but yours works great. Thanks man.
6.16.211 Mirror on XBot.
Enjoy.
X
#31 benefit14snake
benefit14snake
  • 232 posts
Posted 15 June 2012 - 04:12 AM
Awesome, xbot worked. Are the other files hosted there as well?
EDIT: read other thread =P
#32 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
  • Twitter:xlightwaverx
  • LocationEast Coast
  • Current Device(s):XT912, Kindle Fire HD
Posted 15 June 2012 - 04:15 AM
  • benefit14snake and mdowns989 like this
#33 TweakedSystems
TweakedSystems
  • 122 posts
Posted 15 June 2012 - 04:25 AM
Ok I am ready to go from .210 up to .211 ... Before I screw up like I did on my last update....
What is the best method to this.
Can I use ES Explorer? by copying the zip to cache and installing it this way,then use the unstuck .210 to root?
Thx in advance...
#34 yuri2008112073
yuri2008112073
What's new in this version?
#35 benefit14snake
benefit14snake
  • 232 posts
Posted 15 June 2012 - 04:35 AM
hmm.. ive done this before and didnt have any problems. Trying to use the unstuck it says file path not specified. I am refastbooting to 181.
#36 fosser2
fosser2
  • 55 posts
Posted 15 June 2012 - 04:39 AM
Go figure... as soon as I make the 210 jump :P
#37 DriveEuro
DriveEuro
  • 68 posts
Posted 15 June 2012 - 04:48 AM
Flashing to 211 now with the .20x to .210 update procedure found here.
  • sithmasteryoda likes this
#38 iDroidGuy
iDroidGuy
    :D Taco!
  • 650 posts
  • Twitter:iDroidGuy
  • Google+:Stephen Wilmot-Doxey
  • LocationHopewell, VA
Posted 15 June 2012 - 04:51 AM
Same as you lol
If you'd like to buy me a Mountain Dew just PM me for my PayPal info. Thanks :)
#39 jb_alphamale
jb_alphamale
  • 251 posts
Posted 15 June 2012 - 04:52 AM
Man, check this thread out.
Copy the 211 image instead of 210 from the unstuck211.
Change the modified bat file (rename the 210 where you find it into 211).
Run the bat and follow instructions from the OP.
I did it and it worked great without losing any data.
Thx in advance...
#40 jb_alphamale
jb_alphamale
  • 251 posts
Posted 15 June 2012 - 04:53 AM
As I've read Matt is going to release a new version of his utility including this partial restore and the new root method for 404. I do suppose that this is going to work for any leak from now on for 404 kernel.Yupiiii!!!
