#361
Posted 19 June 2012 - 05:30 AM
#362
Posted 19 June 2012 - 06:09 AM
#363
Posted 19 June 2012 - 06:20 AM
#364
Posted 19 June 2012 - 06:21 AM
Why is the update zip linking to a file named Blur_Version.6.12.181.XT912.Verizon.en.US.zip?
It actually tells the version you are "coming from" and given that the ota will be flashed from .181 it is named accordingly.
#365
Posted 19 June 2012 - 06:39 AM
#366
Posted 19 June 2012 - 06:46 AM
Yeah that good if your wifi.I just wanted to share this screenshot. 211 has provided me with the best battery life my Razr (not maxx) has ever seen. I talked for over an hr on the phone and was on 4G most of the day (moderate usage). I love this leak and can't wait for the OTA. For all of those who haven't figured it out yet, vol- and power for a few seconds takes a screenshot.
#367
Posted 19 June 2012 - 06:57 AM
I believe some people reported browser wasn't working in the stock browser (and of course it was never supported in Chrome), but its working in Dolphin HD and a couple others that support flash.
I don't miss flash, because I use Chrome as my default browser, but if you have to have it, Dolphin HD is a really good alternative browser.
I couldn't get dolphin's flash to work either. So if I use chrome I won't need flash support? Is that what you're saying?
#368
Posted 19 June 2012 - 07:13 AM
I believe what he's saying is that Chrome doesn't support Flash at all on Android, so he doesn't have a choice and doesn't miss it. As far as flash support, the default browser does work on some sites, doesn't work on others, not sure why.
#369
Posted 19 June 2012 - 07:14 AM
If my wifi what?
#370
Posted 19 June 2012 - 07:17 AM
First I put the file in sdcard and that failed, so then I went back an put the zip in the \cache folder, went through ROM manager and voila! It flashed pretty quickly and seems to be running smooth.so far.
Thanks Matt and everyone else!
#371
Posted 19 June 2012 - 08:32 AM
#372
Posted 19 June 2012 - 08:37 AM
No you need to go back to ginger break.can this be flashed on top of the .75 leak without going back to GB ??
#373
Posted 19 June 2012 - 09:00 AM
^^^^^This
#374
Posted 19 June 2012 - 01:11 PM
^^^^^This
Stupid question to ask, but doesn't chrome come with a built in flash player? Will have to look that up sometime after yard work.
#375
Posted 19 June 2012 - 03:18 PM
i believe chrome uses html5 which is better than flash but not supoorted by alot of websites. someone correct me if im wrongStupid question to ask, but doesn't chrome come with a built in flash player? Will have to look that up sometime after yard work.
#376
Posted 19 June 2012 - 03:24 PM
#377
Posted 19 June 2012 - 03:33 PM
I am on stock 181 rooted using moto recovery wipe and delete install from sd install zip update.
wont reboot after this must fastboot back to 181 to get it up and running again.
#378
Posted 19 June 2012 - 03:38 PM
this one not flashing easy like the 79, keep getting abort install after it gets 3/4 of the way through flash.
If you are coming from stock .181 try the Rom Manager method using ES file mamager. Might be alot easier for you?
#379
Posted 19 June 2012 - 03:41 PM
ok thanks, not really sure how to do it that way?
#380
