Don't take your hacked, rooted, ics leak installed phone back to verizon. if you believe you will be taking it back, don't install these until an ota. and honestly reception is not something that is easily anwsered, just like battery life. every phone is different, every area in the world is different. simply asking how reception is....is way too vague. I live in farm country and don't get much signal. if you live in chicago than you'll probably get good reception. if by reception you mean how decent is the signal.....most people don't have issues with it. but everyone is different.Gotcha. So two more questions then
-I had some data reception issues and had to get a replacement phone. Were that the case with this phone, would I be screwed till an OTA did come out or would Verizon not notice that I'm exchanging an ICS'd phone you think?
-How has reception been?
#341
Posted 18 June 2012 - 05:59 PM
#342
Posted 18 June 2012 - 06:13 PM
#343
Posted 18 June 2012 - 06:20 PM
After first boot into recovery the android guy will appear to install something. after that, you have to power off the phone, reboot into recovery and you should get the android guy with a red exclamation point. you are getting that error because the sd card hasn't been remounted.
Still didn't work. :/
#344
Posted 18 June 2012 - 06:21 PM
#345
Posted 18 June 2012 - 06:23 PM
Can someone please give me an answer as to why the home button doesn't work? Tried restarting a few times with no luck. Should I go through the whole process again, or is there a simple fix that I'm missing? Also, the lockscreen is not working.
What launcher are you using and when did it start?
#346
Posted 18 June 2012 - 06:29 PM
#347
Posted 18 June 2012 - 06:41 PM
Using stock launcher, and it wasn't working on first boot. Same for lockscreen
#348
Posted 18 June 2012 - 07:04 PM
#349
Posted 18 June 2012 - 07:06 PM
MIUI is already available for ICS leaks
Thanks bro!! All leaks? Including 211??!!
#350
Posted 18 June 2012 - 07:47 PM
#351
Posted 18 June 2012 - 08:12 PM
Dumb question... Is flash player working on this? I'm on 210 and I'm having trouble getting flash to work, which of course means no Southpark!
Yeah it does
Sent from my .211 leak razr
#352
Posted 18 June 2012 - 08:50 PM
#353
Posted 18 June 2012 - 09:12 PM
I don't miss flash, because I use Chrome as my default browser, but if you have to have it, Dolphin HD is a really good alternative browser.
- TrueBlueWitt likes this
#354
Posted 18 June 2012 - 09:33 PM
Step 1. Dl 211
Step 2. Fastboot 181.
Step 3. Fastboot the 11 kernel using Unstuck 211
Step 4. Boot into recovery.
Step 5. Flash 211 from external sd card
Step 6. Boot up and enable usb debugging
Step 7. Boot into ap fastboot mode
Step 8 flash 85 kernel using Unstuck 211
Step 9 boot using bp tools
Step 10 use ics root using Matts utility 1.6
Step 11 flash 211 kernel using Unstuck 211
Step 12 profit
QFT
Hicks, just wanted to let you know this worked like a charm. Thanks, this was my first time coming from a non-fastbootable leak to a newer leak and it went flawlessly.
You, Matt, and all the others here who make all this possible are truly appreciated. Glad to support such a great community! Stay safe.
#355 Guest_BDH_*
Posted 18 June 2012 - 09:44 PM
QFT
You're very welcome! Happy to help and happy to serve!
#356
Posted 19 June 2012 - 03:41 AM
"No trees were killed to send this message, but a large number of electrons were terribly inconvenienced" -- Dr. Neil deGrasse Tyson
#357
Posted 19 June 2012 - 04:02 AM
#358
Posted 19 June 2012 - 04:38 AM
#359
Posted 19 June 2012 - 04:45 AM
The newer leaks have a global option but I haven't seen much on how great it works. I think it depends on your sim card and whatnot. but the global option is there.I am leaving for Europe this weekend, and I was wondering if I should update to 4.0.4 and will it work there, or should I just switch back to my droid 2 global to be safe?
#360
Posted 19 June 2012 - 04:50 AM
For those that use the moto car dock...does it automatically launch VZW navigator as soon as you dock it on this build? I don't recall it doing that on .210, but it does it on .211 and I can't find anywhere to turn it off! No dock smart actions setup, and google navigation is the default.
its a bug in the last update from the verizon navigator, just uninstall the last update and problem solved. you can also disable the app so the play store wont bug you about updating it.
- PsyberEMT likes this
