#281 Guest_cpuman_*
Posted 17 June 2012 - 10:43 AM
From .181 to .211
-Added 2 files (.211 and other file)to SD card in the cache
-Use root keeper to keep root
-Rom manager selected the 4.04
-It installed by itself in 5 mins and rebooted and I had 4.04 on my device
-Rerooted my device using root keeper
Now I have 4.04 on my device within 5 min!!!!!!
#282
Posted 17 June 2012 - 12:00 PM
Hey I dont get why some of you are going through so much trouble to install this. All I did was this
From .181 to .211
It is a more difficult process coming from another ICS leak. Not quite that simple. But yes, coming from 181 is pretty easy.
- danrzr333 likes this
#283
Posted 17 June 2012 - 12:31 PM
Understatement... not even close as coming from another leak.. only trouble I ran into was going from 209 to 210.. all the rest has been easy enough.. also SINCE 210 my gallery on any custom rom was having issues reading media from SD ext... I finally wiped both internal and external... seems to have fixed it for the most part..It is a more difficult process coming from another ICS leak. Not quite that simple. But yes, coming from 181 is pretty easy. Sent from my DROID RAZR using Tapatalk 2
#284
Posted 17 June 2012 - 02:40 PM
From .181 to .211
I was coming from 181, but rootkeeper didn't work for me. I had to use Matt's utility and unstuck bat files to get rooted.
This is my first ICS leak. Nicely done, Moto. Even more gratitude to Matt for his amazing stuff, and to everyone else who helps and supports.
#285
Posted 17 June 2012 - 02:49 PM
#286
Posted 17 June 2012 - 03:04 PM
#287
Posted 17 June 2012 - 03:07 PM
Has anyone found any roms that will work on 211 without causing major data issues. I have flashed a bunch of roms since upgrading to 211. I have data issues on every single one. It gets to the point that not very long after flashing roms, I can't get 3g or 4g. I have tried all the toggle methods, wiping Cache, Dalvik..etc...Any more suggestions? I think the leak is good. I have absolutely no data issues on stock 211.
Once ROMs are built using the stock one as a base we will have them wo issues.
#288
Posted 17 June 2012 - 03:15 PM
Stock works great for me. I'm taking a hiatus from custom roms until we get a fix for data. Even when I manage to get good data on a custom rom (all of them) it's temporary at best.
With the flashable 211 stock rom that hashcode released, I can customize stock while maintaining a strong data connection.
#289
Posted 17 June 2012 - 07:15 PM
From .181 to .211
Yeah, I pretty did that coming from .79 to .206, but for some reason it would not work going from .206 to .211, but I figured it out.
#290
Posted 17 June 2012 - 07:17 PM
Yeah, I had Axiom prior to the leaks, and it was awesome, except the data connection would suddenly go away - you have a link for that hashcode ROM?Stock works great for me. I'm taking a hiatus from custom roms until we get a fix for data. Even when I manage to get good data on a custom rom (all of them) it's temporary at best.
#291
Posted 17 June 2012 - 08:36 PM
#292
Posted 17 June 2012 - 08:57 PM
...into .211 from .209 - Didn't have to start from scratch like before.
#293
Posted 17 June 2012 - 09:11 PM
#294
Posted 17 June 2012 - 09:18 PM
Sent from my XT912
#295
Posted 18 June 2012 - 01:29 AM
iKReaM.ICS.2.11.THEME.UPDATE-R3Ds
R3Ds Themes
How do I put this in my phone? Just wipe cache from boot strap?
#296
Posted 18 June 2012 - 04:19 AM
A lot of you people on GB and the fastbootable leaks are gonna be in for a surprise when you take the OTA and still can't go back to GB lol.
Only if they don't have a brain on there shoulders.....lol. Once you OTA to a new version of Android you can Never flash back to a prior version.
#297
Posted 18 June 2012 - 05:22 AM
Download ,nandroid, put it on your sd card, in bs or ss wipe cache and dalvik and flash then reboot!!!How do I put this in my phone? Just wipe cache from boot strap?
#298
Posted 18 June 2012 - 06:03 AM
#299
Posted 18 June 2012 - 06:15 AM
Sure would love to see some MIUI for this ROM! Love this leak!!! thanks to all devs and their help!
MIUI is already available for ICS leaks
#300
Posted 18 June 2012 - 06:45 AM
