#261
Posted 16 June 2012 - 06:35 PM
#262
Posted 16 June 2012 - 06:38 PM
#263
Posted 16 June 2012 - 06:43 PM
#264
Posted 16 June 2012 - 06:45 PM
im hearing on xda there was yet another leak found.
You better be joking
#265
Posted 16 June 2012 - 07:50 PM
#266
Posted 16 June 2012 - 09:24 PM
You know the drill.
No liability blah blah.
Fastboot the 6.12.181 files using the restore option 1 in my
(Optional. Do this if you were on another stuck ICS leak) Fastboot the 6.16.211 boot.img using the option in the
Go to Motorola Recovery (next to AP Fastboot mode option) and wipe data(recommended), then install zip from SD card and install
A known change right now is that the updater-script deletes the cache from the facebook app while updating...
Help with rooting:
Use the unstuck utility 211 to flash the 6.14.85 (4.0.3) boot.img onto the phone via AP Fastboot mode.
Boot the phone with BP Tools mode (in the same menu as AP Fastboot is located)
Run the ICS root from the Droid Razr Utility 1.6. (note: it may appear 'stuck' during step 2 but ignore it and carry on)
Go back to AP Fastboot and run the unstuck utility 211 again but this time reflash the 6.16.211 boot.img
Profit
Hey matt. Quick question, in your utility, is is normal for it to get stuck for about 10 minutes in-between preinstall and webtop?
#267
Posted 16 June 2012 - 10:05 PM
Its normal if you have low RAM available on your PC.
#268
Posted 17 June 2012 - 01:30 AM
Whoop Whoop! Finally, thanks for all the help. Lesson learned if you're gonna flash via /cache method... don't open rom manager or it won't flash. It will only reboot when you try. Well at least for me It wouldn't. Had no reason to open it anyways, just habit.
I'm having the same problem you had with the preinstall, how did you manage to fix it exactly?
#269
Posted 17 June 2012 - 03:43 AM
#270
Posted 17 June 2012 - 04:19 AM
So, the problem was the sdcard install? Glad you finally got it.
Sent from my RAZR MAXX using Tapatalk 2
#271
Posted 17 June 2012 - 06:37 AM
I have 2gb of ram and mine freezes. What I found out was once the utility freezes I just power off my phone and continue to flash the kernel then the rom. I have to reboot my laptop too. I have done this for the last 4 leaks and it works for me. Ymmv. I'm sure its not recommended but clearly enough files get writtenHey matt. Quick question, in your utility, is is normal for it to get stuck for about 10 minutes in-between preinstall and webtop?
#272
Posted 17 June 2012 - 06:50 AM
#273
Posted 17 June 2012 - 07:39 AM
i think it was debunked but someone on xda last night claimed there was a new build.
#274
Posted 17 June 2012 - 07:53 AM
It gets to verifying current system...
assert failed: apply_patch_check ("MTD:boot:8388608:8e21cfa5d9be4dd08427b079fbff9a80d6e04560:8388608:46b1d867743b54db403dc2cd67a124cbd2b2173
E:\Error in /tmp/sideload/package.zip
(Status 7)
Installation aborted.
Thinking bad download, any other inputs?
#275
Posted 17 June 2012 - 07:56 AM
Got a error message. Will attempt to type this all down.
(Status 7)
I got that 4 times in a row before it finally took.
#276
Posted 17 June 2012 - 08:14 AM
Lol I'm working on 10
#277
Posted 17 June 2012 - 08:27 AM
assert failed: mount(ext3", "MTD", "SYSTEM". "/system")
(status 7)
#278
Posted 17 June 2012 - 08:38 AM
#279
#280
Posted 17 June 2012 - 08:54 AM
(Status 7)
I had the same problems, too. Just go here and follow the instructions to get to .211.
