610 replies to this topic
#221 Guest_BDH_*
Guest_BDH_*
Posted 16 June 2012 - 01:58 PM
Anyone ready for KOA Blur? Debloated, 1% Mod, tweaked Stock .211 ROM.
Will be needing some testers. PM me.
#222 mdowns989
mdowns989
  • 211 posts
  • Twitter:@mdowns989
  • Google+:+Michael Downs
  • LocationCentral Coast Cali.
Posted 16 June 2012 - 01:59 PM
After moto it will put u back in fastboot, for roms are you using safeboot system on? And are the roms you trying to use are 211 based?
R3Ds Themes
Yeah SS enabled and the roms are 'leak' based not necessarily 211 based
Sent from my DROID RAZR
#223 jimyv
jimyv
  • 248 posts
I grabbed 1.6 final that was on unbrick 84 85 fastboot fail thread
Sharing da buzz on my crackflashed rzr jimyv
#224 Mad Cutter
Mad Cutter
  • 30 posts
Posted 16 June 2012 - 02:01 PM
181 will boot after i flash so I figured it was a good download and showed no errors during fastboot.
Yes I flashed 211 kernel. wiped data/cache. Something is corrupt just can't figure out what. And yes fully extracted utility.
#225 stkiswr
stkiswr
  • 106 posts
can't pm your inbox is full lol. I would be interested in testing if possible
#226 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 02:02 PM
Hicks ur box is full man
#227 bilbobaggins
bilbobaggins
  • 124 posts
Posted 16 June 2012 - 02:03 PM
iKReaM.ICS.2.11.THEME.UPDATE-R3Ds
R3Ds Themes
What's the procedure to install it? I had a problem with themes in the past. I have no desire to brick my phone.
Thanks.
#228 mdowns989
mdowns989
  • 211 posts
Posted 16 June 2012 - 02:05 PM
PM box full but I'm down for some blur...
#229 Guest_BDH_*
Guest_BDH_*
Posted 16 June 2012 - 02:10 PM
Inbox cleared out lol, sorry about that!
#230 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 02:11 PM
yes please
#231 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 16 June 2012 - 02:12 PM
Hmm, if .181 will boot after flashing then you don't need to flash the .211 kernel, or maybe I'm misunderstanding. I haven't read all of your posts. I do know of another person that had issues getting .211 to flash due to status 7 errors on preinstall. I suggested he flash .173 then .181 in succession and it worked for him. He was coming from .209 I believe.
#232 networkdood
networkdood
  • 52 posts
  • Twitter:networkdood
  • LocationOver there
Iv'e went from ,84,.208,.209,.210 now installing .211 this is the 1st time i came across assert failed status code 7 ! lol tried 4 times before it finally took. lol
This is what I get, and I am flashing from .206 - what did you do to push it through?
I love it when a plan comes together...
#233 stkiswr
stkiswr
  • 106 posts
its prob about to fill back up haha
#234 networkdood
networkdood
  • 52 posts
Posted 16 June 2012 - 02:15 PM
Step 1. Dl 211
Step 2. Fastboot 181.
Step 3. Fastboot the 11 kernel using Unstuck 211
Step 4. Boot into recovery.
Step 5. Flash 211 from external sd card
Step 6. Boot up and enable usb debugging
Step 7. Boot into ap fastboot mode
Step 8 flash 85 kernel using Unstuck 211
Step 9 boot using bp tools
Step 10 use ics root using Matts utility 1.6
Step 11 flash 211 kernel using Unstuck 211
Step 12 profit
So, even though I am on .306, I should still Fastboot .181?
#235 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 02:18 PM
yes u must follow this
#236 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 02:19 PM
and you meant 206 right?
#237 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 16 June 2012 - 02:23 PM
Our you could use this
I put it all together in one package. With the new 4.,0,4 root method there is no real need to flash the .85 kernel unless you have issues.
Your call.
  • mugsy77 likes this
#238 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 02:26 PM
Your call.
well yea lol
#239 porkshanker
porkshanker
  • 57 posts
Posted 16 June 2012 - 02:28 PM
I have been on this build for about 12 hours - I have actually lost cell signal multiple times anyone else seeing radio issues? Alot of 3/4 G switching which is nothing new in my area.
#240 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 02:36 PM
yes me 2
