610 replies to this topic
#201 Mad Cutter
Mad Cutter
  • 30 posts
Posted 16 June 2012 - 11:59 AM
Step 1. Dl 211
Step 2. Fastboot 181.
Step 3. Fastboot the 11 kernel using Unstuck 211
Step 4. Boot into recovery.
Step 5. Flash 211 from external sd card
Step 6. Boot up and enable usb debugging
Step 7. Boot into ap fastboot mode
Step 8 flash 85 kernel using Unstuck 211
Step 9 boot using bp tools
Step 10 use ics root using Matts utility 1.6
Step 11 flash 211 kernel using Unstuck 211
Step 12 profit
Ive tried this about 6 times now following these instructions. I came from .79. Fastboot back to 181, fastboot the 211 kernel with unstuck, boot moto recovery, then flash 211 update from ext.sd, and every time it aborts with the same error "/tmp/sideload/package/zip (status 0). Then I get to start all over at step 1.
WTF am i doing wrong. Ive redownloaded files several times and checked md5 against each other theyre the same so shouldn't be a bad download. Any help would be greatly appreciated. This is the first time i've ever had a problem flashing anything. So I'm very frustrated.
#202 Majormer
Majormer
    Call me Big Papa..
  • Validating
  • 41 posts
  • Twitter:@MajormerWizard
  • LocationKansas City, MO
Posted 16 June 2012 - 12:00 PM
Only change from 210 is in the setup guide. It added a gmail picture to the email configuration step suggesting that you set up gmail later. This explains the 200kb difference in file size from 210
#203 mdowns989
mdowns989
  • 211 posts
  • Twitter:@mdowns989
  • Google+:+Michael Downs
  • LocationCentral Coast Cali.
Posted 16 June 2012 - 12:40 PM
Ive tried this about 6 times now following these instructions. I came from .79. Fastboot back to 181, fastboot the 211 kernel with unstuck, boot moto recovery, then flash 211 update from ext.sd, and every time it aborts with the same error "/tmp/sideload/package/zip (status 0). Then start all over at step 1.
between steps 2&3 are you waiting for Andy to INSTALL the 181? also after flashing 211 kernel but BEFORE flashing update wipe data through recovery
#204 Mad Cutter
Mad Cutter
  • 30 posts
Posted 16 June 2012 - 12:57 PM
Yes and yes. But one question. Do i need to let 181 boot all the way up after andy install then reboot to recovery? Or catch it before bootup and go to recovery? Or does it matter? Ive been letting it boot up then shut down then to recovery.
#205 mdowns989
mdowns989
  • 211 posts
Posted 16 June 2012 - 12:59 PM
181 will not boot... Andy will install files and it will reboot ant stay on M then force reboot into recovery
#206 Guest_R3Ds_*
Guest_R3Ds_*
Posted 16 June 2012 - 01:05 PM
any themes for this bad boy
I have a stock theme update to fix a lot of the mismatch colors and dsp manager.
R3Ds Themes
#207 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 16 June 2012 - 01:06 PM
I've been getting a few FC's on .211 on a numder of apps TapaTalk, My Cast Weather, and a few others can't remember at the moment. Seems to be random though.
  • doggy2965 likes this
#208 Guest_R3Ds_*
Guest_R3Ds_*
Posted 16 June 2012 - 01:07 PM
181 will not boot... Andy will install files and it will reboot ant stay on M then force reboot into recovery<br />
Dont force it, it takes a while on the reboot after andy finish. Then flash the 211 unstuck and boot to recovery. Wipe data then install zip
#209 mdowns989
mdowns989
  • 211 posts
Posted 16 June 2012 - 01:20 PM
When I wrote that it was in response to someone else asking for help.. I thought 181 would NOT boot after fastbooting it... wonder if this is somehow responsible for roms acting up with my SD card... I always force rebooted after 181 fastboot then installed new kernel.. hmm...
My stock 211 runs perfect.. ROMS will not diplay pics from my Ext SD card and Camera will NOT work... tried everything man... still looking for help on this matter... nothing has worked.. gonna try going back to 209 base tonight..
#210 Guest_R3Ds_*
Guest_R3Ds_*
Posted 16 June 2012 - 01:23 PM
iKReaM.ICS.2.11.THEME.UPDATE-R3Ds
R3Ds Themes
  • bilbobaggins likes this
#211 Guest_R3Ds_*
Guest_R3Ds_*
Posted 16 June 2012 - 01:32 PM
After moto it will put u back in fastboot, for roms are you using safeboot system on? And are the roms you trying to use are 211 based?
R3Ds Themes
#212 Mad Cutter
Mad Cutter
  • 30 posts
Posted 16 June 2012 - 01:37 PM
ok It keeps aborting when it gets to "Patching preInstall files" Any clue why?
#213 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 01:42 PM
factory reset and clear cache from recovery?
Sharing da buzz on my crackflashed rzr jimyv
#214 Mad Cutter
Mad Cutter
  • 30 posts
Posted 16 June 2012 - 01:44 PM
i have over and over. Still no go. Thank god I have a MAXX! LOL!
#215 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 01:45 PM
Reflash 181 got messed up preinstall folder somhow
#216 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 01:47 PM
boot and safestrap will cause this also
#217 Mad Cutter
Mad Cutter
  • 30 posts
Posted 16 June 2012 - 01:51 PM
I have fastbooted 181 in between every try. This Is retarded. Think i got a bad download of matts utility?
#218 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 01:52 PM
And flashed 211 kernel?
#219 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 01:54 PM
Not sure u are getting a good preinstall flash does it error there when running restore 181 option?
#220 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 01:56 PM
Have to be fully extracted utility that is.. and yes there are corrupted copies out there
