610 replies to this topic
#181 wrich73
wrich73
  • 41 posts
  • Google+:wrich73
Posted 16 June 2012 - 06:14 AM
No im using safetrap 2.0
Disable safe mode..If safestrap is installed but safemode isn't on, you can upgrade just fine, but its always best to uninstall it.
You probably need to do a fresh install from scratch...Use 1.6 tool, then the unstuck method.
On your /mnt/sdcard there is a folder called "safestrap" open that folder up and there are 2 more folders, "orig" and "safe" Copy the contents of the "safe" folder to your external SD card. You don't really have to do this, as rolling back to 181 doesn't wipe your internal SD card, but its better to be safe than sorry.
Do the full method to upgrade your phone to 211, make sure everything works, then verify that your internal SD card is intact, if so go into the safestrap folder (NOT the folder on your sdcard-ext) open the sub folder called "orig" and delete the file, verify contents in the "safe" folder.
Install safestrap, launch it, enable safemode and it will backup the image of your working 211 and restore whatever ROM you had running safe side with all data, etc.
I have been switching between KOA and .2xx so often to keep them both updated I am not even bother to use normal backup anymore (well, I make 1 bootstrap every week or so, since I am kinda paranoid :huh: )
  • crpp2401 likes this
#182 joshuahist
joshuahist
  • 61 posts
  • Twitter:joshuahist
  • Google+:joshuahist
  • LocationPhiladelphia Pa
Posted 16 June 2012 - 06:22 AM
Holy cow, that was painful. Finally got root after many, many, many... attempts. Thanks everyone that helped me through this.
By the way I thought we were suppose to have banners if we are donating members. How do I go about getting a banner? I did donate.
I donated too, but I have no idea how that works.
#183 stkiswr
stkiswr
  • 106 posts
Posted 16 June 2012 - 06:23 AM
any screen shots?
screens of moto ics or aokp or about phone ;-)
#184 spike g
spike g
  • 30 posts
Posted 16 June 2012 - 06:25 AM
moto ics but i'll take them all :)
#185 stkiswr
stkiswr
  • 106 posts
Posted 16 June 2012 - 06:28 AM
I d;not want to easyperson the thread up but with theme engine things get niiice
#186 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 16 June 2012 - 06:41 AM
Iv'e went from ,84,.208,.209,.210 now installing .211 this is the 1st time i came across assert failed status code 7 ! lol tried 4 times before it finally took. lol
#187 stkiswr
stkiswr
  • 106 posts
Posted 16 June 2012 - 06:53 AM
assert 7 here too. I had to wipe data. Turn off. Reboot to 3e recovery and it took first try
#188 fixxxer2012
fixxxer2012
  • 262 posts
Posted 16 June 2012 - 07:11 AM
just installed .211 and thats where im staying until we get the ota.
#189 master0fursinz
master0fursinz
  • 24 posts
  • LocationNYC
Posted 16 June 2012 - 08:43 AM
god it was only a few days ago i got 210 on, dont like it too much though, browser is laggy with me, i liked 206 browser better, it was much smoother. well time to take another crack at updating, just think by the end of the month we will probably be at 220 with the way they are refreshing it.
Thank goodness for Devs, cracks, and leaks.
#190 Guest_R3Ds_*
Guest_R3Ds_*
Posted 16 June 2012 - 08:56 AM
So you dont want this 212 ;) j/k.
Btw shootme works for screenshots. Just restore or sideload the apk.
R3Ds Themes
#191 wyld
wyld
  • 845 posts
Posted 16 June 2012 - 08:58 AM
At least there working on it! Getting it all nice and shiny as possible for whenever they release it?????? LoL
#192 mdowns989
mdowns989
  • 211 posts
  • Twitter:@mdowns989
  • Google+:+Michael Downs
  • LocationCentral Coast Cali.
Posted 16 June 2012 - 09:36 AM
I have a problem... it started with the 210 leak.. I now have 211 installed... it runs GREAT as long as I stay stock..Anytime I install a ROM it seems that the gallery has serious issues reading from my ext. SD card.. it will not populate my pics,videos etc.. and will not sync my google photos either.. if I remove SD card it syncs google photos perfectly.. and yes... I've cleared data.. cache... everything... nothing seems to help... anyone else have this happen? Its driving me nuts.. moreso since stock works just fine so its NOT a bad reader... any ideas are most appreciated..
Edit: I also notice that my camera will not work on any custom roms after 210/211..
Any ideas?
#193 dfcisneros
dfcisneros
  • 11 posts
Posted 16 June 2012 - 10:27 AM
Anybody on .211 have problems with ROMtoolbox pro not saving sysctl config setting after reboot?
This is a stock ROM with stock Kernel. Using sysctl.conf tweaks require a custom kernel that is why your values will not save.
#194 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 16 June 2012 - 10:52 AM
R3Ds Themes
any themes for this bad boy :)
#195 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 11:24 AM
ics has built in screenshot
Sharing da buzz on my crackflashed rzr jimyv
#196 Zeklandia
Zeklandia
    Developer
  • 75 posts
  • Twitter:@Zeklandia
  • Google+:+Asher Wood
  • LocationThe Internet
Posted 16 June 2012 - 11:25 AM
How use this???
Asher Wood
Linux, Android, Java, C/C++ Developer.
Google+ | Github
#197 jimyv
jimyv
  • 248 posts
Posted 16 June 2012 - 11:26 AM
How use this???
just hit pwer and v- for a sec
#198 networkdood
networkdood
  • 52 posts
  • Twitter:networkdood
  • LocationOver there
Posted 16 June 2012 - 11:34 AM
Huh, I am on .206, and when I install .211 from external SD, I get:
assert failed: mount("ext3", "MTD", "system", "/system")
E: Error in /tmp/sideload/package.zip (Status 7) Installation aborted.
I already installed the .211 kernel using unstuck program.
I love it when a plan comes together...
#199 Zeklandia
Zeklandia
    Developer
  • 75 posts
Posted 16 June 2012 - 11:54 AM
AWESOMENESS!!!!!!!
Sent from my Battle Droid
  • wabmorgan likes this
Asher Wood
Google+ | Github
#200 Zeklandia
Zeklandia
    Developer
  • 75 posts
You need to reboot. Once it mounts those partitions it can't remount.
Asher Wood
Google+ | Github
