[ROM] Rage M Beta Test **UPDATED LINKS**10/21/2013**
unlocked bootloader safestrap locked bootloader Razr M xt907 Rage Rom Rage M Team Rage BDAZZG1
127 replies to this topic
#61 moto13
moto13
  • 45 posts
  • Current Device(s):Razr M
Posted 11 September 2013 - 04:41 AM
this damn ROM is really pissing me off. Try a dirty flash on top of test 5
Sent from my Raged Out RAZR MAXX HD
I had same issue..  I wish I had a RAZRM to donate, I'm sure it would help!
#62 Senju
Senju
    Veteran Noob
  • 26 posts
  • LocationAyer Ma.
Posted 11 September 2013 - 11:28 AM
Nope, did the same.soooo slow down find yourself or run around smash some stuff and come back to it. 1 of those 2 always works when in create/ repair mode ;)
Say what now?!? :huh:
#63 kendog
kendog
  • 234 posts
  • LocationMillville, NJ
  • Current Device(s):droid bionic
Posted 11 September 2013 - 04:44 PM
Beta 8 just bootlooped for me
Sent from my Droid RAZR M using Tapatalk 4
#64 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
  • Current Device(s):DROID RAZR M
Posted 12 September 2013 - 02:47 AM
Mine didn't boot loop, it just wouldn't flash in twrp or cwm. The error I got said updater script failed. I asked via private message if there was any way he could make a regular zip file (non recovery flashable) containing only a system.img and a boot.img to flash via fastboot. Also, when I have pulled other ROM zips apart, that's what they contained. But to me, just writing two compiled IMG files seems easier. It may not be possible to get the end result he wants that way though. Maybe it has to flash basically a stock img, then update/add the things he wants in this ROM. BTW, it was beta 8. Also, OP couldn't u download an android emulator online, then change the specs to the RAZR m, and test this way without having the physical device. I know this is possible if you have the right software, which I believe is in the SDK. Maybe not, though. I don't remember.
#65 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
Posted 12 September 2013 - 02:58 AM
Basically like virtualbox is for testing desktop OSes. I know this is the method a lot of devas use, when developing mass ROMs because they can't own 50 devices. It isn't practical. I would guess in the Android emulator it would give options when opening like Brand(moto) , board (msm8960), processor, screen size. Then I believe you can insert a stock XML, then from there install custom recoveries.
PS this is just an idea. I know the possibility exists, I just don't know all the details. And honestly I was thinking about trying to build a stock ROM myself. Possibly with me having the actual device, and your expertise, we could get something working well. If I can get a beta to actually boot, I can provide logcats or whatever you need.
#66 lowvolt
lowvolt
  • 478 posts
Posted 12 September 2013 - 03:09 PM
I am guessing gapps are included.
#67 kendog
kendog
  • 234 posts
Posted 12 September 2013 - 09:04 PM
Yes
  • reggietothemax likes this
#68 bdazzg1
bdazzg1
    I Break $hit!
  • 359 posts
  • Twitter:@bdazzg1
  • Google+:https://plus.google.com/u/0/+TonyRossBDAZZG1
  • LocationPrescott Valley, AZ
  • Current Device(s):Nexus 6, Droid Maxx, Droid Ultra, LG G2, LG G3, Samsung Galaxy Tab 2 7.0
Posted 12 September 2013 - 10:10 PM
Test 9 Uploading Now! :)
#69 techjunkie
techjunkie
  • 43 posts
  • Twitter:islandfellow
  • Google+:islandfellow
  • LocationGeorgia (The State)
  • Current Device(s):Droid Razr M, Sony Tablet S
Posted 13 September 2013 - 04:49 PM
Test 9 is a no go for me I get...."installation aborted" in CWM.  Still trying other combinations.
This is not installing for me.  :wacko:
Edited by techjunkie, 13 September 2013 - 05:44 PM.
  • aviwdoowks likes this
#70 reggietothemax
reggietothemax
Posted 13 September 2013 - 08:18 PM
Same here, test 9 fails in twrp
#71 bdazzg1
bdazzg1
    I Break $hit!
  • 359 posts
  • Twitter:@bdazzg1
Posted 14 September 2013 - 08:24 AM
Are you guys mounting system after wipe? I didn't change the updater script or binary at all so I don't understand the failures...unless system isn't mounted
#72 techjunkie
techjunkie
  • 43 posts
Posted 14 September 2013 - 08:36 AM
Yes, I wipe system, wipe cache, mount system, flash zip.
 I even tried mounting everything.
I also tried wipe system, wipe cache, reboot recovery, and then mount system.
#73 Senju
Senju
    Veteran Noob
  • 26 posts
  • LocationAyer Ma.
Posted 14 September 2013 - 03:43 PM
No go here either. I did the dances too. On to the next
#74 bdazzg1
bdazzg1
    I Break $hit!
  • 359 posts
  • Twitter:@bdazzg1
Posted 14 September 2013 - 04:06 PM
That's effing weird. It is failing to flash in recovery right? What exactly is the error?
#75 techjunkie
techjunkie
  • 43 posts
Posted 14 September 2013 - 04:46 PM
The error for me in CWM is "installation aborted"  thats all.
#76 Senju
Senju
    Veteran Noob
  • 26 posts
  • LocationAyer Ma.
Posted 15 September 2013 - 06:34 AM
Boot loop at boot animation even after "super clean" installation
#77 aviwdoowks
aviwdoowks
  • 140 posts
Posted 15 September 2013 - 07:59 AM
Of course it bombs. It was zipped in a redundant folder!
Re zipping a copy....
#78 aviwdoowks
aviwdoowks
  • 140 posts
Posted 15 September 2013 - 08:09 AM
To all: extract the test, select all from the useless folder, select cut from rootexpl, go up to the root of test..., choose move here, trash the folder, go up, longpress on test..., zip..
#79 bdazzg1
bdazzg1
    I Break $hit!
  • 359 posts
  • Twitter:@bdazzg1
Posted 15 September 2013 - 08:32 AM
Nice way to point out an error a$$ho!e! It's a$$ho!es like you why there's so little development for this device. My pacience is about gone with this damn site and the way it's treated the rest of my team anyway! As I do appreciate you pointing out a mistake, you don't have to be so smug about it. I do this for fun...no more, no less, to give something for FREE. Responses like yours will only quickly drive me to scrap the damn project.
  • jco23 likes this
#80 Shilalygawd
Shilalygawd
  • 8 posts
  • Twitter:twitter.com/Shilalygawd
  • LocationMarshall, TX
Posted 15 September 2013 - 08:57 AM
Pretty sure he wasn't being a shlong. You just took it poorly because he used the word redundant.
Also tagged with one or more of these keywords: unlocked bootloader, safestrap, locked bootloader, Razr M, xt907, Rage Rom, Rage M, Team Rage, BDAZZG1
