[GUIDE] 3G Data on Droid Bionic / RAZR w/o LTE SIM on JB STOCK [Non-Verizon Carrier]
7 replies to this topic
#1 matriX1218
matriX1218
  • Google+:kalpeshsuratwala
  • LocationSurat
  • Current Device(s):Motorola Droid Bionic - XT875
Posted 26 August 2013 - 09:42 PM
Finally 3G Data on Droid Bionic is possible without LTE SIM..!!!!!! [Non-VERIZON Carrier]
!!!!!!!...PLEASE NOTE THAT THIS PROCESS CAN BE DONE BEFORE FLASHING YOUR PHONE TO ANY CARRIER...!!!!!!!
IF YOU HAVE ALREADY FLASHED YOUR PHONE TO SOME CARRIER, SIMPLY FOLLOW THIS GUIDE AND YOU WON'T NEED LTE SIM FOR 3G DATA....
THIS IS JUST A WORK AROUND / SOLUTION TO LTE SIM ONLY...
IT SHOULD ALSO WORK ON RAZR / RAZR MAXX as Bionic and RAZR are Siblings
Ok Guys,
Here is my guide for the same... Please note that I've already tested this method and its working properly on my Bionic...
However I take no responsibility, if you brick your phone...
!!!!!!..........YOU MUST BE ROOTED..........!!!!!!
Download apps from the following link...
Install both apps and grant Superuser permission when needed...
Now run aShell
Select Root on Top Right
Now TAP on FIle Explorer then
>>>> DATA  /  DATA  /  com.android.providers.settings
TAP on Databases
TAP on settings.db
TAP on Open databse with aSQLiteManagar
TAP on secure
TAP on data tab and following screen will appear
TAP on EDIT on No 14 Entry "preferred_cdma_subscription"
Change Value to 1
Press OK
Now Press PgDn until you see No 50 Entry "subscription_mode"
TAP on EDIT and Change Value to 1 same as you did previously"
Now Press PgDn until you see No. 483 "preferred_network_mode"
Now TAP on EDIT and change Value to 7 as shown in picture for 3G
Or change value to 8 for 4G...
Press OK
Press Back on Phone until you see the following/SIZE]
Press YES
Press Back on Phone until you see EXIT the aShell
TURN OFF your Phone
Remove LTE SIM
TURN ON...
VOILA 3G WILL START AFTER REBOOT...
[SIZE="4"]Feel free to post comments...
  • aneeshmbabu and tuxman like this
#2 Bala_n
Bala_n
  • 7 posts
Posted 27 August 2013 - 03:37 AM
Is this method for the NVONLY mode ? or it will work with RUIM_Mode with indian sim cdma sim cards inside?
#3 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 27 August 2013 - 06:32 AM
nice guide will give a try ...I'm waiting for this from last 6monthsss....
#4 matriX1218
matriX1218
  • LocationSurat
Posted 27 August 2013 - 07:01 AM
It's for NV Only mode...as I'm on Reliance CDMA only... :p
Trying to make data work on OMH card for all CDMA too...;)
sent from Motorola DROID BIONIC HD on Reliance Wireless
#5 matriX1218
matriX1218
  • LocationSurat
Posted 27 August 2013 - 07:02 AM
Same here...
Finally able to crack the code...B)
#6 nakedtime
nakedtime
    Sauce Boss
  • 200 posts
  • LocationOhio
  • Current Device(s):iPhod 3gs, Droid 2, Droid Bionic
Posted 31 August 2013 - 01:50 PM
Could we use some form of this hack to enable use with GSM carriers?
I'm from the internet and so can you!
#7 zlebors
zlebors
Posted 17 September 2013 - 06:59 AM
Trying to make data work on OMH card for all CDMA too... ;)
Here in Indonesia we use RUIM for EVDO rev.B, I've done this a year a go
#8 matriX1218
matriX1218
  • LocationSurat
Posted 17 September 2013 - 07:11 AM
Please post guide
Sent from Motorola DROID BIONIC HD on Reliance Wireless
