[Rom][Razr - Gsm] Eternityproject Mod -- Deodexed Stock Rom (6.5.1.73
3 replies to this topic
#1 shady_lanem
shady_lanem
    GSM/VZW Rom Madman!
  • 27 posts
Posted 21 December 2011 - 06:54 AM
Welcome to The EternityProject's Deodexed Stock Rom by shady_lanem
Prerequisites:
GSM International Version only
Tested on build number 6.5.1-73_SPU
System Version 651.73.23
Bootstrap Recovery
What do we have here?
Fully deodexed stock rom done manually by Shady of EternityProject Team.
Which version of gsm is compatible with this Rom?
As of now, I only tested on European 6.5.1-73. Those with different build number flash this at your own risk.
Why deodex?
Mainly for theming and slight noticeable increment of performance and speed on the phone
Issues/Bugs (Please report or leave comments if you found any errors)
- Swype and moto input keyboards force closes
- Apps associate with Motocast will get errors (Music, gallery, wifi on) ---> Temporary solution is to freeze or remove the ZumoService.apk in system/app
Download:
Temporary Swype fix --->
Download Instructions:
1. Download the zip file and put into your sdcard
2. Enter bootstrap recovery
3. Go to Install from sdcard
4. Install the zip file
5. Wipe cache partition
6. Reboot (Reboot will take a very long time, don't worry it's not bricked. Just be patience)
The EternityProject Developer,
shady_lanem
If you appreciate and would like to support my work,
Add me to your Google+ circle
#2 adlx
adlx
    Developer
  • 34 posts
  • Twitter:adumont
  • LocationMadrid, SPain
Posted 09 January 2012 - 06:56 AM
Did you encounter any error while deodexing the rom?
Phones: Motorola RAZR UMTS XT910, HTC Chacha, Atrix (hard bricked), Defy, 2 Dext, CliqXT, GeeksPhone One
#3 mijey2006
mijey2006
  • Twitter:mijey2006
  • Google+:mijey2006
Posted 04 July 2012 - 10:49 PM
hi bro i hav this model
claro mobile puerto rico
system version 651.167.3370.xt910.americamovil.en.01
baseband u_1c.76.0fp
webtop wt-2.0.0-139_es
kernel 2.6.35.7
build# 6.5.1-167_slc-m37
rom 2.3.6
is already rooted and cm recovery
i like to nhow which ics stable custom room for daily use i can install because for this model i cant find much
#4 nande
nande
  • 5 posts
Posted 16 November 2012 - 01:35 AM
Edit: erase... didn't see the date :|
