[SBF] xt908 SBF
xt908 sbf xt908 sbf xt908 .sbf
29 replies to this topic
#1 Guest_dullawolf_*
Guest_dullawolf_*
Posted 23 August 2013 - 08:32 AM
I am not sure where this should go, but this location seems like it will due for now. Mods, if it is in the wrong place, feel free to relocate it. Which I am sure you would have done with or without my permission.
I was giving a copy of the XT908 SBF file for 4G phones. My initial goal was to take the system.img file xt908 and try it on my xt912; Howerver, I am not brave enough yet to do that. The reason for doing so is because there is no bloat whatsoever.
 Well, since I had mentioned that I had this file, some people were asking about, so out of the niceness of my heart, I will do so.
Here it is. Enjoy -->
 I believe this is the 4.0.4 file.
[disclaimer] I am not responsible for anything you do to brick your phone. This file is as I received it from the source and it is legit. I am not a developer/hacker/moderator and will be of minimal help.
  • neckchop, johnthehillbilly, livinginkaos and 6 others like this
#2 livinginkaos
Posted 23 August 2013 - 09:01 AM
Thanks for posting this! There have been a few requests for this and many of us have looked high and low.  All we had to do was look for you :)  Thanks again!
  • johnthehillbilly and oman14 like this
#3 johnthehillbilly
Posted 23 August 2013 - 09:17 AM
Indeed....:) this is awesome !
....you should be having fun....
  • oman14 likes this
#4 oman14
oman14
Posted 24 August 2013 - 02:15 PM
awesome! downloading now i have a bricked xt908 from Nex-tech ill let you guys know what happens. i also looked high and low i even went into the china forums and tried my best with website translators to find this, but had no luck! thanks again
Edit: wanted to ask a question.
also now that we have this you think it is possible to make roms for it now and get us xt908 users on android 4.1.2 or maybe even 4.2? we never got the official jelly bean update as Motorola didn't see it necessary because this phone inst so popular
Edit: Update
Downloaded it and it worked like a charm!!! anyone with the fail to boot problem try it out!! thanks!
Edited by oman14, 24 August 2013 - 03:39 PM.
  • Jorgeabel13 likes this
#5 MA7MOD_GSM
MA7MOD_GSM
  • 16 posts
  • Twitter:ma_m0d
  • Google+:mahmody61@gmail.com
  • LocationEGYPT
  • Current Device(s):HTC One X
Posted 25 August 2013 - 08:52 AM
ok great ,,  thank you i will try 2moro ,, hope unbrick my xt908
#6 Guest_dullawolf_*
Guest_dullawolf_*
Posted 26 August 2013 - 07:22 AM
Excellent!! I am glad that I was able to get this file for you. I am sure a lot of people are going to be downloading it.
As for the 4.1.2 and 4.2.2 update, I am not sure what is being done with that. Since the 908 seems to have a custom made .sbf, it will probably be some time before Motorola puts together a JB for those devices. You can always try contacting a motorola tech and see what they say.
#7 johnthehillbilly
Posted 26 August 2013 - 07:26 AM
I opened this sbf file up.... and there seems to be an ota update included (in a seperate file ).... not sure what update it is tho.......... just sayin' :)
.... you should be having fun ...
#8 oman14
oman14
Posted 26 August 2013 - 06:02 PM
I also noticed the update but I didn't think nothing of it
#9 chairwolf
chairwolf
  • 18 posts
  • Current Device(s):Motorola Droid Razr Maxx Xt908
Posted 17 September 2013 - 04:12 PM
XT908 question for dullawolf  - (hope this thread isn't dead!)  Anyhooo, are you getting 4g on your XT908 with this sbf file?  any modifications required?  I bricked my rooted xt908.  Got it returned to stock 4.0.4 and working again (long story).  I'm still stock unrooted now, but my carrier will be going 4g in November supposedly.  Problem is, they only support 4g on the  IP5 so far.  I know my 908 will handle it, but i'm not sure how to do it.
I'm thinking along these lines:
- re-root
- install ss 3.11
- try your sbf file on a slot and see if 4g works.
Any thoughts, anyone?
thanks
ps also, question on eternityproject's root program - does it put another 'stock' rom on the phone, or does it keep the existing 'original' stock rom?  on my first root experience, I used Matt's utility 1.82 and it put a verizon 'stock' rom on my phone.  it worked, but i could not go back to my original file.  just wondering if the eprj software is different.  thanks!  ;)
#10 johnthehillbilly
Posted 17 September 2013 - 04:18 PM
Obviously I'm not dullawolf LOL ... but you cant use an sbf on a ROM slot, as it uses fastboot mode which is over and above the ROM slots.... HD tappin' .... hillbilly style!!
#11 chairwolf
chairwolf
  • 18 posts
Posted 17 September 2013 - 04:21 PM
great!  But I'm wondering if i'll get 4g with it.
#12 johnthehillbilly
Posted 17 September 2013 - 04:25 PM
Sorry I typed that wrong... you can't (cannot) use sbf on a ROM slot.... as far as 4g .... I'm not sure if the radios included are 4g radios .... they would need to be updated (probably via OTA)
#13 chairwolf
chairwolf
  • 18 posts
oh, wait a minute, so what exactly does the sbf file do?
#14 johnthehillbilly
Posted 17 September 2013 - 04:27 PM
Sbf is used to restore full factory stock settings and software on the phone ... it will wipe everything and then reinstall it....
#15 chairwolf
chairwolf
  • 18 posts
Posted 17 September 2013 - 04:31 PM
oh, ok.
now....
i think that the sbf file that was posted contains a radio.img file.
So, if
(1) that file does 4g, and
(2) the file is for the cdma xt908, and
(3) my carrier jives with that file,
then will my phone do 4g if i use that file?
#16 chairwolf
chairwolf
  • 18 posts
Posted 17 September 2013 - 04:33 PM
i'm also wondering if i just re-root and put jb on a rom slot, if 4g will work on that slot.
(I'm trying to get 4g even though my carrier isn't going to "give" it to the xt908)!!!
#17 johnthehillbilly
Posted 17 September 2013 - 04:42 PM
If your carrier is not supporting 4g on your device, AFAIK there really is not a way to get 4g on it....
#18 Guest_dullawolf_*
Guest_dullawolf_*
Posted 18 September 2013 - 08:49 AM
Ok, here is the thing. There are two xt908 .sbf files. One of them is for companies that only support 3g and the other one is for companies that support both 3g/4g. Lucky for you, the sbf file i was able to acquire is for the companies what support 4g.
I am not going to guarantee anything, but you should be fine to install this .sbf. If the 4g doesn't work right away, you SHOULD still be able to pick up 3g.
#19 chairwolf
chairwolf
  • 18 posts
Posted 19 September 2013 - 04:07 PM
Thanks, John and Dulla.  I won't be able to check until my carrier actually offers 4g, which is supposed to be in November.  Stay tuned!
#20 MA7MOD_GSM
MA7MOD_GSM
  • 16 posts
  • Twitter:ma_m0d
  • LocationEGYPT
Posted 15 October 2013 - 07:56 PM
can we get 4.2.1 update sbf for xt908
Sent from my iPhone using Tapatalk -
Also tagged with one or more of these keywords: xt908, sbf, xt908 sbf, xt908 .sbf
