Wifi Tether
20 replies to this topic
#1 chrisc2u
chrisc2u
  • 50 posts
Posted 22 August 2013 - 07:32 PM
Can a current owner of the Ultra or MAXX try PdaNet+ which is partnered with Foxfi (or other non-root wifi tether app that doesn't require root) to see if it works? I use my phone as a hotspot and need to ensure I can wifi tether with my unlimited data in order to buy this phone. I am really looking forward to the active notifications, trusted device unlock and continued great battery life!
Thanks in advance!
#2 Casen_
Casen_
  • 100 posts
Posted 23 August 2013 - 12:11 AM
Thanks in advance!
Just checked, PDA net free does not work. Puts up an error on the MAXX.
Sent from my XT1080 using Tapatalk 4
#3 chrisc2u
chrisc2u
  • 50 posts
Posted 23 August 2013 - 03:53 AM
Thank you very much for checking! What was the error? Entitlement check or?
#4 Casen_
Casen_
  • 100 posts
Posted 23 August 2013 - 04:01 AM
Just said could not establish. Did not specify error
#5 chrisc2u
chrisc2u
  • 50 posts
Posted 24 August 2013 - 04:11 PM
I tried foxfi, pdanet+ and 1 click wifi tether today at the store (along with a few others) and had no luck with any of them.
#6 livinginkaos
Posted 24 August 2013 - 05:03 PM
If you are on the ultra are you on the shared data plan?
From My S4 Dev Edition
#7 Casen_
Casen_
  • 100 posts
Posted 24 August 2013 - 05:28 PM
I do not have a shared data on my MAXX
Sent from my DROID MAXX via Tapatalk 4.
#8 chrisc2u
chrisc2u
  • 50 posts
Posted 24 August 2013 - 08:44 PM
If you are on the ultra are you on the shared data plan? From My S4 Dev Edition
I was testing on the MAXX at the store so I don't actually know what kind of plan the store phones are on. My initial thought would be that on a shared data plan the apps would usually work because it was allowed?
#9 clintro
clintro
  • 44 posts
  • Twitter:clintro
Posted 26 August 2013 - 04:58 AM
On the shared (tierd) plans, if I recall correctly, the built in HotSpot should work.  You need the work around for unlimited datd plans or you have to pay $30 per month for HotSpot data.
#10 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
  • Google+:amcsocold@gmail.com
Posted 27 August 2013 - 04:32 AM
You can no longer change any part of your plan of you reside on unlimited. I tried changing visual voicemail and the online prompt true forcing me to chose a replacement shared data plan.
sig by jayrod
The Rules-Follow them.
#11 PogoTheMonkey
PogoTheMonkey
  • 98 posts
  • Current Device(s):Motorola DROID MAXX Developer Edition
Posted 27 August 2013 - 08:25 AM
The web site just sux call in and and you can change w/e you need to
#12 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
Posted 03 September 2013 - 04:40 AM
I have been. It's called cancelling my lines. I'm done with the greed and bull business practices.
Sent from my Galaxy Nexus using Tapatalk 4
sig by jayrod
#13 chrisc2u
chrisc2u
  • 50 posts
Posted 12 September 2013 - 09:06 PM
Credit to DirtyDroidX and PipeHitter, after you root (thanks JCase!) You can now use SQLite Manager or the free method below to enable your mobile hotspots on the new Droids without the entitlement check!
http://www.droidrzr....e-hotspot-hack/
For using the stock Mobile Hotspot, here is a quick walk-thru using some free sql apps if you want to avoid paying for SQLite Manager.
As always, all standard caveats apply - ie perform at your own risk. ROOT IS REQUIRED!
Note: If you make an error while in aSQLiteManager don't panic, just back out and when prompted to save tap NO, then start over.
1 Launch your stock Mobile Hotspot app to ensure a db entry is created[/size]. It will not work and give a msg stating to call cust svc, thats fine.
2 Back out and download both aShell and aSQLiteManager by ANDSEN in play store for free[/size]
3 Launch aShell and agree to terms, etc.[/size]
4 Make sure you enable root access by checking box in upper left corner that says "root"[/size]
5 Tap "file explorer" and navigate to /data/data and select "com.motorola.android.providers.settings"[/size]
6 Select "database"[/size]
7 Select "settings.db" !!!BE PATIENT!!, it will take a momement to create a temp file [/size]and give you a response
8 Tap complete action using either reference to aSQLite[/size]
9 Tap open database with aSQLiteManager[/size]
10 Tap settings[/size]
11 Tap data[/size]
12 Tap pgdn until you see “entitlement_check” (mine was row 67)[/size]
13 Tap "edit" on row 67, then change "value" from the default of 1, to 0[/size]
14 Tap OK[/size]
15 Reboot[/size]
Now you should be able to use VZW Mobile Hotspot[/size] with no problems. I've connected with various devices and all behaves normally.
Posted using wifi hotspot from my new Droid MAXX :)
  • wabmorgan likes this
#14 skiboarder119
skiboarder119
  • 6 posts
Posted 16 September 2013 - 09:13 AM
After doing as Chrisc2u listed the first time it didn't work.  I had to hit "back" a couple times to get it to "save changes".
This works for wifi hotspot & USB Tethering.
Thanks to everyone who makes this possible!
#15 VenturaDroid
VenturaDroid
  • Current Device(s):Droid Maxx, Asus TF101
Posted 01 November 2013 - 10:51 AM
1)I remember doing this same fix to my Droid Bionic. However... Does anyone remember if this affects the Verizon OTA Update Integrity check?
Incase others do not know, when an OTA comes out, it usually checks the integrity of the download AND the current configuration of your phone. In the past i remember undoing some changes so it would pass and the OTA would go through. Cant remember if doing the entitlement check fix for Wifi affects future OTA updates.
2) The original thread here stated chris was looking for a 'non-root' method. Havent tried this yet on the Maxx, but were you actually able to edit the entitlement record in the DB with SQLLiteMngr, without being root?
#16 splashd
splashd
Posted 04 November 2013 - 06:46 PM
Worked like a champ on my Droid Maxx Dev Edition. thanks
#17 VenturaDroid
VenturaDroid
Posted 04 November 2013 - 10:34 PM
But doesn't your Dev Maxx have root privlages?
#18 DVDDave
DVDDave
  • 66 posts
Posted 30 November 2013 - 03:45 PM
im not rooted and pdanet works on my new maxx
#19 clintro
clintro
  • 44 posts
  • Twitter:clintro
Posted 31 December 2013 - 06:28 AM
I am running the maxx dev edition on stock unrooted with a locked bootloader and it works.  They updated FoxFi.
#20 savannahman
savannahman
  • 90 posts
Posted 18 January 2014 - 01:42 PM
XT1080M developer addition:
I just updated to 4.4, have root however the entitlement check database has changed. The database accessing with SQ Lite  is:
data/data/com.motorola.android.providers.seetings/databases/settings.db
The choices here are: android_metadata, global, secure, sqlite_sequence and system
The only choice that gives a database is secure
If you choose secure and go down to entitilement_check (on my phone is line 60), you can enter a 1 or a 0 and the hotspot still prompts for payment. Has anyone found a workaround here?
Also, FoxFi did not work either.
