[FXZ] Motorola Droid Ultra FXZ
26 replies to this topic
#1 Pzyduck
Pzyduck
    Firmware Team
  • 45 posts
  • Twitter:Pzyduck
  • LocationLa Rioja - Argentina
Posted 21 August 2013 - 06:31 AM
FXZ are provided by FIRMWARE TEAM!
You can download them here: http://sbf.droid-dev.../obake/list.php
Please note that I don't know what is the RSD lite version requirement!
Install for fastboot :D
  • jntdroid, jack'o, livinginkaos and 1 other like this
Firmware Team: Kent_lkc - Kwachu - daywalker04 - Pzyduck - Skrilax_CZ - toto221
#2 jntdroid
jntdroid
  • 36 posts
  • LocationTX
Posted 22 August 2013 - 04:26 AM
Thanks for getting these so quickly... already had to utilize it.
With rsdlite 6.1.5 I could not get it to see the device... but since fastboot was seeing it, I was able to fastboot the boot.img, which is all I needed at the time.  I don't know if that helps with the rsdlite version question or not (by means of deduction!)...
#3 livinginkaos
Posted 22 August 2013 - 04:43 AM
I have to ask, why did you need to use it already?
From My S4 Dev Edition
#4 jntdroid
jntdroid
  • 36 posts
  • LocationTX
Posted 22 August 2013 - 05:14 AM
I was trying to pull the new apk for Touchless Controls for a dev (open1your1eyes0).  He asked if I'd tried motochopper to root the Maxx yet, and in our back and forth I misunderstood him and thought he said he had seen it work (I should've clarified...).  So I gave a couple different versions a try, and one particular version that I can't find now (it was a link on this forum - file is motochopper_1.2_HD.zip) actually pushed a boot.img and attempted to flash it... I wondered why that particular .zip was larger than the other versions... :huh
Anyway, the moment I saw it pushing boot.img I had that "uh oh" moment that seemed to last a few seconds but only took a split second before it failed and I was stuck in the bootloader/fastboot menu.  Not sure why rsdlite wouldn't see it, but fortunately all I had to do was fastboot the boot.img and it was fine.  I wonder if a different version of rsd would make a difference?
A facepalm moment for sure, but I did at least make sure an FXZ was available before attempting the motochopper files...
#5 livinginkaos
Posted 22 August 2013 - 05:49 AM
Ah, yes, that particular version is for those on the HD that had taken the OTA update last month and were not unlocked.  In order to gain root, they need to flash the boot img back a version, take root, then flash back the updated boot img.  Now I understand :)
  • jntdroid likes this
#6 Casen_
Casen_
  • 100 posts
Posted 24 August 2013 - 09:04 PM
Well, hopefully someone gets root soon. I'll pay for their beer fund
Sent from my DROID MAXX via Tapatalk 4.
#7 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
  • Google+:amcsocold@gmail.com
Posted 25 August 2013 - 06:56 AM
since this thread contains the FXZ file, i think itll fit better under development. OP whats your opinion b4 i move the thread?
sig by jayrod
The Rules-Follow them.
#8 PogoTheMonkey
PogoTheMonkey
  • 98 posts
  • Current Device(s):Motorola DROID MAXX Developer Edition
Posted 04 September 2013 - 05:40 PM
any chance someone could provide 12.7.4 for the maxx, if it exists, i bought my maxx today and it came out of the box with 12.7.7
#9 BladeRunner
BladeRunner
    Chatroom Tech Support
  • 347 posts
  • LocationMaine
Posted 25 September 2013 - 03:35 AM
why do you need 12.7.4? What the difference  between the two?
#10 BladeRunner
BladeRunner
  • 347 posts
  • LocationMaine
Posted 25 September 2013 - 03:36 AM
Does USB debugging need to be enabled for RSD lite to see the phone?  I've seen that mentioned elsewhere and I'm not sure if it is correct or not.
#11 PogoTheMonkey
PogoTheMonkey
  • 98 posts
Posted 25 September 2013 - 03:40 AM
That's what I'm try to check
I've only ever used RSD in fastboot mode so I would assume the awnser would be no. Anything done in the os over ADB yes.
#12 BladeRunner
BladeRunner
  • 347 posts
  • LocationMaine
Posted 25 September 2013 - 11:58 AM
I've seen the 12.7.4 files somewhere, can't remember just where but they are out there somewhere.
That is what I though about RSD lite. There is some misinformation being distributed.
#13 BladeRunner
BladeRunner
  • 347 posts
  • LocationMaine
Posted 25 September 2013 - 12:06 PM
http://sbfdownload.d...eys_CFC.xml.zip   12.7.4
#14 MartyChubbs
MartyChubbs
  • 211 posts
  • LocationThe Ghetto, Minnesota
Posted 26 September 2013 - 06:40 PM
12.7.4 is older and not differentiated between ultra or ultra maxx... Just a guess.
Sent from my XT1080 using Tapatalk 2
I (aka Mr. Chubbs aka Marty "The Wad" Chubbs aka Knot Mehreelname ) accept no liability for the content of this post. I basically made it all up as I was typing...
#15 ahjee
ahjee
  • Current Device(s):Droid Ultra
Posted 12 November 2013 - 08:57 AM
Hey guys, my Droid Ultra is currently soft bricked, the two files available are out dated, they will not restore my phone back to stock after accepting the latest 12.15.15 OTA for the Ultra, If someone could upload the latest 12.15.15 so i could get my phone booted up and working that would be great. I am sorry if this comes off demanding, I just am in dire need of my phone!
Thanks in advanced for the file. I really appreciate it.
#16 originalmg
originalmg
Posted 15 November 2013 - 05:18 PM
This is  EXACTLY what I did after the update soft bricked my phone and caused a boot loop.
This is an easy fix. Use RSD lite version 5.6 (at least this is exactly how I did it). Place Device in fastboot mode.
Using the .zip file you download from the above links, Extract the file, then access the xml file within the folder. Edit using Notepad, Notepad + and erase
THESE 4 LINES ----
These 2 are at the bottom:
<step operation="getvar" var="max-download-size" />
<step operation="oem" var="fb_mode_set" />
 <step operation="oem" var="config carrier vzw" />
 <step operation="oem" var="fb_mode_clear" />
Once you have removed these, save the file. THIS SAVED XML FILE IS ALL YOU WILL NEED SO PUT IT SOMEWHERE EASY TO REMEMBER.
Run Rsd lite and fastboot the xml file YOU JUST SAVED!
boom should be all good. If it doesn't help you restore your MAXX I can't help beyond that.
  • Memnoch73 likes this
#17 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 15 November 2013 - 05:35 PM
Thanks man... Good info. I've heard this talked about before here but I'm not sure there have been written instructions anywhere. Shoot, if it helps at least one person it's a success. Glad you got yours going.  :)
#18 xXAaron04Xx
xXAaron04Xx
  • 14 posts
Posted 18 November 2013 - 07:44 AM
Are their fastboot files for the new 12.15.15 update?
#19 SamuriHL
  • 44,349 posts
Posted 18 November 2013 - 08:08 AM
No.  Everyone's still waiting.  The guy who provides them, Skrilax_CZ, also needs them for his phone so he's highly motivated to get them posted.  LOL.
  • admack and xXAaron04Xx like this
#20 Pzyduck
Pzyduck
    Firmware Team
  • 45 posts
  • Twitter:Pzyduck
Posted 22 November 2013 - 08:49 AM
Uploading: http://fwteam.grupoa...13/UltraXT1080/
  • SamuriHL, livinginkaos and xXAaron04Xx like this
