Ok so I am a new member and this is my 1rst 4g phone which I just 10 min. ago had flashed to page plus and shw was amazing .
anyway ...
I now need to do a back up before I remove bloatware and don't know whats the best I am now flashed to page plus on 9.18.79
So I had a droid 3 and used 1. safestrap v2.01 which I liked but bootstrap I loved and stuck with that but they do NOT make a bootstrap for the razr maxx hd as far as I know .
my questions would be is clockwork mod basically bootstrap? I used it before but it takes up a lot of space and I am not going to be flashing ROMS .
2ndly. I also had a droid 4 which I still have the safestrap version 3.05 and that worked very well to wipe cache and delvik
It has been over 4 months since I have looked into this and need a solid save option which will work with the razr maxx hd .
3. will version 3.05 work properly to save my original setup ,and if not can anyone recommend a version that will or
anther source {like clockwork mod } Again I will not be updating or changing my rom I just want to remove bloatware ,will most likely learn how to use titanium backup because no bloat {even though it works well is non as highly recommended as titanium backup} .
Thank you all
