Lockscreen Ring Help
6 replies to this topic
#1 gatorbeetle
gatorbeetle
  • 7 posts
Posted 20 August 2013 - 11:30 AM
Ok, so I was running ICS .215, and finally decided today to take the plunge and load the JB OTA.  I reverted back to .211 and ran the update, rerooted my phone, and installed Safestrap and all seems to be running sweet and well.
My issue is this...I had been sporting a custom lockscreen ring, using this post
 I of course lost this when I reverted to .211, as it is part of a system file which the reload wiped.  I tried to use the old ICS instructions, and Safestrap, but it didn't work, and I bricked the phone.
Recovered from brick, hoping someone has done this mod and can help me out.  Missing my custom look.
I think I know which files to replace in the framework-res...and know how to change that file, simply not sure how to safely load that file back without bricking it.
Thanks!
#2 johnthehillbilly
Posted 20 August 2013 - 11:35 AM
Edited because I'm an idiot and didnt fully read the post LOL .... .... are you having fun yet? ... if not, YOU SHOULD BE!!!
#3 johnthehillbilly
Posted 20 August 2013 - 11:40 AM
Anyway..... there are a couple ways you can replace the framework-res.apk .... the easiest would be a flashable zip..... or you could use adb and push it to /system/framework then use adb shell and chmod 644 /system/framework/framework-res.apk...... then reboot...... On you may have a few FC on reboot.... but rebooting again should fix it..... .... are you having fun yet? ... if not, YOU SHOULD BE!!!
  • livinginkaos likes this
#4 gatorbeetle
gatorbeetle
  • 7 posts
Posted 23 August 2013 - 06:25 AM
Thanks, but I ended up bricked when I edited the framework file, by simply adding the new image files, and uploaded it as a zip.
#5 gatorbeetle
gatorbeetle
  • 7 posts
Posted 23 August 2013 - 06:27 AM
The other suggestions I would have to research, I suppose.  Don't have much time for that, so the silly little key image will just have to do for the time being.  Thanks again.
#6 johnthehillbilly
Posted 23 August 2013 - 08:41 AM
Uploaded as zip? ..... could you elaborate on that.... you can't just flash a regular zip (in case you didn't know) ....:)
Anyway, the ADB method is probably the most reliable method.... although the most time consuming.....
If you need them here is the steps
place the modified framework-resume.apk in your ADB directory (unless you have ADB in "path"
Open command window
adb remount
ADB push framework-res.apk /system/framework
ADB shell
cd /system/framework
rm-r framework-res.apk
chmod 644 framework-res.apk
exit
exit
ADB reboot
That should install the framework-res.apk properly
....you should be having fun....
#7 gatorbeetle
gatorbeetle
  • 7 posts
Posted 30 August 2013 - 05:25 AM
I guess I should say I put the zip on my external SD card and ran it as an update in safestrap (previously had used Clockwork Recovery.)  I'll try the ADB route and let you know.  Thanks for the guidance. :)
