xt912 root, fix verizon hotspot, how to unroot (not to write the stock version)
4 replies to this topic
#1 malkovich
malkovich
Posted 19 August 2013 - 10:50 AM
Hi guys, I'm using xt912 JB official in EU, with no problems. Expect hotspot. I've tried to find the right info but I couldn't.
I need to fix verizon hotspot as it asks me to call some us number.
I can root the phone change some strings via sqlite but how can I unroot by saving the strings I've edited in setting database via sqlite edit. ?
If I unroot by putting stock JB rom, the changes I've  made rooted will not be saved?
Thanks for you time.
#2 johnthehillbilly
Posted 19 August 2013 - 10:54 AM
You can certainly make changes and then unroot..... the changes should stay...:) as long as you don't flash stock back to your phone :) .... are you having fun yet? ... if not, YOU SHOULD BE!!!
#3 malkovich
malkovich
Posted 19 August 2013 - 10:56 AM
That was quick ;) so I just need to unroot by deleting superuser safestrap etc?
#4 johnthehillbilly
Posted 19 August 2013 - 10:58 AM
You can unroot by deleting superuser.apk and su binary and busy box....
#5 johnthehillbilly
Posted 19 August 2013 - 11:00 AM
Superuser lives in /system/app
Su lives in /system/bin
Busybox lives in /system/xbin
Make sure you delete all 3 before exiting out of your root file explorer or if using adb, before you reboot....
