Posted 11 June 2012 - 10:01 AM
1. RSD'd to 173
2. Using Matt's Utility, rooted GB (option 2)
3. Install Voodoo to Save Root
4. Download & Install ES File Explorer
5. Download & Install Rom Manager (Free)
6. Copy both update & crc files to /cache ( Blur_Version.6.12.173.XT912.Verizon.en.US.zip & Blur_Version.6.12.173.XT912.Verizon.en.US.crc )
7. Tap on zip file, choose to open with Rom Manager, hit "OK"
After that didn't work, I went back and did the same thing, only this time instead of tapping the file that i copied to /cache, i went back to the original file (after having copied to /cache) on my sd card (ext) and tapped on that...didn't work either.
I even tried verifying my steps with a youtube video.
My phone is an insurance replacement phone that shipped with 181, don't know if that affects anything.
Anyways, supposedly ICS is going to start rolling out tomorrow (emphasis on the SUPPOSEDLY), so it wouldn't be life-altering if it didn't work, just want to know what I'm doing wrong since I had no problems installing the ICS leak on my previous Razr.
#2 Guest_BDH_*
Posted 11 June 2012 - 10:03 AM
Posted 11 June 2012 - 10:06 AM
start from scratch
its important
if that doesnt work come to chat and ill help you out
Posted 11 June 2012 - 10:07 AM
Gotcha. Thing is, the files I have now are the files I had before from when the ICS leak was first discovered and the file names were the ones i mentioned in the OP. Should I update to 181 and change the file name accordingly? I tried doing that for 748 and it didn't work (obviously), but I don't know if it'll work going forward instead of backwards.
no that wont work.. Hicks must be busy right now he didnt read it all correctly
good man he is though.
anyway ill help you out
Posted 11 June 2012 - 10:28 AM
Posted 11 June 2012 - 01:28 PM
Posted 11 June 2012 - 04:02 PM
I'm re-downloading the files to see if maybe, just maybe, I mixed the 181 files with the 173...unlikely, but i've gone over everything so many times now that it seems like the only logical explanation is that i'm using the wrong files.
Keep in mind the file names are wacky. We have several ICS leaks labeled .181 because Moto tends to label their updates with the name of the system you are coming FROM, not going to. As if that makes it any less confusing. As stated though, all these ICS leaks require your system version to be .181, not .173, it's predecessor.
Posted 11 June 2012 - 09:20 PM
The first ics leak (.75) was based off of 173 which the op said he us trying to install. So he would have to be on .173.
Posted 12 June 2012 - 02:38 AM
Posted 12 June 2012 - 11:05 AM
Also tagged with one or more of these keywords: ics leak, razr
