[ROM] [8/17] [Wi-Fi flo-JSS15J] --FloTroN--
10 replies to this topic
#1 DirtyDroidX
DirtyDroidX
    The Enigma
  • 60 posts
  • LocationPittsburgh, Pennsylvania
  • Current Device(s):Note 2, Note 8.0, Nexus 7
Posted 17 August 2013 - 11:28 AM
- FloTroN -
- Stock Based JSS15J -
READ ME PLEASE!
THIS IS FOR THE 2013 NEXUS 7 AKA FLO/RAZOR. DO NOT FLASH THIS TO ANY OTHER DEVICE! ONCE AGAIN THIS IS FOR THE NEW NEXUS 7. BY FLASHING THIS YOUR WARRANTY IS NOW VOID, MYSELF OR DROIDRZR ARE NOT RESPONSIBLE FOR ANYTHING THAT MAY HAPPEN TO YOU OR YOUR DEVICE.
I made a personal ROM for myself and figured i'd share with everyone. Please do not report bugs, for i'm sharing this and might not continue on it, or maybe i will , who knows. If you did not read the big red letters above, this is for the 2013 Nexus 7!
~ROM~
~ Based of 4.3 JSS15J
~ Rooted
~ Busybox
~ Zipaligned
~ Deodexed
~ Insecure Stock Kernel
~ Init.d Tweaks
~ Build.prop Tweaks
~ ADB as Root
~1% Batt Mod
~ Beats Audio
~ Bravia Engine 3
~ Blacked out a few things
~ Advanced Power Menu (APM)
~ Stock AOSP Browser with Bookmark Sync
~ Xposed Framework Installer
~ Xposed Theme Engine
~ Genie Widget
~ cLocK
~ Dark Keyboard
~ Improved Touch Responsiveness
~ GPS Tuning
~ Probably more~
~Installation~
1) Must be Unlocked
2) TWRP Recovery prefered
3) MAKE A BACKUP!!!
4) Wipe Data Factory Reset
5) Install
6) Profit
~Tips~
~ Beats Audio is off by default, go into the Beats app to enable it. So far it's getting along with the default audio drivers.
~ Xposed Installer and Theme Engine was designed by @Rovo89 over at XDA. Please visit his thread HERE to find out how to use it. You must install the latest modules to be able to make modifications to your framework. In that thread is links to many theme's others have ported from CM themes to work with Xposed. So yes, basically Xposed is similar to the T-Mobile theme engine, but limited in certain area's. You will have to test it out for yourself. I have personally tested out a few and they work pretty good.
~ After you installed sit it down for a minute, just let it settle , don't ask just do it.
~ Have fun !
~Credit's~
Google ~ For giving us Android
BBCrackman
P3Droid
CyanogenMod & all the other AOSP Teams
My Mom
Droidrzr.com
A being that's higher than myself
~DOWNLOAD FloTroN v.1.5.1~
  • rickw likes this
#2 livinginkaos
Posted 17 August 2013 - 11:35 AM
Will this work on my original N7.....
JUST JOKING MAN!!!!
Thanks for sharing DDX!
From My S4 Dev Edition
  • DirtyDroidX likes this
#3 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 17 August 2013 - 12:05 PM
JUST JOKING MAN!!!!
I almost asked if it would work on my Nexus 4 and if it had "the HALO"  :p
  • Gytole, livinginkaos and DirtyDroidX like this
#4 Gytole
Gytole
    The Hicks Boson!
  • 248 posts
  • LocationOhiyah!
  • Current Device(s):HTC ONE M8, Galaxy Note 3, Nexus 7 FLO
Posted 18 August 2013 - 04:55 PM
Installed on my razr maxx hd... Few issues... It doesnt boot? shlong droidrzr developers... Hahaha
Jk installed fine, ish pretty neat. Love some flo lovin
Gyt-bauss stock wrecker
#5 lowvolt
lowvolt
  • 478 posts
Posted 18 August 2013 - 05:46 PM
you really installed on RAZR max hd? If true it should work on my M I believe they have the same kernel.
#6 Gytole
Gytole
    The Hicks Boson!
  • 248 posts
  • LocationOhiyah!
Posted 19 August 2013 - 09:32 PM
L........ Lmfao...
#7 Gytole
Gytole
    The Hicks Boson!
  • 248 posts
  • LocationOhiyah!
Posted 19 August 2013 - 09:37 PM
No man, i own a razr hd maxx but im running official cm10.
I also own a nexus 7 FLO and ive been rocking flotron out on it. I had cpu issues for a second but i solved it by a wipe and install again. Its all good. It also says in the op that its flo only. Too much fun!
#8 livinginkaos
Posted 26 August 2013 - 01:05 PM
JUST JOKING MAN!!!!
I guess now that I got Flo, I should put this on it !!  Gotta take it out of the box first though huh?  That part's not in the install instructions......  Unless that's what you mean by "Unlocked"... HA HA HA !!! I crack myself up  !!!  Time for oem unlock, thank you very much.....
#9 DirtyDroidX
DirtyDroidX
    The Enigma
  • 60 posts
Posted 27 August 2013 - 04:53 AM
Just makes life a little better when you have the option to "fastboot OEM unlock" :)
On a side note, working on update to latest OTA . Stripping down useless crap, Aroma installer and FloTroN kernel. Of course no ETA.
Kaos, can you move this to the new flo section, please and thank you.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
#10 livinginkaos
Posted 27 August 2013 - 05:20 AM
Done
#11 DirtyDroidX
DirtyDroidX
    The Enigma
  • 60 posts
Posted 27 August 2013 - 05:35 AM
Done
Your a gentlemen and a scholar.
