DISCLAIMER
**Neither myself or droidrzr.com are responsible for the things you do to your phone**
THANKS
BDH: For Rage Rom...letting me use it as a base and a lot of support and help!
usmcamgrimm: For helping me learn themes and all the hard work he put into this project!
johnthehillbilly: For the boot animation, testing and a ton of help and advice!
ZKK007: For helping me with beats audio.
nobe1976: Always there with a good tip, trick or advice.
eye_dea: for the governor/scheduler scripts.
zooyork0721: For helping me learn themes and hooking me up with his file hosting!
Badazzbionic
slwest78
Anyone else previously thanked in the Rage ROM OP
FEATURES
Works with Safestrap v3.11, v3.60, v. 3.65
Themed: usmcamgrimm, jl90 and BDH
OR
Optional stock theme (Thanks Grimm!)
1% battery mod
Entitlement hack baked in (WiFi tether)
Toggles
Reboot menu
Improved GPS lock and accuracy
Full init.d support
Insanely Debloated
Deodexed
Tons of init.d tweaks
Super SU
Super build.prop edits
Baked in optional overclocking
Extra governors and scheduler and ready to use
( thanks to east2west for compiling the modules)
Volume rocker skip track mod
Center clock mod
Transparent app drawer
Search key launches browser
Custom boot animation with custom sound
Default governor pegasusq
Default scheduler sio
Thanks eye_dea!
Beats Audio with AC!D tweaks (Knight47)
Special thanks to ZKK007
Team BlackedOut updater app (Thanks Zoo!)
BUGS
You tell me.
INSTALLATION
1. Select any ROM slot.
2. Create ROM slot.
3. Flash the ROM.zip
4. Reboot system
ENJOY!!
OVERCLOCKING INSTRUCTIONS
the overclocking frequencies are written in already but commented to prevent initial start up issues.
to enable overclocking:
1. open the Smanager app included in the rom.
2. Select "browse as root" and grant superuser permission.
3. Navigate to system/etc/init.d.
4. You will see a file named 94modules open it.
5. Select edit and open it directly when asked.
6. Remove the # found in front of each echo command
For example
( #echo 0 300 1025 > /proc/cpu_control/tweak_cpu)
7. Press the back arrow on phone select save.
You will be warned about bricking your device.
Select brick! It's OK!
8. Exit the app
Reboot phone.
After Reboot
Open the included Nofrills CPU app
Your phone will now be overclocked to 1325mhz.
Helpful Tip
NofrillsCPU.
Open settings (in app) and enable refresh frequencies
SetCPU
Create a profile for screen on, priority 100... with the setup you plan to use
Also
Underclock/undervolt your phone with the underclocking table.
Use the same process as above
DOWNLOADS
STOCK UI
Blood-less Rage
Many thanks and ALL credit to usmcamgrimm
OPTION 1
If you have already installed BloodRage.
Simply flash the Blood-less Rage.zip
OPTION2
If you have not flashed BloodRage.
1. Install BloodRage as instructed above.
2. Complete the set-up of your phone
3. Flash the Blood-less Rage.zip
THANK YOU!
Don't be afraid to hit like on this post!
