In need of some help with my Atrix HD.
Best Answer livinginkaos , 08 August 2013 - 05:06 PM
Sometimes the partitions can be fidgety and flashing them manually helps that. Anyway glad to help.
From My S4 Dev Edition
Go to the full post
55 replies to this topic
#41 livinginkaos
Posted 08 August 2013 - 04:19 PM
Then do a fastboot erase cache
Fastboot erase userdata
#42 devoe41
devoe41
  • 29 posts
  • LocationKannapolis, NC
  • Current Device(s):Atrix HD
fastboot flash system cdrom
is that the correct command? Sorry it's really been a bit since I've done this... I'm rusty.
#43 livinginkaos
Then reboot
#44 livinginkaos
Posted 08 August 2013 - 04:20 PM
No - fastboot flash cdrom cdrom
#45 livinginkaos
No worries
#46 devoe41
devoe41
  • 29 posts
Posted 08 August 2013 - 04:21 PM
OK cdrom done erased cache and system data
#47 livinginkaos
Posted 08 August 2013 - 04:24 PM
Userdata?
#48 devoe41
devoe41
  • 29 posts
i have the warning saying my bootloader is unlocked and it just stays there....
#49 devoe41
devoe41
  • 29 posts
Posted 08 August 2013 - 04:25 PM
yes sorry userdata...
#50 livinginkaos
Posted 08 August 2013 - 04:27 PM
In a short description RSD is justv an automated way to flash files. The script lays it out. The word between the quotes is the command that immediately follows the fastboot command then the "partition" is the part that follows that then the filename after that.
#51 livinginkaos
Try a reboot?
#52 devoe41
devoe41
  • 29 posts
Posted 08 August 2013 - 04:33 PM
yes when i reboot i am getting it still.
 I am sending a pic of it
#53 livinginkaos
Posted 08 August 2013 - 04:35 PM
And it just hangs?
#54 livinginkaos
Posted 08 August 2013 - 04:36 PM
Can you reboot into recovery?
#55 devoe41
devoe41
  • 29 posts
Posted 08 August 2013 - 04:45 PM
ok just did RSD again and it loaded into the OS. I thank you so much for your help with this.
#56 livinginkaos
Posted 08 August 2013 - 05:06 PM   Best Answer
