Best Answer livinginkaos , 08 August 2013 - 05:06 PM
Sometimes the partitions can be fidgety and flashing them manually helps that. Anyway glad to help.
From My S4 Dev Edition
Go to the full post
Go to the full post
Posted 08 August 2013 - 01:40 PM
OK, so I downloaded the FXZ and sure enough the get-var's were in there. The other error I got was that the filename path was too long. SO,
1. Take the zip that you downloaded and shorten the name.
2. Extract the zip
3. Delete the .xml file in the extracted folder
4. Download the xml that I have attached here
5. Place the xml into the extracted folder
6. Run RSD and navigate to the xml in the extracted folder.
Posted 08 August 2013 - 01:48 PM
here is what my phone shows and the RSD shows as error
Posted 08 August 2013 - 01:53 PM
You know, that's an error that usually happens when you've flashed a newer version. Most of the fxz's I've seen have that at the end. You can try removing that line as well and give it a go.
Posted 08 August 2013 - 02:01 PM
The phone is on 4.1.1, the fxz I DL'ed is for that ver. I tried the ICS and in Fastboot it said it was a downgraded one and would not allow me to continue. Which line should i remove in the xml?
Posted 08 August 2013 - 02:07 PM
Posted 08 August 2013 - 03:09 PM
get to step 8 and get this error.
Posted 08 August 2013 - 03:17 PM
Posted 08 August 2013 - 03:25 PM
got to 16 this time. LOL
Posted 08 August 2013 - 03:36 PM
Posted 08 August 2013 - 03:41 PM
Posted 08 August 2013 - 03:47 PM
Posted 08 August 2013 - 03:52 PM
Posted 08 August 2013 - 03:56 PM
hmm..... it is not working...... am I missing something? here is what I get.
Posted 08 August 2013 - 04:03 PM
Posted 08 August 2013 - 04:04 PM
never mind I'm an idiot.... and sleep deprived....
Posted 08 August 2013 - 04:05 PM
it is writing the system img... after that do I run RSD again?
Posted 08 August 2013 - 04:06 PM
also yes it is 5.6 what is the newest RSD? I shall find it and DL it real quick...
Posted 08 August 2013 - 04:08 PM
ok getting 6.1.5 now...
Posted 08 August 2013 - 04:13 PM
OK just tried to reboot the phone and it is showing me a warning that my bootloader is unlocked.... Which I already knew....
Posted 08 August 2013 - 04:15 PM
