S Voice workaround?
Posted 07 August 2013 - 12:59 AM
I do remember hearing about an app that makes other apps think you are using a different phone. Think that could work?
Posted 07 August 2013 - 02:21 AM
Posted 07 August 2013 - 02:11 PM
Now does anyone know how I can change the system voice? Id like to change it to a better sounding female
Posted 07 August 2013 - 02:16 PM
Is there one that will work on the XT907? I found an "Cracked" apk file for it and tried but of course it doesn't work properly, any ideas on if its possible to even do?
Please refrain from disccussing the use/possession of/acquiring of illegally obtained apps. It will not be tolerated here on DroidRzr . Item 4 in the site rules and guidelines expressly discuss this -
- Memnoch73 likes this
Posted 08 August 2013 - 09:54 AM
They're not talking about pirate apps, they're talking about s voice, which is a touch wiz app on the Sammy phones. When he says cracked he's talking about modified or modifiable. Not stolen.
Posted 08 August 2013 - 12:59 PM
OK ! The first thing that comes to mind when I see the word Crack or Cracked is pirated versions. My bad. Carry on!
Posted 08 August 2013 - 02:11 PM
This needs to be moved from the dumping ground to where ever it came from plox.
Posted 08 August 2013 - 02:16 PM
Done
Also tagged with one or more of these keywords: s voice, crack, mod, s4, galaxy, samsung, s3
