Is there a Wifi Tether fix for JB that works
5 replies to this topic
#1 rwrutl
rwrutl
    Droid Devotee'
  • 37 posts
  • LocationCleveland TN
Posted 06 August 2013 - 01:16 PM
Tried to use all the suggested workarounds for fixing Tether and nothing works, is (no ripoff) double pay Tethering a thing of the past ? I use to love the app but it doesn't work no matter what I do. I had seen a suggestion about re configuring a sys file but no longer seem to be able to locate the instruction, any help ?  plz ?
#2 livinginkaos
Posted 06 August 2013 - 01:30 PM
Read through this topic -
The last post has some options you may want to look at.
#3 rwrutl
rwrutl
    Droid Devotee'
  • 37 posts
Posted 06 August 2013 - 02:01 PM
Thanks I'm checking it out  thx again
#4 rwrutl
rwrutl
    Droid Devotee'
  • 37 posts
Posted 06 August 2013 - 03:12 PM
one other question I have is, will entitlement check reset work on unrooted phones (I'm rooted,but just wonderin')
#5 androidlearner
androidlearner
  • 904 posts
  • LocationPeoria, AZ
Posted 06 August 2013 - 03:19 PM
You still need root to make the change initially but I've never personally tried it. I would assume that once you've done the change and unroot it should still work. You only needed root to modify the entry. The system is just reading the entry.
Sent from my XT912 using Xparent Skyblue Tapatalk 2
#6 livinginkaos
Posted 06 August 2013 - 03:25 PM
I agree it should as you are using the stock tether and it would have no reason to check for root.
From My S4 Dev Edition
