[Q] Help with mobile data state - Disconnected
mb886 atrix HD mobile data
4 replies to this topic
#1 INsekure
INsekure
Posted 06 August 2013 - 03:19 AM
Hello all,
I am a new user posting from New Zealand.
I recently brought the Atrix HD MB886 online as an "unlocked" phone (I think from Canada?) and it seems to work fine sending txt's and making calls but I cannot get the mobile data to work.  If i go into "about" and then "phone status" it shows "Mobile data state - Disconnected"
I have tried adding the APN settings but this doesn't seem to change the disconnected state.
I read somewhere that even though the phone is unlocked, the mobile data may still be locked by AT&T?
If this is true, is there anything i can do to get it connected?
I really love my new phone and i hope i can get this working :D
These are my phone specs if it is any help:
System version: 98.4.20.MB886.ATT.en.US
Model number: MB886
Android version: 4.1.1
Baseband version: MB886_BP_100740.071.65.04P
Build number: 9.8.0Q_MB886_FFw-20
#2 linuxgator
linuxgator
  • 24 posts
  • Twitter:linuxgator
  • Google+:linuxgator
  • LocationNorth Central Florida
  • Current Device(s):Bionic
Posted 08 August 2013 - 06:13 PM
Does your sim card connect to data in another phone?
Sent from my MB886 using Tapatalk 2
  • INsekure likes this
#3 INsekure
INsekure
Posted 08 August 2013 - 10:31 PM
I will have to find another phone with a micro sim to try, my last phone took a normal sim and that worked fine but the atrid HD takes a micro so i took it into the telecom shop and they transferred my number on to a micro sim.
I might get the chance to try it in another phone tomorrow so ill post back when i can confirm. thanks!
#4 livinginkaos
Posted 09 August 2013 - 05:23 AM
Usually if you are having that kind of issue a new sim is what it takes.
From My S4 Dev Edition
#5 devoe41
devoe41
  • 29 posts
  • LocationKannapolis, NC
  • Current Device(s):Atrix HD
Posted 09 August 2013 - 09:14 AM
Does it show it's IMEI by chance? if not then maybe someone flashed the wrong radio onto it. If it is factory unlocked it should be go to go on the phone's end of things. I ran into this on a Note i717 once and just flashed the OEM radio back to it to get it to work again.
If they did give you a new Sim card it could be the issue, your old one you could of cut down to size. Also they make adapters to go from micro to full size on sims.
Also tagged with one or more of these keywords: mb886, atrix HD, mobile data
