S4 gpe 4.3
9 replies to this topic
#1 SamuriHL
  • 44,378 posts
Posted 03 August 2013 - 07:33 PM
I pulled the update from cache if anyone needs it. I can post it in the morning if anyone finds that useful. Been running it for a day now and it rocks. Battery life is great. Smooth and fast as hell. You have to be on stock recovery to update. I can post the instructions I used to restore stock recovery as well.
Etched in blood by a katana
  • rickw, livinginkaos and zooyork0721 like this
#2 rickw
rickw
    corvette dude
  • 1,951 posts
  • Google+:rickwebb001@gmail.com
  • LocationDelaware
  • Current Device(s):S4 dev edition,moto x dev,Nexus 6
Posted 04 August 2013 - 04:48 AM
yes please,lol
#3 SamuriHL
  • 44,378 posts
Posted 04 August 2013 - 06:27 AM
WARNING: I take no responsibility for anything that happens to your phone by following these directions.  This worked for me, it may not work for you.  This if for the I9505G Google Play Edition *ONLY*.  Other S4 variants will brick trying this.
Second WARNING:  Your failure to read is a failure to get support.  This is a potentially dangerous thing to do to your phone. READ, READ AGAIN, and READ ONE MORE TIME before doing anything.  If you don't understand something, just ask.
Ok, first, IF you need to fix stock recovery, go to this thread: (You need to do this if you have twrp or cwm installed)
http://forum.xda-dev...d.php?t=2360346
You can use that file and those instructions and only flash recovery.  That should work.  I have not tried heimdall myself, but, it seems to work if you follow the directions.  Make sure you are careful.  And you don't need to flash boot or system.  Just recovery.
If you want a more....adventurous (read DANGEROUS) method, you can extract the mmcblk0p22_recovery.img from the zip file in that thread, put it on your INTERNAL sdcard, open a terminal, and type this:
su
dd if=/sdcard/mmcblk0p22_recovery.img of=/dev/block/platform/msm_sdcc.1/by-name/recovery
HUGE WARNING!!!!!  MUST READ!!!!  If you don't extract the mmcblk0p22_recovery.img file from the zip file and instead try to flash the zip file, you WILL BRICK YOUR PHONE.  You MUST ONLY flash the mmcblk0p22_recovery.img file!!!!
NOTE: You must be rooted to use the dd method!
Now, if you already have stock recovery or have successfully restored stock recovery using one of the methods above, you can now flash the 4.3 update:
http://www.mediafire..._Update_FWD.zip
Notice that Samsung nicely put the sha1 hash into the filename (brilliant!) for us.  That's a hint that you should check the sha1 hash once you download it to make sure it matches.  Use Hashtab on Windows if you need a quick way to check the hash.
o) Put that file on your external sdcard.
o) Boot into stock recovery.  (Power off.  Hold volume up, home, and power until it vibrates then let go.)
o) Select apply update from external storage
o) Pick the file you put on the external sdcard
o) Once it's done, select the wipe cache (DO NOT pick wipe data unless you want a clean start.  WARNING picking wipe data is a factory reset and you will lose ALL your apps and data. JUST pick wipe cache unless you want a factory reset)
o) Reboot and you should be on 4.3 once the android upgrade script finishes
You will lose root during this process.  You can try using Voodoo OTA Rootkeeper if you want to preserve root.  Otherwise you can flash a custom recovery (TWRP or CWM) and flash chain fire's su zip package in recovery.  Make sure you get the latest version of chain fire's su zip as it's been updated to work with 4.3.
  • zooyork0721 likes this
#4 SamuriHL
  • 44,378 posts
Posted 04 August 2013 - 06:33 AM
I can't stress enough that using dd to flash recovery is potentially dangerous.  If you flash the wrong thing or get the instructions off, you will brick. It's a very unsafe thing to do as you're literally replacing the bits on the partition with the file you give it.  So please please please be careful if you use that method.
#5 SamuriHL
  • 44,378 posts
Posted 04 August 2013 - 04:57 PM
I've pulled my stock recovery for 4.3 but it doesn't match another person's posted on XDA.  Once I get that straightened out I'll post it so that those who wanna TWRP it up (um, myself) will have a stock recovery img to go back to for the next update.
#6 SamuriHL
  • 44,378 posts
Posted 05 August 2013 - 07:33 PM
I've got a bunch of stuff to add to this thread tomorrow. It was a busy day. I have a fully working odin flashable recovery img for 4.3. I'm working on modem updates for those that have baseband problems. Exciting times.
Sent from my Xoom using Tapatalk 4
#7 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
  • Google+:amcsocold@gmail.com
Posted 23 August 2013 - 06:06 PM
Looks like I get to join this club soon :D que the late night readings...
Sent from my Galaxy Nexus using Tapatalk 4
  • SamuriHL likes this
sig by jayrod
The Rules-Follow them.
#8 SamuriHL
  • 44,378 posts
Posted 23 August 2013 - 06:57 PM
I'll get some stuff together for you.  I've been a little bit slacking on the S4 stuff.
#9 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
Posted 24 August 2013 - 05:20 AM
Gotta fill this shiny new place ;) I need to read about pulling stock files so I have a safety net. Then I'll twrp
sig by jayrod
#10 SamuriHL
  • 44,378 posts
Posted 24 August 2013 - 06:23 AM
Yea, I have to go bring my mom her b-day present but I'll be back this afternoon and maybe will have some time to put things together.
