[Cdma Razr][Gingerbread] [Rom-Stock-181] Ikream.razr.gb.rom.vrc1-R3Ds
#1 Guest_R3Ds_*
Posted 03 June 2012 - 09:50 PM
FULL STOCK 181/748 OTA AND SOME MODS FROM ECLIPSE RAZR ROM V1.3 BY NITROGLYCERINE33
ALL CREDITS AND THANK YOU FOR THE AWESOME ROM AND HARD WORK NITROGLYCERINE33 YOU DID A FANTASTIC JOB
SOME FEATURES:
Motorola Services Working
Stock Blur Apps Included
Deodexed
Zipaligned
AOSP Gallery3D ( for Picassa Sync )
CM7 File Manager - Credits to Cyanogenmod
Google CarHome
Maps 6.8.0
YouTube
Sound Recorder
Inverted Dropbox
Inverted Google Search
DSP Manager
SpareParts
Misc prop edits
Busy Box
init.d Scripts Support
Th3ory's Custom SYSCTRL
Th3ory's Custom INIT.D
Th3ory's RAM Script
4096 SD READ Enhancement
iKReaM Theme by R3Ds
R3Ds Bootanimation
Battery Manager - for Battery Saving Profiles ( Need to Create a Shortcut to Activities )
Working Wifi-Tether - Use version 11
HOW TO INSTALL:
YOU WILL NEED TO USE SAFEBOOT RECOVERY VERSION 1.9 ENABLED
1 - DOWNLOAD THE ROM ZIP FROM LINK BELOW
2 - PUT ZIP ON SDCARD-EXT
3 - BOOT TO SAFEBOOT RECOVERY
4 - MAKE A BACKUP
5 - WIPE DATA AND CACHE
6 - WIPE CACHE
7 - GO TO MOUNTS AND FORMAT SYSTEM
8 - GO BACK
9 - GO TO ADVANCE AND WIPE DALVIK-CACHE
10 - GO BACK TO MAIN RECOVERY MENU
11 - CHOOSE FLASH ZIP FROM SD CARD AND SELECT EXTERNAL SD
12 - FIND AND SELECT THE ZIP AND INSTALL
13 - GO BACK AND REBOOT SYSTEM NOW
14 - ENJOY!!!
DOWNLOAD LINK UPDATE TO FOLLOW
********YOU MUST BOOT ROM ONCE BEFORE FLASHING ANY THEMES OR MODS********
iKReaM.RaZR.INVERTED.THEME.v2.0-R3Ds
HOW TO INSTALL:
1 - DOWNLOAD THE THEME ZIP FROM LINK BELOW
4 - MAKE A BACKUP
5 - CHOOSE FLASH ZIP FROM SD CARD AND SELECT EXTERNAL SD
6 - FIND AND SELECT THE ZIP AND INSTALL
7 - GO BACK AND REBOOT SYSTEM NOW
8 - ENJOY!!!
LIKE MY WORK?? YOU CAN HELP TO GET ME A COLD ONE, THANKS IN ADVANCE....
DONATE HERE
- MrFrankRazr, trikotret and kevinarjun like this
#2 Guest_R3Ds_*
Posted 03 June 2012 - 09:51 PM
THIS THEME IS MADE FOR MY iKReaM.RaZR.ROM ONLY, TO USE INSTALL THE ROM FIRST.
HOW TO INSTALL:
4 - MAKE A BACKUP
7 - REBOOT
8 - ENJOY!!!
#3 Guest_R3Ds_*
Posted 03 June 2012 - 09:57 PM
#5 Guest_R3Ds_*
Posted 03 June 2012 - 10:15 PM
Nice!! Getting this now and will Theme. Love your work Man!
Thank you, hope everyone enjoys it.
R3Ds Themes
Posted 03 June 2012 - 11:02 PM
#7 Guest_BDH_*
Posted 03 June 2012 - 11:05 PM
R3Ds giving us some more RAZR love!! I love the look of it man, very nice job!
Posted 03 June 2012 - 11:59 PM
I really like that theme. :-) badass bro.
#9 Guest_R3Ds_*
Posted 04 June 2012 - 12:20 AM
Gb 2.3.6ICS leak port? :-)
R3Ds Themes
Posted 04 June 2012 - 01:29 AM
Posted 04 June 2012 - 02:41 AM
Posted 04 June 2012 - 03:27 AM
Posted 04 June 2012 - 04:44 AM
You have to be on 181 for this? I didn't know anyone was still on 181. Wish I could go back and use this tho! It looks awesome.
I toyed with ICS .79 but always kept coming back to 181. Didn't want to flash the other ICS stuff since I hate being locked into something. Glad to see this rom is here. Been wanting a deodexed zipaligned 181 with init.d support (so I can get back to my undervolting I did previously).
Thanks again for the rom.
#14 Guest_R3Ds_*
Posted 04 June 2012 - 05:07 AM
R3Ds Themes
- thisismalhotra likes this
Posted 04 June 2012 - 05:17 AM
Posted 04 June 2012 - 05:40 AM
Urban, Just4Tang and iKandee themes coming soon.
R3Ds Themes
OMG ... srsly cant wait .. finally getting my crackflasher fix yay !!
Posted 04 June 2012 - 07:42 AM
Posted 04 June 2012 - 11:03 AM
Posted 04 June 2012 - 11:23 AM
#20 Guest_R3Ds_*
Posted 04 June 2012 - 11:37 AM
Make sure to use the moto launcher. Remove launcher pro using tibu or root explorer, reboot and default launcher is set.looks great! i like it! i LOVE how I can bluetooth with your ROM. but just one thing i did come across, i'm having trouble loading my favorite 20 contacts widget. you know, the widget where there are 4 contacts on home screen that explode into 20? other than that - this will be my daily driver ROM
R3Ds Themes
