Idk, I got the exact same results on Koa
Sent from my DROID RAZR
What music player were you using? Worked perfect with Google Music.
Posted 24 June 2012 - 11:55 PM
Posted 25 June 2012 - 02:58 AM
I have never installed your rom. 75/79/211, with this new bears app you put together. I cannot hear a difference with the options being changed as I use it. The first beats you did works. Not sure why the options are not working. I use the motocast player or google play. I am not dissing your hard work. It come off like it. Respect bro. I am using a player that is not compatible? I also have the beats selected in the media enhanced section.It's funny you say that because it's also baked into the KOA AOKP and KOA ROM and works flawlessly in both. Thanks for your input though!
Posted 25 June 2012 - 05:44 AM
I've tried Google music, motocast, and poweramp. Doesn't show up in poweramp, but I don't think it's supposed to. I've set permissions and tried both flashing and manual.What music player were you using? Worked perfect with Google Music.
Posted 25 June 2012 - 05:49 AM
Posted 25 June 2012 - 06:35 AM
Posted 25 June 2012 - 06:44 AM
Stock 211 installed good with bootstrap, awesome beats app is there, option in settings/sound/music effects to enable. But no difference when playing with eq...
Back to vol+
Posted 25 June 2012 - 06:53 AM
Posted 25 June 2012 - 06:55 AM
Posted 25 June 2012 - 06:59 AM
Sry 4 dble. Hey dont sweat it. I appreciate what you do, have done, and will do lol. Just wanted throw some feedback from a bootstraper lol. I am fear my blade!
Posted 25 June 2012 - 07:34 AM
No that's fine I definitely appreciate the feedback, not getting frustrated with you guys and I'm sorry if it seems like that lol. Just getting frustrated with the Mod haha.
Posted 25 June 2012 - 07:42 AM
Edited by sankyou, 25 June 2012 - 07:59 AM.
Posted 25 June 2012 - 09:27 AM
Posted 25 June 2012 - 09:44 AM
Posted 25 June 2012 - 11:51 AM
Lol, I've tried obvious settings just to hear if it would change. ie, all treble, ridiculous mid scoop..LOL I give up. Works fine for me. What are you guys even changing the settings to? Arre you only playing the music through your phone speaker and saying you don't hear a difference??????
If you are, that's the wrong answer lol.
Posted 25 June 2012 - 12:41 PM
Posted 25 June 2012 - 01:00 PM
So uh.. what is Beats? Just an EQ app or something? Pretty sad that it's software.
Posted 25 June 2012 - 01:47 PM
Posted 25 June 2012 - 02:23 PM
Posted 25 June 2012 - 02:28 PM
Posted 25 June 2012 - 03:00 PM
Success! Finally, lol, on latest Koa. Works great, idk what changed but thanks!For those of you that have success, please post what ROM or leak you are currently on so I can update the OP. Thanks guys!
