[Mod] Beats Audio (Flashable Zip) (6/27/2012)
#141
Posted 21 June 2012 - 03:05 AM
I am fear my blade!
#142 Guest_BDH_*
Posted 21 June 2012 - 10:35 AM
Hey just wondering.. if say someone was in line for a soak of some sort, would having this mod likely hinder the ota?
I am fear my blade!
Not if you unroot. Everyone says to be bone stock but I've installed OTAs before while having 3rd party apps installed. By the way, I got my mail and thank you!!
#143
Posted 21 June 2012 - 03:12 PM
Great! Sorry it took so longNot if you unroot. Everyone says to be bone stock but I've installed OTAs before while having 3rd party apps installed. By the way, I got my mail and thank you!!
I am fear my blade!
#144
Posted 21 June 2012 - 04:50 PM
*9That's really weird, you should have the app in the app drawer. Let me take a look at the updater script and see what I can find.
Anyone else having this issue???
me too no app in the drawer
permissions are set correctly here as well
#145
Posted 21 June 2012 - 05:00 PM
Eclipse 1.3 .173 rooted ...version 4 no dice no app in drawerFor everyone who is having errors, what system version are you on? I'm on .181 running Eclipse 1.3 over the top.
#146
Posted 21 June 2012 - 05:02 PM
link deadFor anyone with issues installing i made a small utility that installs it for you. It requires a rooted phone on any of the ICS Leaks (not gingerbread)
All thanks goes to spc_hicks09 for creating the beats hack and mattlgroff for creating Droid RAZR Utility 1.6 which is what i used to make this utility
404
#147
Posted 21 June 2012 - 05:29 PM
#148
Posted 23 June 2012 - 02:41 PM
#149
Posted 23 June 2012 - 02:43 PM
+1 yeah, I don't get it, it doesn't do anythingI manually added everything and properly set permissions on the apk. Does the other files need any special permissions? The app runs but does not control the sound at all. Can anyone help please?
#150
Posted 23 June 2012 - 02:44 PM
#151
Posted 24 June 2012 - 05:55 AM
But did you get it to affect the sound?Disregard my last comment. I answered my own question lol.
#152
Posted 24 June 2012 - 07:39 AM
Note to portscan:
Edit: This mod DOES affect the speaker and headset sound as much as Beats is want to do.
#153
Posted 24 June 2012 - 12:12 PM
I believe it makes a difference, but I and many others users can't get the settings in beatscontrol to affect the sound.Edit: This mod DOES affect the speaker and headset sound as much as Beats is want to do.
Try changing the eq to something absurd.. does the sound change?
#154
Posted 24 June 2012 - 02:04 PM
#155
Posted 24 June 2012 - 02:47 PM
#156
Posted 24 June 2012 - 07:54 PM
#157
Posted 24 June 2012 - 07:59 PM
#158
Posted 24 June 2012 - 09:13 PM
#159 Guest_BDH_*
Posted 24 June 2012 - 11:31 PM
This mod is a bust. Sad. Does not work.
It's funny you say that because it's also baked into the KOA AOKP and KOA ROM and works flawlessly in both. Thanks for your input though!
#160
Posted 24 June 2012 - 11:49 PM
Idk, I got the exact same results on KoaIt's funny you say that because it's also baked into the KOA AOKP and KOA ROM and works flawlessly in both. Thanks for your input though!
Also tagged with one or more of these keywords: music, beats, audio, ics, gingerbread, dsp manager, beats audio
