[Mod] Beats Audio (Flashable Zip) (6/27/2012)
music beats audio ics gingerbread dsp manager beats audio
381 replies to this topic
#121 claps1775
claps1775
  • 596 posts
Posted 08 June 2012 - 08:29 PM
It does not work on my phone. Has the apk but cannot hear the sound change.
#122 DrDiff
DrDiff
  • 93 posts
  • Twitter:@DrDiff952
  • Google+:DrDiff
  • LocationNorthWest Indiana
Posted 09 June 2012 - 12:07 PM
on GB .181 waiting for the OTA update to ICS.
I understand that If I install under GB i will not get the app.
My question is if I install under GB do I have to re-install after the OTA update, to get the app?
#123 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 09 June 2012 - 05:14 PM
Yes. When you install its update it will wipe system files which includes the beats hack. Just reinstall once ics is up and running
Sent from my ICS Leak RAZR
#124 DrDiff
DrDiff
  • 93 posts
  • Google+:DrDiff
Posted 10 June 2012 - 05:55 AM
I installed and didn't notice any difference through the phone's speaker. But plug in a set of headphones and wow!
I can't wait to play with it on ICS.
#125 farhanito
farhanito
  • 13 posts
Posted 10 June 2012 - 07:54 AM
Sorry, but isn't this the same as Cyanogenmod's DSP Manager?
And yes, changing settings in the Beats control app does nothing
Sent from my XT910 using Tapatalk 2
#126 sreeman
sreeman
  • 68 posts
Posted 10 June 2012 - 09:51 AM
So i did the steps as stated in OP, but i dont see the icon in my app drawer? Went into system/apps re-installed it, rebooted and still nothing, but can open from system/apps. Is it supposed to be like that?
#127 holla
holla
  • 68 posts
  • Locationatlanta,Ga
  • Current Device(s):DNA
Posted 10 June 2012 - 01:12 PM
I had that same problem go inside settings and app scroll to the bottom.it could be disabled like mines was
#128 sreeman
sreeman
  • 68 posts
Posted 10 June 2012 - 07:41 PM
Sorry for the silly question, how do i enable it? i see it at the apps but it was already running. so i forced stop it and now theres no re-enabling LOL!
Now i dont see the beatsapp in the manage apps anymore. LOL!
Re-installed it from /system and now its back on manage apps, but not in drawer..but its enabled. :S
#129 mixerpilot
mixerpilot
  • 36 posts
  • LocationOhio
Posted 11 June 2012 - 07:57 AM
For anyone with issues installing i made a small utility that installs it for you. It requires a rooted phone on any of the ICS Leaks (not gingerbread)
All thanks goes to spc_hicks09 for creating the beats hack and mattlgroff for creating Droid RAZR Utility 1.6 which is what i used to make this utility
Tried this with rooted .209, didn't work. Should it act like it's rooting phone?
#130 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 11 June 2012 - 09:46 AM
Yes that is essentially what it does. I will look into this
#131 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 11 June 2012 - 01:48 PM
I have confirmed this to work on 209.
Check out the new post i made with my utility
Basically you have to use option 4 first to flash the .85 kernel, then run the mod, then flash back the 209 kernel
#132 Nubia1
Nubia1
    JUST A COOL OLD GUY WHO LIKES ANDROID
  • 270 posts
  • LocationCincinnati,Ohio
  • Current Device(s):DROID RAZR MAXX HD/ OG RAZR MAXX
Posted 11 June 2012 - 02:17 PM
Is this for all versions
#133 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 11 June 2012 - 04:13 PM
Yes. Gingerbread does not support the app but all the other files can be used
#134 onemotodroid
onemotodroid
  • 51 posts
  • Twitter:onemotodroid
Posted 14 June 2012 - 06:59 AM
i installed this on .79
after rebooting the beat app did not show up in the app drawer or in setting / app's list
i went into /system/app and installed the beat apps (lite press than install) from there. it is now in my app's drawer
#135 joshuaericjones
joshuaericjones
  • 32 posts
Posted 17 June 2012 - 10:55 AM
Installed fine, but it doesn't do anything? Changing settings doesn't affect the sound, either does changing between BeatsControl and MusicFX in stock sound settings.
#136 hootowlserenade
hootowlserenade
  • 256 posts
  • LocationDavison, MI
Posted 17 June 2012 - 11:23 AM
Which leak are you running? I have the same problem on .79
#137 joshuaericjones
joshuaericjones
  • 32 posts
Posted 17 June 2012 - 11:52 AM
I'm on .211 now, but I tried it on .206 and .84 when I was on those. Same thing each time.
#138 hootowlserenade
hootowlserenade
  • 256 posts
Posted 17 June 2012 - 12:42 PM
I wonder if you are getting the same error as me... if you could go to the stock sound settings (where you select beatscontrol or musicfx) select beatscontrol, click OK... reopen the setting and don't click either one (beatscontrol should still be selected) and just click OK... see if you get a fc from musicfx... if you get that fc, you are experiencing exactly what I am... I just gave up on it...
#139 joshuaericjones
joshuaericjones
  • 32 posts
Posted 17 June 2012 - 03:48 PM
I forgot, that is one difference: I got that same fc on .84 and .206 but I no longer have musicFX fc on .211.
Doesn't seem to affect anything either way.
#140 irtehun
irtehun
  • 13 posts
  • Twitter:irtehun
Posted 19 June 2012 - 05:11 PM
I did this on .211 and MusicFX fc. Can't get it to work. Doesn't change the sounds at all.
Also tagged with one or more of these keywords: music, beats, audio, ics, gingerbread, dsp manager, beats audio
