[Mod] Beats Audio (Flashable Zip) (6/27/2012)
music beats audio ics gingerbread dsp manager beats audio
381 replies to this topic
#101 claps1775
claps1775
  • 596 posts
Posted 07 June 2012 - 04:49 PM
Okay brother, I did as you stated and now rebooting
#102 claps1775
claps1775
  • 596 posts
I see the beats control apk. The ect folder from the beats zip, I put in the/system folder. The files that were in that folder are in the ect folder at the bottom. Not in a folder at all. This okay?
#103 claps1775
claps1775
  • 596 posts
Posted 07 June 2012 - 05:00 PM
So I messed with the apk and I do not hear a difference. I made the bass moderate and set to studio. Hmmm, am I doing something wrong? Where you going by the way. Nice work as well. Thank you.
#104 claps1775
claps1775
  • 596 posts
Posted 07 June 2012 - 05:01 PM
#105 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 07 June 2012 - 05:02 PM
It only seems to work with certain audio apps. Pandora does not, but Google Music does
#106 claps1775
claps1775
  • 596 posts
Posted 07 June 2012 - 05:06 PM
I am using the moto cast tunes apk. I selected the beatscontrol apk in the sound/music effect. It did not force close on me. Still cannot hear a difference.
#107 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 07 June 2012 - 05:25 PM
It should work with any app that DSP Manager does.
#108 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 07 June 2012 - 07:27 PM
For anyone with issues installing i made a small utility that installs it for you. It requires a rooted phone on any of the ICS Leaks (not gingerbread)
All thanks goes to spc_hicks09 for creating the beats hack and mattlgroff for creating Droid RAZR Utility 1.6 which is what i used to make this utility
  • lownslow200sx and XCellFoneSalesRep like this
#109 claps1775
claps1775
  • 596 posts
Posted 07 June 2012 - 08:12 PM
I have it installed fine. I did as Hicks posted to do. Just I cannot hear a change in my sound. I am not sure if I need to wipe all cache or not. Wish it did work. Sad face.....
#110 hootowlserenade
hootowlserenade
  • 256 posts
  • LocationDavison, MI
Posted 07 June 2012 - 10:01 PM
Just tried your zip as a last resort.... when I choose the zip in bootstrap it says installing update then it says installation aborted... wiped cache, dalvik cache, tried it mounting system, then without mounting system... either way produces the same result... installation aborted.... I checked and still no change in the beats control app.... I know that Pandora works with a dsp manager because I used the one that came with eclipse on it and you could tell instantly when you made an adjustment in dsp manager that it was working... I wonder if I need to install dsp manager somehow first? Is there a way to do that on stock ICS?
#111 hootowlserenade
hootowlserenade
  • 256 posts
Posted 07 June 2012 - 10:03 PM
What leak are you running? I'm running .79 and I have the same issue you are having... maybe it doesn't work on .79...?
#112 claps1775
claps1775
  • 596 posts
Posted 08 June 2012 - 03:52 AM
I am running .79 as well.
#113 dimitri407
dimitri407
  • 129 posts
  • Twitter:dimitri407
Posted 08 June 2012 - 04:02 AM
I may be stupid today but I can't seem to figure out how to make this interact with Google Play. Google Play seems to have it's own Equalizer but no option for using another. Am I being stupid today?
#114 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 08 June 2012 - 05:18 AM
I am so sorry if I was unclear. This is not to be used in bootstrap. You download it to your comp and extract it to your desktop and run it just like unstuck ics utility or DROID RAZR utility
Sent from my ICS Leak RAZR
#115 XCellFoneSalesRep
XCellFoneSalesRep
  • 53 posts
  • Twitter:https://twitter.com/XCellFoneRep
  • Google+:http://goo.gl/XgDaW
  • LocationThe Joisey Shore, Nu Joisey
Posted 08 June 2012 - 06:38 AM
Thank you for this utility! I tried doing it the manual way several times and each time, after all the steps, i reboot and she wouldn't boot up, no matter what. Lost everything, several times. Tried the utility once at it worked the 1st time. :)
#116 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 08 June 2012 - 06:47 AM
Glad it worked for you!!!
I just updated the zip file on the link and added a Gingerbread option (it does NOT include the BEATS app since it is not compatible with GB and it fixes permissions for you)
#117 hootowlserenade
hootowlserenade
  • 256 posts
Posted 08 June 2012 - 09:12 AM
The utility didn't work for me... hangs on starting daemon... is it because I'm on the .79 ICS leak? I have all the up to date moto drivers installed... I even installed the 5.7 development drivers to make sure my PC could see the RAZR in any setting...
#118 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 08 June 2012 - 09:19 AM
Sorry about all the confusion. Try going to the new post I made or download from the link above again (I updated it)
#119 Nubia1
Nubia1
    JUST A COOL OLD GUY WHO LIKES ANDROID
  • 270 posts
  • LocationCincinnati,Ohio
  • Current Device(s):DROID RAZR MAXX HD/ OG RAZR MAXX
Posted 08 June 2012 - 09:48 AM
This looks interesting, does everyone like this so far?
#120 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 08 June 2012 - 09:56 AM
I'm loving it :)
Also tagged with one or more of these keywords: music, beats, audio, ics, gingerbread, dsp manager, beats audio
