[Mod] Beats Audio (Flashable Zip) (6/27/2012)
#361
Posted 02 December 2012 - 03:27 PM
#362
Posted 02 December 2012 - 06:45 PM
How do i do that and y is it a bad idea? I know theres an app on the market for beats but i read bad stuff about the app especially if i want to uninstall. so if the app can install it how can i do it manually?
Well you have safestrap, if you put bootstrap on you will brick and simply unistalling safestrap doesn't get rid of everything you need to get rid of to safely move to bootstrap, plus most ROMs are for safestrap.
#363 Guest_BDH_*
Posted 02 December 2012 - 08:00 PM
Also, I am not responsible for anything that happens to anyone's phone who uses bootstrap. Just want to put that out there.....
#364
Posted 02 December 2012 - 08:51 PM
#365 Guest_BDH_*
Posted 02 December 2012 - 09:04 PM
ok then how do i install it manually then without flashing? i dont want to install the beats app because it can't be uninstalled. at least installing manually i can back stuff up that i replace
The Beats app can be uninstalled. Just use a root file explorer and delete the apk. As for installing manually, you'll have to download the zip, extract it, take all the files and put them on your phone making sure that you put each file in its corresponding folder. Then set permissions on every file to rw-r--r--.
Then reboot.
#366
Posted 02 December 2012 - 10:46 PM
#367 Guest_BDH_*
Posted 02 December 2012 - 11:16 PM
Thanks hicks! I couldn't find meta-inf, but it still worked!
Very welcome! Glad I could help!
#368
Posted 19 January 2013 - 06:26 AM
#369
Posted 01 March 2013 - 07:57 AM
Thanx
#370
Posted 01 March 2013 - 02:57 PM
Link is dead can you upload it again?
Thanx
just flash and your good to go
#371
Posted 02 March 2013 - 02:07 PM
thanks but
It's again dead :/
#372
Posted 02 March 2013 - 05:05 PM
thanks but
It's again dead :/
It works just fine, its you... try a different browser or something
#373
Posted 03 March 2013 - 02:30 AM
Funny I couldnt open it yesterday but now it works Thanx but I cannot get it work with poweramp. It works with stock without problem.
Well thanx again.
#374
Posted 21 April 2013 - 06:26 AM
I tried installing it, and nothing. Don't see it installed, don't see it listed under Settings>Apps>All, etc...
#375
Posted 28 April 2013 - 10:10 AM
Curious will this work on Bionic Stock JB?
#376
Posted 28 April 2013 - 03:56 PM
Well thanx again.
I realize this is a slightly old post....PowerAmp doesnt use External EQ's
#377
Posted 28 April 2013 - 06:18 PM
#378
Posted 20 May 2013 - 10:48 PM
Nothing Here The file you're looking for has been deleted or moved
#379
Posted 27 May 2013 - 10:21 AM
#380
Posted 11 June 2013 - 04:19 PM
Also tagged with one or more of these keywords: music, beats, audio, ics, gingerbread, dsp manager, beats audio
