[Mod] Beats Audio (Flashable Zip) (6/27/2012)
music beats audio ics gingerbread dsp manager beats audio
381 replies to this topic
#321 androidlearner
androidlearner
  • 904 posts
  • LocationPeoria, AZ
Posted 14 August 2012 - 11:23 AM
I tried flashing this using safestrap and when I tried to reboot it just sat on a black screen and has been sitting on the screen for about 10 minutes. I can do a battery pull and get back into safestrap and recovery but cant get past this black screen is there any ideas or help? My phone is unusable.
Do you have a backup you can restore? Sounds like something went wrong on your flash.
Sent from my Droid Razr Maxx Arctic .215
#322 smeekteek
smeekteek
  • 224 posts
Posted 23 August 2012 - 05:25 AM
I'm on Dualcore ROM. After following instructions, I see it in the system file but not in the app drawer.
#323 Guest_BDH_*
Guest_BDH_*
Posted 23 August 2012 - 08:27 AM
If dualcore has DSP Manager then you need to uninstall that then reboot.
Sent from my Unlocked Rezound using Tapatalk 2
#324 smeekteek
smeekteek
  • 224 posts
Posted 23 August 2012 - 08:31 AM
I tried that. it still didnt show up in the app drawer. Thanks for the response.
#325 Guest_BDH_*
Guest_BDH_*
Posted 23 August 2012 - 10:10 AM
Now that it's deleted, try wiping cache and dalvik, then flash the zip again. Should work after that.
#326 smeekteek
smeekteek
  • 224 posts
Posted 23 August 2012 - 11:08 AM
I'm not seeing it still. Do i need to go into the system file and execute the apk?
I do have an app called MusicFX. Could that be the culprit?
#327 Guest_BDH_*
Guest_BDH_*
Posted 23 August 2012 - 12:45 PM
Most likely, get rid of that and let me know.
Sent from my ADR6425LVW using Tapatalk 2
#328 smeekteek
smeekteek
  • 224 posts
Posted 24 August 2012 - 06:16 AM
I erased the MUSICFX and reflashed the zip file. The phone got stuck on the boot animation. It does the same thing when I install the Beats app from the market. i guess Dualcore ROM doesn't like this app or something.
#329 smeekteek
smeekteek
  • 224 posts
Posted 26 August 2012 - 10:26 AM
I finally got my phone to boot up after flash and beats is still not in the app drawer. But, I noticed that "Music FX" reinstalled itself.
#330 LauraSakura
LauraSakura
  • 148 posts
  • Twitter:laurasakura
  • LocationYoungstown, OH
Posted 27 August 2012 - 08:15 AM
has anyone flashed this on Jelly Bean? (CM10 Unofficial Alphas)
CDMA RAZR MAXX - Running Android 4.1.1 JB - CM10 Unofficial Alpha
#331 Guest_BDH_*
Guest_BDH_*
Posted 27 August 2012 - 09:07 AM
I haven had anyone say they did but it should still work on JB too.
#332 MrC1122
MrC1122
  • 8 posts
  • Google+:MrC1122
  • LocationIndiana
Posted 27 August 2012 - 01:55 PM
yes, it does work on jb...at least it does on stock jb (nexus 7)
I don't know karate...but I know kaRazr!
#333 extirpate
extirpate
    Just flash it..
  • 163 posts
  • LocationSacramento, Ca
  • Current Device(s):Dr. Device
Posted 07 September 2012 - 12:29 PM
I can't get the app to show. Using stock ICS .211. I read first 6 pages then skipped to last 2 in forum. Didnt see anything that i was doing wrong. No other sound app. Just removed bloat. Im using safestrap. everything flashed fine. Pasted the ro.semx.xloud.... ect file where it needed to be then rebooted. still no DSP app. Tried exc. from zip and nothing happens. Im not sure if the audio is different. Should i hear a differnce without his app installed?
#334 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 07 September 2012 - 06:02 PM
did you accidentally remove/freeze the stock DSP apk. Or is the stock DSP manager enabled? If so make sure everything is unchecked. Here is a link to my beats file. Install, place on external sd , boot into safestrap or stock recovery then flash.
Make It Your Own
#335 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 07 September 2012 - 06:05 PM
The app looks like this wben you open it
  58.09KB   23 downloads
Icon looks like this top left
  30.29KB   22 downloads
Make It Your Own
#336 Mikegold28
Mikegold28
  • 21 posts
Posted 07 September 2012 - 07:30 PM
This is my first time rooting my phone.
Fisrt: Thanks for all the Beats, but im not sure where where to go to add this:
ro.semc.xloud.supported=true
persist.service.xloud.enable=1
ro.service.swiqi.supported=true
persist.service.swiqi.enable=1
#337 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 07 September 2012 - 07:33 PM
You shouldn't have to add those anywhere. Its just a flash file.
Make It Your Own
#338 Mikegold28
Mikegold28
  • 21 posts
Posted 07 September 2012 - 07:36 PM
Thanks!
#339 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 07 September 2012 - 07:46 PM
Let me know if it works out
Make It Your Own
#340 extirpate
extirpate
    Just flash it..
  • 163 posts
Posted 07 September 2012 - 10:44 PM
Not that i can tell. I got rid of some motocast services in Titanium. I looked back thru Titanium and don't see anything re: DSP. What's the stock DSP named? I DL'd the zip you posted. Flashed it w/o wiping cache & delvik and after wiping both. Using safestrap 2.0. Says files flashed successfully. Disabled safe system and reboot. Nothing in app drawer. Went in thru root explorer and try and install the apks from the zip but that didn't work as expected. Not sure what else to try.
Also tagged with one or more of these keywords: music, beats, audio, ics, gingerbread, dsp manager, beats audio
