Worked great using Bootstrap....on Stock 211
+1
Works perfectly for me. This with projectM set as my live wallpaper, turns my razr into one awesome music machine.
Posted 26 June 2012 - 02:20 PM
Posted 26 June 2012 - 02:52 PM
Posted 26 June 2012 - 03:31 PM
Okay sir captian Hicks! I just installed bootstrap and then flashed your newest beats. So, lets take a peak. I wiped both cashe and mounted system............ Update....I still got nothing. I am on stock rooted 211. Installed ics bootstrap. Rebooted into recovery and mounted system, wiped both cashe, and then installed the beats apk. What am I doing wrong? I have never heard beats on my phone. Sadden. I so want to hear Cher Lloyds, Want U back song...............Update, booted into recovery. Wiped all cashe and installed beats from sd card. I still have nothing. I unselected the effects for the stock effects and selected beats. Also cleaned cashe on beats. O well. Now how do I uninstall bootstrap with outdoing a full wipe?
Posted 26 June 2012 - 03:34 PM
Posted 26 June 2012 - 03:40 PM
Posted 26 June 2012 - 03:41 PM
Hmm so I need safe strap? How do I get rid of bootstrap with out fastbooting. I cannot do that right now.
Posted 26 June 2012 - 03:51 PM
Posted 26 June 2012 - 03:52 PM
Posted 26 June 2012 - 04:35 PM
Here you go Aixelsyd...
You may have to remove DSP2.0 or beats control to install it. but you can try installing it first. I`ve had it go both way depending on the rom I was on.
Posted 26 June 2012 - 07:42 PM
Posted 26 June 2012 - 08:01 PM
Thanks again, this sounds great. But does anyone know which apps this works with? I hear it on play music and Apollo... but is there anyway to get poweramp to recognize it? Other beats mods work with power amp, so I was wondering I'd there is a particular file or something PA looks for.
Posted 26 June 2012 - 09:30 PM
Posted 27 June 2012 - 05:33 AM
Posted 27 June 2012 - 05:41 AM
Posted 27 June 2012 - 05:42 AM
dont edit build.prop????
ro.semc.xloud.supported=true
persist.service.xloud.enable=1
ro.service.swiqi.supported=true
persist.service.swiqi.enable=1
Posted 27 June 2012 - 05:43 AM
Posted 27 June 2012 - 05:48 AM
Posted 27 June 2012 - 05:50 AM
Posted 27 June 2012 - 05:55 AM
In all xda mods to enable the function to edit the beats build.prop with these commands.
Sorry I speak little English
Posted 27 June 2012 - 05:58 AM
