[Mod] Beats Audio (Flashable Zip) (6/27/2012)
#181
Posted 25 June 2012 - 03:46 PM
had to install all the files using the manual method
it worked after the first reboot
#182
Posted 25 June 2012 - 03:49 PM
#183
Posted 25 June 2012 - 03:52 PM
#184 Guest_BDH_*
Posted 25 June 2012 - 04:01 PM
Do you have to have bootstrap/safestrap to use this?
No but you would have to put all the files in your phone manually and believe me, you do not want to have to do that lol.
#185
Posted 25 June 2012 - 04:14 PM
#186 Guest_BDH_*
Posted 25 June 2012 - 04:17 PM
Ugh! Just tried the new flashable zip in the OP... still no beats audio control! I don't get it... I have tried the manual method, Alex.Abraham's utility, and now the flashable zip.... all to no avail... I can open the beatscontrol app but the settings do nothing to audio streamed on phone speaker, headphones, or my Bluetooth headphones (which would rock because the stock audio settings will not adjust for Bluetooth headphones) I am getting frustrated that others are profiting from this mod... I am stock rooted .211 with no bloat frozen... why can't I get this mod to work?
I wish I could figure it out man, I updated the OP for ROMs that this is comfirmed working on and Stock 211 has been confirmed to work.
#187
Posted 25 June 2012 - 04:44 PM
Hicks, are you able to hear the difference with the beats app when you chance rje setting? If you do, what can I be doing wrong?I wish I could figure it out man, I updated the OP for ROMs that this is comfirmed working on and Stock 211 has been confirmed to work.
#188
Posted 25 June 2012 - 04:46 PM
#189
Posted 25 June 2012 - 05:28 PM
I had your problem too, I tried everything. Finally got it to work after wiping everything, formatting system, and fixing permissionsHicks, are you able to hear the difference with the beats app when you chance rje setting? If you do, what can I be doing wrong?
#190
Posted 25 June 2012 - 06:44 PM
#191
Posted 26 June 2012 - 03:39 AM
I can confirm that the new update is working on STOCK .211 (no safestrap/bootstrap) now. The contents of the zip changed and the app is new now. I manually pushed all the files and properly set permissions. I am now listening to my phone and the bass is blowing my mind!
I'm still hearing no love. On Eclipse, used the flash/zip now in OP, twice. Wiped cache/dalvik both times. The app is not showing up in app drawer, and neither "beats" or DSP are making any difference to the sound at all. Any ideas on what to try next?
Should I be wiping cache/dalvik on both safe and non-safe side? This one has me stumped.
Proud father of a US Marine
#192
Posted 26 June 2012 - 06:05 AM
This is similar to what I experienced as well. If you navigate to /system/apps - you will see both apks. When I try to install them - I get an error that the signatures do not match.I'm still hearing no love. On Eclipse, used the flash/zip now in OP, twice. Wiped cache/dalvik both times. The app is not showing up in app drawer, and neither "beats" or DSP are making any difference to the sound at all. Any ideas on what to try next?
#193
Posted 26 June 2012 - 06:16 AM
Im on Ikream Ics 6.16.2.11 Deodexed Rom V1.0 R3Ds
And nothing. The apps are in my system/app but it also wouldnt let me reinstall them.
#194
Posted 26 June 2012 - 08:27 AM
Just some feedback. Its not a big deal if i get this working or not. Just thought it would be cool to try out.
Same here, same Rom. I see the app in the system app folder, but not the app drawer.
#195
Posted 26 June 2012 - 08:48 AM
ro.semc.xloud.supported=true
persist.service.xloud.enable=1
ro.service.swiqi.supported=true
persist.service.swiqi.enable=1
#196
Posted 26 June 2012 - 10:09 AM
#197
Posted 26 June 2012 - 12:59 PM
#198
Posted 26 June 2012 - 01:12 PM
Sort of related... I have no luck with either beats control or DSP manager 2.0 as far as modifying sound with settings... nuke those and try dsp manager 1.0 and boom the changes make a difference... I still can`t figure out why 1.0 works and the later version and beats control do no...
For me to run a test mind posting the 1.0 DSP Manager you used
#199
Posted 26 June 2012 - 01:42 PM
Yeah let me find a home for it... It works everytime on slacker radio, where neither 2.0 or Beats control will .... I`ve been going in circles through every method and several roms trying to figure out why...
#200
Posted 26 June 2012 - 01:49 PM
Also tagged with one or more of these keywords: music, beats, audio, ics, gingerbread, dsp manager, beats audio
