[Mod] Beats Audio (Flashable Zip) (6/27/2012)
music beats audio ics gingerbread dsp manager beats audio
381 replies to this topic
#1 Guest_BDH_*
Guest_BDH_*
Posted 02 June 2012 - 10:14 AM
POPULAR
Works on ANY ICS VERSION!!!
Here everyone! I got bored today and made this. It is a flashable zip of a complete and full Beats Audio installation. This zip file contains every single Beats file and is up to date.
It also contains a modified DSP Manager app to work with the Beats files.
Requirements for flashing:
Be on ICS, or Gingerbread but how many of us are still on GB really?
Rooted
Safestrap OR Bootstrap
**DO NOT TRY TO INSTALL THE APP AS A REGULAR APP, FOLLOW THE INSTRUCTIONS**
1. Download the zip file and place it on your sdcard.
2. Reboot into recovery
3. Wipe Cache Partition
4. Wipe Dalvik Cache
5. Flash Beats Audio
6. Reboot
After flashing, add the following lines to your build.prop file located in /system
This has not been confirmed to flash with Bootstrap but it should still work.
Confirmed Working on the following ROMs:
Stock 211
KOA ROM
KOA AOKP
Arctic ROM
Black Widow ROM
Eclipse ROM
Beats Audio for RAZR:
Edited by spc_hicks09, 27 June 2012 - 05:59 AM.
  • mugsy77, jb_alphamale, DTrainMusikVein and 28 others like this
#2 shizumie
shizumie
  • 650 posts
  • Google+:shizumie@gmail.com
  • LocationHortens, Ga
  • Current Device(s):DNA
Posted 02 June 2012 - 10:23 AM
Dwnloading! Thanks. Will report back!
I am :ph34r: fear my blade!
#3 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 02 June 2012 - 10:24 AM
Thanks for this!! If I already installed the previous beats.zip you posted, will this overwrite it? Or, do I need to uninstall it somehow first?
#4 Guest_BDH_*
Guest_BDH_*
Posted 02 June 2012 - 10:26 AM
Very welcome! Yes please let me know.
You're good to go, it will overwrite all the previous files. :)
#5 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 02 June 2012 - 10:31 AM
Awesome, thanks for the prompt response. Liked! ;) Downloading now & will report back. So just wanted to confirm before install: Based on the OP it appears there's no need to mount system this time?
#6 Guest_BDH_*
Guest_BDH_*
Posted 02 June 2012 - 10:33 AM
Correct, updater-script does that for you :)
  • PillClinton likes this
#7 shizumie
shizumie
  • 650 posts
just wanted to add first reboot took 4 E V E R !
LOL
I actually thought i had soft bricked or something.
all good though lol
#8 DrDiff
DrDiff
  • 93 posts
  • Twitter:@DrDiff952
  • Google+:DrDiff
  • LocationNorthWest Indiana
Posted 02 June 2012 - 10:36 AM
Will this work on any ROM? GB or ICS?
#9 shizumie
shizumie
  • 650 posts
Posted 02 June 2012 - 10:42 AM
So, I must admit, i can actually tell a difference this time around. I'm still not really seeing the eq adjustments, but i can def tell a audio difference this time! Gold star for Hicks for today for sure!
#10 Guest_BDH_*
Guest_BDH_*
Posted 02 June 2012 - 10:49 AM
Yes
#11 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 02 June 2012 - 10:50 AM
Feeling like a noob here for asking this but... How do I access the modified DSP manager app? I don't see it in the drawer after installation & reboot. However, the BEATSControl.apk is in /system/app.
#12 Guest_BDH_*
Guest_BDH_*
Posted 02 June 2012 - 10:53 AM
Odd, should be in the app drawer, named Beats Control.
Can you check that permissions are rw-r--r-- ?
#13 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 02 June 2012 - 10:57 AM
Permissions are set correctly. I tried clicking on the app to see if it would give me the usual prompt ("This is a system app, do you want to replace it?") but instead, I got a parse error ("There is a problem parsing the package"). This is the same thing that happened when I tried installing the Beat Controls APK manually, prior to you releasing this. Not sure if it matters but I am running Eclipse 1.3 on the .181 base.
#14 knghts50
knghts50
  • 199 posts
  • Google+:kevin.page3
  • LocationCopperas Cove, TX (Fort Hood)
Posted 02 June 2012 - 10:58 AM
Thanx hicks.
Taptalk from my Droid Razr Maxx with Beats Audio
#15 Guest_BDH_*
Guest_BDH_*
Posted 02 June 2012 - 11:02 AM
That's really weird, you should have the app in the app drawer. Let me take a look at the updater script and see what I can find.
Anyone else having this issue???
#16 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 02 June 2012 - 11:04 AM
Thanks for looking into it! I just re-wiped cache/dalvik & re-flashed. I'll let you know if anything changes. It's rebooting now.
Edit: Same result, still a no-go for me.
#17 knghts50
knghts50
  • 199 posts
Posted 02 June 2012 - 11:07 AM
@ hicks i just reflashed this new version its optimizing apps ill let you know if i have issuse
#18 Ragarm
Ragarm
  • 6 posts
Posted 02 June 2012 - 11:09 AM
Which recovery did y'all use? I'm on ICS .79
#19 joeyx2
joeyx2
  • 159 posts
Posted 02 June 2012 - 11:12 AM
Same problem with no beats control app. Permissions are correct, on 181. Says problem parsing when I try to install from root explore.
#20 jb_alphamale
jb_alphamale
  • 251 posts
Posted 02 June 2012 - 11:15 AM
Sweet. It was the time for somebody to do this. Yayyy!!
Thank you.
Also tagged with one or more of these keywords: music, beats, audio, ics, gingerbread, dsp manager, beats audio
