My bad, I didn't realize all that, sorrywhy suprised...MIUI can't use all the libs that CM9 and AOKP haves. second you are wrong..dhacker AOSP rom has all the same issues. that why he pulled it for now. it is the base i am using. he knows these issues are there. i am trying to fix the base before i can implement the changes into MIUI. and last thememing is not a issue those are things that MIUI needs to work on. Most themes in the theme manager are from GB builds...they need to updated by the themer for ICS. if you try looking at miuithemes.com u may find a couple themes that have status bar changes.
[Rom][Razr - Cdma] Miui-V4 Beta For Ics Kernel (6/29/12)
#41
Posted 15 June 2012 - 07:51 AM
#42
Posted 15 June 2012 - 10:01 PM
#43
Posted 17 June 2012 - 12:36 PM
Keep up the great work with all of this.
- 0rion_black likes this
#44
Posted 26 June 2012 - 09:32 AM
#45
Posted 26 June 2012 - 10:21 AM
- Erp likes this
#46
Posted 26 June 2012 - 10:25 AM
Have most of the other issues been resolved then? If so, I can't wait to run this. I've never ran MIUI but everyone raves about it and it looks slick.i have it switched over to the moto ICS .211 base..the only thing that isn't working right is data...everything else works. the data is 1x thats what i get. a tester said he got 3g but until he rebooted. so that is where i am stuck.
#47
Posted 26 June 2012 - 10:33 AM
So your saying that this does not in fact work with the .211 OTA?. And how is your port of the 910 comming, i follow your thread on androimiui.com and cant wait to see the new miui
#48
Posted 26 June 2012 - 02:46 PM
all the issues are fixed since i changed to Moto ICS .211 as base for MIUI port form Xt910 official builds. bluetooth works, blur camera is in the rom for full functionality, framework has both sd card mounted, they changed the file explore app to read both sd card...its that i can't get 3g or 4g data myself.Have most of the other issues been resolved then? If so, I can't wait to run this. I've never ran MIUI but everyone raves about it and it looks slick.
#49
Posted 26 June 2012 - 02:48 PM
it works...it just has the issue in the op...the port is like i state one post up...trying to figure a way to get 3g nd 4g dataSo your saying that this does not in fact work with the .211 OTA?. And how is your port of the 910 comming, i follow your thread on androimiui.com and cant wait to see the new miui
#50
Posted 26 June 2012 - 02:53 PM
Ok. I tried it earlier today and it looked great but i could not get data after toggling, was there something else i should of done or should i just pipedown and be patient?
#51
Posted 26 June 2012 - 03:29 PM
That's impressive. It's a shame data isn't fully working yet. Maybe there's some clues in other AOKP/CM9 builds that will help get data? I'm tempted to flash this but KOA AOKP is treating me very well with everything working, including 4G data on boot and every subsequent boot thereafterall the issues are fixed since i changed to Moto ICS .211 as base for MIUI port form Xt910 official builds. bluetooth works, blur camera is in the rom for full functionality, framework has both sd card mounted, they changed the file explore app to read both sd card...its that i can't get 3g or 4g data myself.
#52
Posted 27 June 2012 - 04:12 PM
#53
Posted 27 June 2012 - 05:00 PM
the data is not yet working with the .211 build yet, we are all patiently waitingis it suppose to say NO SERVICE in the notification bar even after i toggle and have data? how do i get rid of it? also there are some things that are still in Chinese, my notifications in my lock screen (sms) for example
#54
Posted 29 June 2012 - 05:43 AM
I have moved my work to www.miuiandroid.com und the Motorola Razr.
- XCellFoneSalesRep likes this
#55
Posted 29 June 2012 - 08:27 AM
#56
Posted 29 June 2012 - 02:53 PM
#57
Posted 29 June 2012 - 04:18 PM
So the only issues are data right now? SD cards are reading correctly?
Yes both sdcards r read by the system...only issue is data
#58
Posted 01 July 2012 - 04:22 AM
Sent from my Razr Maxx using TapaTalk
#59
Posted 01 July 2012 - 04:49 AM
#60
Posted 01 July 2012 - 05:30 AM
i am looking for help from the right people...this rom is not based off AOSP..it is Based off the Moto ICS build .211 i believe i need to edit setting.apk, phone.apk and framework.jar. not to sure what i am looking for though to get data to work right.Skiwong. Are you still developing this? Why not get with the devs for AOKP and other AOSP based safe strap roms to see if they can get the right files for you get data working.
Also tagged with one or more of these keywords: miui, miui rom, ICS Leak
