[Rom][Razr - Cdma] Miui-V4 Beta For Ics Kernel (6/29/12)
miui miui rom ICS Leak
117 replies to this topic
#1 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 01 June 2012 - 04:11 PM
Here is the MIUI for ICS leak build.
MY MIUI port is moving to MIUIandroid.com that is where u can find this rom now
HUGE Thank goes out to:
Hashcode for his knowledge and skills
STS-Dev-Team for the awesome contribution for the Moto phones
DroidTh3ory
ANY DEV working hard to make roms and awesome Apps
DROIDRZR.com for a nice site tou call home
Must be on ICS LEAK BUILDS FOR THIS TO BOOT. ANY leak.
changelog:
intial release
update 2.6.1
Fix some applications, pressing the back key player gif results in locking
Remove the "Disable" button to disable the system applications on app info page to prevent incorrectly shutting down core services which may lead to stability problems
Optimise light-sensor strategy to tackle screen lighting issues
Optimise (CDMA) call ended still shows the green return to call information
Added support for displaying music spectrograph animations
Optimisation without SIM card will display the phone in Airplane mode
Optimisation of lock screen to provide 720P HD support
NEW Allow to show / hide system FC error messages (See developer options for further details)
fix widgets showing on desktop
New Monitor apk look
Please download superuser app from Market-forgot to fix
6/8/12
update to 2.6.8
fix T cdma64 to Verizon Wireless
Optimisation - when adjusting the clock minute selection, the clock does not automatically add / subtract
New call, new call reminder supports notification tone, can also be set up with prompts e.g.
New functions for stopping current program (press return key) with a longer response time
Add support for majority of original factory settings
etc
6/15/12
update to 2.6.15
Optimized 12-hour time-phased by the "AM / PM" to "morning, noon, afternoon, evening, and midnight,
Optimisation of third-party calling, allow the proximity sensor to turn on or off the screen
Fix in some case the wrong session is displayed from the search results page
Optimisation of desktop frame rate
Fix problems with gallery library FC issues
Optimisation of SMS keyword (spam) filtering rules
etc
* Here is a link to Full MIUI changelog, some changes don't pertain to are phone *
READ THIS:
please do a wipe data, wipe cache and wipe dalivik cache
Safestrap for now, i have not tested it on bootstrap yet
You don't have to install GAPPS they are include
Known issue in the Rom
  • data on boot- need to toggle radio to get data
  • panaroma camera not loading
  • 3g only, at least that what i found
  • facelock not working
  • external sdcard not mounting
  • camcorder doesn't start.
  • bluetooth?
Release:
MIUIv4_2.6.1_leak:
link:
MIUv4_2.6.8_leak:
link:
md5: a63b22ceb8a32000c03504b1ab8dbd55
MIUIv4_2.6.15-leak
link:
MIUIv4-2.6.29
link:
  • XCellFoneSalesRep likes this
Lets the sun and the moon collide! eclipserom.com
#2 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 01 June 2012 - 04:12 PM
SwitchsdICS.zip
this a zip so you can flip the storages, the external sdcard as primary (the storage MIUI can read)
link:
Change T-CDMA64 to Verizon Wireless
link:
#3 jamminjon82
jamminjon82
  • 610 posts
  • Twitter:@jamminjon82
  • LocationGloucester, VA
  • Current Device(s):LG G2, Moto X, Kindle Fire 2,Razr M, Nexus 7, Acer A100
Posted 01 June 2012 - 04:29 PM
Nice! Will check this out tonight
Sent from the bottom of my fart
#4 (TSON)
(TSON)
  • 529 posts
Posted 01 June 2012 - 05:01 PM
OH LORD YES
#5 _base2
_base2
  • 810 posts
Posted 01 June 2012 - 05:36 PM
OH LORD YES
OH HELL YES.
You day man Skiwong!
[ ...paths? ... where we're going we don't need... paths. ]
[ sent from _base2 ]
#6 uberbdon
uberbdon
  • 367 posts
Posted 01 June 2012 - 06:05 PM
3G only?! f%$k yeah!
  • tankdroid likes this
#7 Muteki
Muteki
  • 132 posts
Posted 01 June 2012 - 07:29 PM
I want this rom so bad with it worked 100%. I cant toggle radio to get data. It never works!
#8 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 01 June 2012 - 07:40 PM
Great job on this rom! Only thing not working is the things in the bug list. I actually get data on boot however.
Sent from my full_spyder using Tapatalk 2
#9 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 02 June 2012 - 04:00 AM
hey man., i get data when you toggle gsm only then got to cdma only..it should start turning on 3g services and switch right to gsm/cdma when it start to turn to 3g signal...and it should boot data in..
#10 Muteki
Muteki
  • 132 posts
Posted 02 June 2012 - 06:56 AM
Ill give it another go just for you. :)
#11 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 02 June 2012 - 07:47 AM
I had a issue of phoneinfo, texting, and simuihelper crashing after a fresh install with data/cache wipe. Tried 3 times with same results. I have a second razr which I installed on which didn't have this issue and the only difference was the second don't have a sim. I stuck my sim into the second one and data worked fine so I installed on my first razr without the sim in and booted up. Once I was fully booted in, I turned the phone back off, inserted the sim, and rebooted. Now data works on the the first phone as well.
#12 DroidAddict101
DroidAddict101
  • 259 posts
  • LocationBinghamton
Posted 02 June 2012 - 08:08 AM
You are the man skiwong. Can't wait to try this later
#13 theonlycosmic
theonlycosmic
  • 470 posts
Posted 02 June 2012 - 04:17 PM
If I remember correctly you can't have two phones using the same sim number like two phones on one data plan both activated. It will give you errors and such. You should just stick to one sim card for both phones.
#14 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 02 June 2012 - 05:44 PM
I think you missed the meaning of my whole post. It has nothing to do with the sim and my service.
My process was....
1. format /system
2. wipe data/cache/dalvik
3. install miui update
4. reboot
5 unlock phone and things crash.
6 shutdown and remove sim card
7 format /system
8 wipe data/cache/dalvik
9 install miui update
10 reboot
11 unlock phone and no crashes
12 shutdown and put sim back in
13 reboot and unlock phone - Data/Phone work
14 reboot and try 1 - 4 again with sim in - Same results as 5 things crash.
So for me on 2 seperate phones I had to wipe everything and install then boot without the sim in then shutdown and insert sim for them reboot for the data/phone to work.
#15 0rion_black
0rion_black
  • 17 posts
  • Twitter:0rion_black
  • Google+:busablack
  • LocationUnion, NJ
Posted 03 June 2012 - 04:26 AM
Has anyone had trouble with the theme manager? I have tried multiple themes and the manager states that the new theme is applied, but it is still the stock green theme.
Updated: attained root and that cleared up the problem with the themes not changing..
#16 XCellFoneSalesRep
XCellFoneSalesRep
  • 53 posts
  • Twitter:https://twitter.com/XCellFoneRep
  • Google+:http://goo.gl/XgDaW
  • LocationThe Joisey Shore, Nu Joisey
Posted 03 June 2012 - 06:52 AM
OMG, thanks Ski! My hopes, dreams, and prayers have been answered :):):) If i can help out in any way, please feel free to ask :)
#17 XCellFoneSalesRep
XCellFoneSalesRep
  • 53 posts
Posted 03 June 2012 - 10:37 AM
Time Out :
Do all your MIUI builds have dual signal bars and is there or will there be a fix for this? :(
#18 (TSON)
(TSON)
  • 529 posts
Posted 04 June 2012 - 05:26 AM
All current ICS MIUI builds have dual bars when you're on 3G.
#19 tucstwo
  • Google+:tucstwo@gmail.com
Posted 04 June 2012 - 06:13 AM
Damn I wish this rom didn't have so many major issues cuz ive been waiting so long for it to get updated to work on the actual ICS kernel. I'm gonna be watching this closely. Once 4g and the sd card bugs are gone I'm on this. I'm so happy to see progress with MIUI, I had this on my DX, the ginger bread version and man do I miss it.
#20 CaptainKn0tz
CaptainKn0tz
  • 63 posts
Posted 04 June 2012 - 03:34 PM
+1 to everything g u said word for word lol. Also had on my DX and that ROM was a beast! Everything worked awesome! Can't wait for this to be fully up and running on the Razor!
~Sent from my Droid [R]
Also tagged with one or more of these keywords: miui, miui rom, ICS Leak
