[Rom][Razr - Gsm] Fts V2.2[Rc] V2.3[Ex] [Xt910]
10 replies to this topic
#1 FrAsErTaG
FrAsErTaG
    Developer
  • 8 posts
  • Twitter:frasertag
Posted 18 December 2011 - 09:31 PM
(Frasertag System)
Posted ImagePosted ImagePosted Image
Original System Size 216mb
My System Size 123mb
Removed
Most of the Moto bloat (there is still some services that I was not sure so left them in)
Blur Home Screen
Modded
Rooted
Deodexed
Boot Animation
Battery %1
Busybox
Ad blocked host file
Theme (Manual and UOT)
Genie Widget smoked
Zip Aligned all system apps
New Market
Notification Toggles[/indent]
Added
ICS Style Launcher Pro
Gallery 3D
ICS Music
SEMC Calendar
LightFlow
Install Instructions
PLEASE FOLLOW CORRECTLY
Download and Install CWM on boot from
NANDROID
Copy rom to external SDCARD
WIPE FACTORY RESET (From CWM)
Install ZIP from Sdcard
After flashing Reboot
During initial Setup, Select Always use Launcher Pro when Prompted
You May get a Moto Force Close error, Just Ignore
AFTER INSTALLATION IS COMPLETE, GOTO SETTINGS -> Accessibility > enable Accessibility option, Enable Lightflow
IF COMING FROM V2.0 PLEASE WIPE
STABLE DOWNLOAD
EXPERIMENTAL DOWNLOAD
Thanks to
Me - Themed ICS Launcher Pro, Modded Rom
kholk - Various Hacks, Organizing the Forum
shady_lanem - Deodexed Rom, Arctic Rom (Script ideas), Theme help, Services.jar, Widget Toggles Help
J.Y.Daddy - CWM on Boot
Montalbert - For allowing me to use his .png's for the theme
Doomlord - Root Expliot
  • opensourcefan and egeez32 like this
#2 B_ren
B_ren
    News Crew
  • 48 posts
  • Twitter:B_ren8
  • Google+:www.gplus.to/bren
  • LocationOttawa
Posted 19 December 2011 - 03:56 PM
looks good, will have to give this a go as soon as I have some time to load it
#3 J.Y.Daddy
J.Y.Daddy
  • 23 posts
  • Twitter:J_Y_Daddy
  • Google+:Kevin Song
Posted 19 December 2011 - 04:25 PM
It looks good!
By the way, is this rom base on GSM? CDMA?
Sadly, I can't use this rom. My razr is UMTS_Spyder. :(
But, cheers for your work! ;)
#4 iXiao
iXiao
  • Twitter:Cesarxiao
Posted 19 December 2011 - 05:17 PM
I think this is based on GSM.
#5 FrAsErTaG
FrAsErTaG
    Developer
  • 8 posts
  • Twitter:frasertag
Posted 19 December 2011 - 08:01 PM
Yes it is from GSM Source and made for GSM XT910
#6 psy
psy
  • 7 posts
Posted 23 December 2011 - 11:51 PM
Will this rom work on a razr with system version en.AU?
I've rooted my razr and installed safestrap but all the roms i attempt to flash wont boot up. Screen just goes black after splash screen :blink:
#7 DroidRazrAZ
DroidRazrAZ
  • 198 posts
  • Twitter:konellaz
  • Google+:konellaz@gmail.com
  • LocationPDX 2 PHX
Posted 24 December 2011 - 12:53 AM
I'm in no way shape or form a dev or claim to be I learn by trial and error. With no SBF it creates a need to crackflash. So there is no way possible this would actually boot if i installed using Hashcode's SafeStrap?
#8 Naruyasha
Naruyasha
  • 6 posts
  • Twitter:https://twitter.com/#!/naruyasha
  • LocationPuerto Rico
Posted 21 January 2012 - 09:24 PM
will this work on a RAZR with the mobile provider from Claro Puerto Rico?
System version: 651.73.250.XT910.AmericanMovil.en.01
#9 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 22 January 2012 - 12:27 PM
This rom looks sweet from the screenshots! Any chance it will ever be ported to the CDMA Razrs?
#10 FrAsErTaG
FrAsErTaG
    Developer
  • 8 posts
  • Twitter:frasertag
Posted 22 January 2012 - 11:40 PM
Perhaps when I get time, My Xperia Play rom turned into a CDMA/GSM rom after some time and work..
#11 razrlen
razrlen
  • 17 posts
Posted 02 March 2012 - 12:32 PM
Does it works on 2.3.6 or I should be on 2.3.5 651.167.** Retail.en.EU
