[PATCH]GSM Fix for XT912 CM10.1.2, CM10.2
#21
Posted 16 August 2013 - 01:38 PM
XT912 on CM10.2
#22
Posted 27 August 2013 - 09:54 PM
THANXXXXX A MILLION BRO finally i can use my internet!!!!!!!! PHEWW!!!!!!!!!!!!
- neoXank likes this
#23
Posted 24 January 2014 - 12:35 PM
Hi, will this work on ATT? If yes, can you please provide steps.
Thank You.
#24
Posted 01 March 2014 - 06:04 AM
Sorry, but it doesn't work for US carriers. The US GSM frequencies are locked with no luck to unlock yet.Hi, will this work on ATT? If yes, can you please provide steps.
Thank You.
DROID RAZR with Tapatalk 4
#25
Posted 07 March 2014 - 03:37 PM
I'm trying to use this Motorola razr tx912 on T-Mobile but I'm not getting any bars but I can use the wifi, when I go to gobal I cant search for a network can anybody help.
#26
Posted 08 March 2014 - 05:57 AM
Please read at least once before posting..I'm trying to use this Motorola razr tx912 on T-Mobile but I'm not getting any bars but I can use the wifi, when I go to gobal I cant search for a network can anybody help.
XT912 DOESN'T WORK ON US GSM CARRIERS.
- Memnoch73 likes this
#27
Posted 17 March 2014 - 05:50 PM
#28
Posted 22 March 2014 - 07:51 PM
I'll update the patch soon for KK Roms.is it work for cm 11 , kit kat .. I installed aviator gummy ROM but data not worked ng in gsm.. is any solution
#29
Posted 16 May 2014 - 11:32 PM
Update: Dynamic fix uploaded. No longer specific for one ROM. The fix can be used on any ROM you are running.
#30
Posted 17 May 2014 - 08:46 AM
#31
Posted 17 May 2014 - 08:57 AM
#32
Posted 17 May 2014 - 08:54 PM
Let me check..
Razr HD with Tapatalk Pro
#33
Posted 19 May 2014 - 08:12 AM
sir I'm getting error while flashing ..thru sfestrap 3.72
I've updated the script. Can you test and report. My Razr is dead and I can't test it for myself.
#34
Posted 24 November 2014 - 08:23 AM
Oh my god! I can't thank you enough! Searched several days for a solution to get my SIM CARD working. It totally solved my problem (IMEI unknown, etc.)
THANK YOU! THANK YOU! THANK YOU!
#35
Posted 22 December 2014 - 05:20 AM
#36
Posted 22 December 2014 - 07:29 AM
when I went to Mexico, the only ROM that I could get working with the GSM patch was the STOCK ROM. Secondly, I also had to mess around with the APN settings to get it working.
Make sure you are on a Stock ROM and ask the provider for the correct APN settings.
GL
#37
Posted 22 December 2014 - 08:13 AM
#38
Posted 22 December 2014 - 08:42 AM
I would try it on stock....as I said, I couldnt get it working on other custom roms like LiquidSmooth and even stock based custom roms didnt work.
