[PATCH]GSM Fix for XT912 CM10.1.2, CM10.2
37 replies to this topic
#1 neoXank
neoXank
  • 66 posts
  • Current Device(s):Motorla Droid Razr XT912, Motorola Razr HD XT925
Posted 23 July 2013 - 11:58 AM
This is for XT912(CDMA) only
What it does.?
This allows XT912 users to run there phone on GSM networks on Custom Roms (based on AOSP,CM etc)
Since the ICS update, XT912 is capable of working on both GSM and CDMA network. However the GSM bands for US carriers are protected by a security layer so it doesn't work on US GSM carriers.
As long as you run the stock (or stock based) ROM, the GSM works fine. But the Global phone capabilities have not been included in the CM/AOSP/AOKP based ROMs yet.For that you need the GSM fix.
How To.?
  • Boot into recovery
  • Wipe Cache & Dalvik
  • Flash the zip
  • Wipe Cache/dalvik again
  • Reboot
Thanks.!!
Thanks to ZKK007 and HSD-Pilot.
 Info
  • I've also added many GSM APN's (mostly Indian Carriers) so you don't have to manually add it.
UPDATE:The fix now uses dynamic script and is no longer specific to one Rom. i.e. you can flash it on any ROM you're running and it won't affect your build.prop tweaks and properties.
Download Link:
PS: I searched the forums a lot and whatever I tried gave me some errors like sms issues or signal strength not showing correctly so I decided to make this myself. After a lot of Hit & Trials finally this is the result.
  • Memnoch73, aneeshmbabu, sharklasers and 4 others like this
#2 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 23 July 2013 - 12:29 PM
Nice work man. I moved this to the Development section and pinned it at the top so others can find it easily.
  • neoXank and dbReed53 like this
#3 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 23 July 2013 - 02:57 PM
anyways great work sir.. I am from india running aviator cm10.1.2 based ROM..in gsm network..I flashed this zip today everything works fine SMS MMS and data...nice work again
congrats
#4 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 23 July 2013 - 08:28 PM
how to get ussd code working ?
#5 neoXank
neoXank
  • 66 posts
Posted 23 July 2013 - 09:11 PM
USSD issues are consistent with CM based ROMs. It works a few times and then it doesn't.
I'm looking for it to fix.
#6 neoXank
neoXank
  • 66 posts
Posted 23 July 2013 - 09:44 PM
Thanks Man.!! Much appreciated.
#7 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 24 July 2013 - 12:38 AM
u r correct it works for me aboutb4;times after that nothing...
#8 henrysam79cu
henrysam79cu
Posted 25 July 2013 - 12:33 AM
how Flash the zip, what software use, please
#9 neoXank
neoXank
  • 66 posts
Posted 25 July 2013 - 01:58 AM
You can flash it with either Safestrap or Boot Menu Manager after flashing the ROM.
#10 henrysam79cu
henrysam79cu
Posted 25 July 2013 - 09:24 AM
forgive my ignorance I'm new to the subject could help me with a step by step guide
#11 neoXank
neoXank
  • 66 posts
Posted 25 July 2013 - 09:50 AM
What ROM are you using.?
#12 henrysam79cu
henrysam79cu
Posted 25 July 2013 - 09:34 PM
i use this CUSTOM AOKP NIGHTLY JELLY BEAN 4.2.2
#13 neoXank
neoXank
  • 66 posts
Posted 26 July 2013 - 03:42 AM
Ok. I've tested this on AOKP and it worked.
  1. Copy the Zip to your SDcard
  2. Boot into recovey (reboot and select recovey from Safestrap/BMM splash screen)
  3. Select Wipe>Cache & Dalvik Cache
  4. Return to recovery Menu
  5. Select Install>Select the Zip from SDcard. Wait for it to finish.
  6. Select Wipe Cache & dalvik.
  7. Reboot.
#14 itsrainner
itsrainner
  • Locationindia
  • Current Device(s):motorola razr maxx
Posted 27 July 2013 - 11:39 AM
after installing this gsm patch google play store not working it says unfortunately stopped
#15 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 28 July 2013 - 06:15 AM
hi I m also from India ..tell me which ROM unusing... did u followed the installation process..?which handset model u using? Inflashed this on cm based roms dont have any problems my data SMS all r working...in reliance cdma and Airtel network... message me any help
#16 neoXank
neoXank
  • 66 posts
Posted 29 July 2013 - 10:12 AM
Wipe cache and fix permissions.
#17 itsrainner
itsrainner
  • Locationindia
Posted 14 August 2013 - 10:53 AM
i cant check my balance my handset droid razr maxx using aokp rom
ussd codes not running?????
#18 neoXank
neoXank
  • 66 posts
Posted 14 August 2013 - 12:00 PM
AOSP/AOKP/CM based ROMs have issues with USSD.
#19 bukola
bukola
Posted 16 August 2013 - 01:35 PM
Thanks a million. Been searching for hours for a solution.
The patch not only fixed my SMS, it also fixed USSD. Gives my phone better reception also.
Now everything works fine.
XT912 running CM10.2
#20 bukola
bukola
Posted 16 August 2013 - 01:36 PM
